Offline JPL44
#1 Posted : 06 May 2021 14:50:38(UTC)
JPL44
If I buy a used Krokodil on EBay which needs work, will I be able to find necessary spare parts like engine “brushes” for the electric motor. Other parts too for Spur 1 Loks like smoke generators? Where???
I am thinking of buying one of the ca 1984 Krokodil Locomotives Spur 1-Track 1 Large Format. While they were issued to commemorate a Marklin business anniversary they are fully functional. I worry that such an old analog Lok will need service and that even the most common spare parts, such as brushes for the electric motor will be unavailable. I called up the schematic on thr Marklin website and found only a bag of light bulb replacements were still available and a few screws !! I also have a # 5706 Steam tender Lok and a 5719 diesel Lok both Spur 1. The smoke function on the 5706 never worked properly. I bought these Loks and a few cars in Germany in 1982/3 and I would run them in the old analog system in a very modest way since I lack space for an elaborate set up. I have always loved the Krok in Spur 1 since I first saw it in a shop window in Hamburg but I want one that will at least go around my minimalist circle. I wonder about the availability of parts if it won’t run without them or if my existing Loks stop working. I only set them up once-twice a year. I don’t know if they still work and in any case they surely would run better if I can service them. Are spare parts available from somewhere? If so, where? Thanks for your interest and advice. As you see, I’m a rank amateur!
#2 Posted : 06 May 2021 17:17:07(UTC)
A little personal intro maybe?
A little more specific info on which "Krokodil"? (Gauge, model # , etc..) ?
H0JPL44
#3 Posted : 06 May 2021 17:36:39(UTC)
Good point.
It is about I gauge, but more details would be helpful.
Related:
https://www.marklin-user...um/posts/t46875-Krokodil
#4 Posted : 06 May 2021 18:04:39(UTC)
Good point.
Related:
Hmm, never got a comment on the links I gave over in that thread, sounds like maybe he has picked up one of them (they were both 4 digit catalogue numbers, so reasonably old models).
#5 Posted : 07 May 2021 07:45:17(UTC)
Hmm, never got a comment on the links I gave over in that thread.....
I commented....
#6 Posted : 07 May 2021 07:49:47(UTC)
To answer the OP's question, Gauge 1 brushes are still available, but I don't know if it is a one size fits all. I recently got a few sets of brushes off ebay one pair of which went into a Gauge 1 BR55 steam loco.
https://www.ebay.com/itm...b50d7:g:ne4AAOSwoJZXSyfw
As to smoke generators, Suethe produce Gauge 1 smoke generators and these are readily available - most likely the original Marklin generator are Suethe produced.
https://www.ebay.de/itm/...a211b:g:EqEAAOSwJt5byE5-
https://www.ebay.de/itm/...edfa1:g:2o0AAOSwJclgbyvc
I don't know what size curves you are using, but I would suggest you don't even think about running a Gauge 1 Croc on 600mm radius curves. 1020mm radius curves are the minimum needed.
Offline phils2um
#7 Posted : 07 May 2021 10:46:09(UTC)
phils2um
I picked up a green gauge I krok, No. 5756 off Ebay about 10 years ago. It was in good shape except for some broken handrails. I found the part no. for a replacement handrail set and put in an order with Reynauld's here in the USA back in 2012. It was on backorder for years. I had pretty much given up hope and figured I'd need to fabricate something myself with brass wire. In April of 2017, five years later, I got a call asking if I still wanted the handrails. Of course I said YES and they arrived shortly thereafter. I've yet to install them as I want to put in a decoder possibly with sound when I start work on it.
Moral of the story is don't give up hope on finding replacement parts!
Phil S.
thanks 2 users liked this useful post by phils2um
Offline JPL44
#8 Posted : 07 May 2021 14:57:17(UTC)
JPL44
Thanks for all these helpful suggestions and great stories. I’ve been waiting for 40 years for a Spur 1 Krokodil so I’m patient too! But still nice to have great links to spare part sources if I ever find the courage to venture into the guts of my Spur1toys!! Jpl44.
Offline JPL44
#9 Posted : 07 May 2021 15:02:02(UTC)
JPL44
PS
I’m lucky on the track and circle radius/diameter. The track I bought in Germany makes a circle of 1020 mm radius and I can even extend it with a few straight track sections. I’m only limited by the size of my empty nest unused bedroom.
thanks 2 users liked this useful post by JPL44
This page was generated in 0.510 seconds.
