Offline Maurice
#1 Posted : 29 March 2021 05:02:38(UTC)
Maurice
Any hints on decoupling ICE power units?
I have tried putting on a flat surface
and pulling apart but am concerned about the
amount of pressure l am applying without
the cars disconnecting.
Maurice.
#2 Posted : 29 March 2021 13:32:59(UTC)
If the train operates fine, then they are coupled correctly. I would use a cotton swab or other small applicator and put some silicone lubricant on it. If you have forcep clamps, you can also attach them to both couplers and only pry them, not pry by the train.
Offline eduard71
#3 Posted : 29 March 2021 13:41:00(UTC)
eduard71
Chile
I have the model, and usually I need to apply some force to un-couple the unit, Until now I had not have any problems.
Eduardo
Offline Maurice
#4 Posted : 01 April 2021 01:48:15(UTC)
Maurice
Thanks for suggestions. I will try decoupling them over Easter as I want to add a carriage that is compatible with this model.
I think this ICE will be added to my permanently coupled collection for which l make individual wooden bases and attach old M track that is used for storage and rolling on and off layout.
Maurice
This page was generated in 0.337 seconds.
