Offline ocram63_uk
#1 Posted : 25 June 2021 16:19:37(UTC)
ocram63_uk
Good afternoon, having read some of the 'DB E03 train consists 1965-67' thread in the Prototype forum I am now wondering which of the many versions of this loco I could buy.
I have 3coaches for this loco: 2 x 4095 and 4097
I will need the panoramic one too soon
In 1967 there was a 3053. This is the one with the screws on the roof. Bit outdated today.
In 2009 / 2010 there was a 37575 - I have also discovered that there is a 37577. The difference between the two seems to be in the sound decoder functions available for the latter.
In 2017 / 2018 there was a 39170 listed.
Are there any other models of this loco ?
I recall the E 03 when I first saw it in a catalogue and I prefer Era III trains to more recent ones.
I've looked on the UK / European 'bay' for these numbers and there are a couple at interesting prices, i.e < 200 GBP
Other suggestions ?
Thank you
Marco
#2 Posted : 25 June 2021 19:39:49(UTC)
The 4095, 4096 and 4097 coaches were among the original 27cm coaches produced by Maerklin. There was also the 4098 which was a 4095 with taillights and the 4099 panorama coach. Maerklin never made the ARDm Bar coach to go with this series. These coaches still had center mounted bogies and coupling shafts which resulted in excessive spacing between coaches. Maerklin later released the 42990 and 42991 sets of 3 coaches each in this livery with close couplings.
With certain changes, the E03/103 has been around in a number of variants since the late 60s/early70s.
There were versions in red/beige and black, red/beige and in DB Traffic Red.
If you go to http://www.bahn.hfkern.d...erklin/Dt_Loks_E103.html you will find a list which goes from 1966-2003
If you want a classic consist, look for the 3053 with the 24cm metal coaches 4085-4090.
I already mentioned the 27cm coaches that you already have plus the newer versions with close couplings.
There were also the 4295-4298 coaches in the red/beige livery (IC) of the late 70s/1980s (no dome car)
#3 Posted : 25 June 2021 21:44:54(UTC)
... and the 4099 panorama coach.
If operating a digital layout, don't forget the panorama coach is available as one of the first digital rolling stop items that Marklin made as 4999.
They are expensive for what you get and don't come up for sale often, but are a talking point on the layout with visitors.
Also remember that the 3053 version of the E03 is prone to paint flaking as they hadn't used an etch primer on the plastic - or whatever it is they do to make the paint stick.
Offline ocram63_uk
#4 Posted : 25 June 2021 23:23:24(UTC)
ocram63_uk
The 4999 I found on the 'bay' cost between 200 and 300 euros. For a coach? They must be crazy. Never!!
Is 27 cm the 'correct' lenght or it still is a shorter Marklin gizmo?
I had the coaches for the TEE in the late 70s bought in Lugano in a very posh shop. Don't recall if they were tin plate or not though.
I've seen a few 3053 and the paint jobs are really awful so I guess I will opt for the 37577, more modern.
#5 Posted : 26 June 2021 00:02:26(UTC)
Yep, that would be the going rate for them. But only if using a digital layout.
Offline Nigel Packer
#6 Posted : 26 June 2021 00:08:48(UTC)
Nigel Packer
Views messages in topic : 700
The 4999 has several lighting options built in, and also the motorised waiter who walks up and down the aisle delivering drinks.
That and the 4998 disco coach (disco lighting effects, choice of dance music, and several motorised dancing couples inside) were some of the most complex coaches ever made by Märklin. They were made in limited numbers, and have always been quite expensive as they are each unique of their type. Make a good talking point for visitors who have never seen anything like them before.
Nigel
#7 Posted : 26 June 2021 00:18:13(UTC)
If you really want an era III version then get one labelled "E 03" with just a single row of ventilation grills and make sure it is not era V/VI.
37575 would be an option. 37577 is a model of the main series, built in era IV, showing the state of the ’80s without the black border below the red part.
Offline Dave Banks
#8 Posted : 26 June 2021 01:30:23(UTC)
Dave Banks
Hello Marco, I have #39573 BR EO 3 TEE spanning Era III to IV. This version has single vents.
https://www.maerklin.de/en/produ..._torrpdb_pi1%5Blang%5D=4
https://www.youtube.com/watch?v=...MarklinModellersofSydney
D.A.Banks
Offline ocram63_uk
#9 Posted : 26 June 2021 09:28:57(UTC)
ocram63_uk
Hi Dave, the 39753 has a C-Sinus motor and I steer away from them if I can. But indeed single vents are interesting and I didn't notice the difference between single and double vents
#10 Posted : 26 June 2021 10:33:03(UTC)
I believe they should be 303mm for correct H0 scale length.
They are plastic coaches.
#11 Posted : 26 June 2021 11:08:30(UTC)
Yes. Most German TEE coaches should be 303 mm in H0 scale, some dining or bar coaches even 316 mm.
The latest Märklin versions are 282 mm. This is 1:93.5 for normal coaches, 1:97 for those longer dining or bar coaches.
For coaches in 1:87, look at Piko or Roco or other brands.
Offline ocram63_uk
#12 Posted : 26 June 2021 11:09:29(UTC)
ocram63_uk
So i measured the 3 type of coaches I have and this is what comes out:
Shortest: tin plate
Middle lenght: 4095-4097 i.e. 27 cm
Full lenght: Roco exact 1:87
Thank you hxmiesa
Offline ocram63_uk
#13 Posted : 26 June 2021 12:58:41(UTC)
ocram63_uk
@mike_c Thank you for the link. The only E 03 are the 3053 and 39573, all the rest are E 103. Interesting.
Looking at the 'bay' the 3053 are all in bad / very bad conditions when it comes to paintwork as well as having problems with the windshields or other windows.
I found:
a 3053 already converted to digital with a 6080 decoder which seems ok
a 37577 in more than good conditions
they both cost the same but between the two this time I'll go for the 37577 even if it has two rows of grids on the side :-)
#14 Posted : 26 June 2021 17:55:14(UTC)
I specifically did not mention the 4999 nor any variants of TEE coaches which do not correspond to the time frame addressed in the question.
The 4999 was a digital model of the dome car when it was operated by the Swiss Mittelthurgau Travel Bureau (Reisebüro Mittelthurgau) as 'Trans Europ Panorama"
The same applies to the 4147/4247, 4153 and other models with the later IC livery.
#15 Posted : 26 June 2021 17:59:44(UTC)
It's not Maerklin and it's not AC, but if you really want a nice E03: https://brassdepartment....ic-locomotiveusd-850-00/
Offline ocram63_uk
#16 Posted : 26 June 2021 18:29:42(UTC)
ocram63_uk
Mike, this is a beautiful 'beast' !!!
Offline mvd71
#17 Posted : 26 June 2021 23:07:38(UTC)
I found:
That’s a good choice. The matching era 4 Roco coaches in scale length come up on eBay all the time. The earlier era 3 versions are not so common.
#18 Posted : 30 June 2021 15:22:44(UTC)
For anyone who might be looking for an E03/103, I came across this offer on one of the dealer sites:
https://www.jura-modelis...ns-de-fer-allemands.html
This page was generated in 0.744 seconds.
