Offline French_Fabrice
#1 Posted : 18 April 2021 17:34:36(UTC)
French_Fabrice
Hello Markliners,
I've decided to jump for the 665201 Turntable made by Fleischmann, as the 7286 is no more produced by Marklin.
Here are a few pictures of the TT:
Top with the usual truncated cone
The wires below
The bridge from below
I have a LDT TT-DEC decoder, previously used for my 7286 TT.
If you look a the TT-DEC documentation (see https://www.ldt-infocent...ungen/ttdec_06_13_en.pdf ) on page 2,
you must set a jumper prior to the use. Until so far, for the 7286, I've set the jumper in position shown at § 2.1.
However, when looking at the connections of the bridge, they are a bit different of the 7286: This one has only 3 wires and NO diode, and the 7286 has 4 wires and 3 diodes.
My question is: Has anyone used this 665201 turntable with this decoder, and should I go for jumper in position shown at 2.2 or stay at 2.1 ?
My own feeling is to go for jumper in 2.2 ...
Thanks for your feedback
Fabrice
Offline PMPeter
#2 Posted : 18 April 2021 20:05:01(UTC)
PMPeter
Hi Fabrice,
I have the older Fleischmann turntable 6652 and the LDT TT decoder. In my setup I have the jumper installed across the Fl pins 3&2 as shown in diagram LDT 2.2. it works fine for me.
#3 Posted : 18 April 2021 20:25:12(UTC)
French_Fabrice
That's great !
Thank you Peter !
Out of curiosity, do you know/remember if below your TT bridge, the 1N4xxx diodes are also missing ?
Fabrice
Offline PMPeter
#4 Posted : 18 April 2021 20:31:55(UTC)
PMPeter
No I do not have any diodes. The colour coding on my wires is different than yours as well.
#5 Posted : 18 April 2021 20:37:46(UTC)
French_Fabrice
Many thanks !
I'll test that next week.
Fabrice
This page was generated in 0.323 seconds.
