Offline Rohit279
#1 Posted : 27 February 2021 09:19:02(UTC)
Rohit279
Bahrain
Hello members !
At the outset, I wish every one the best of health !
I run my trains on marklin digital layout ( C - tracks ) with MS 60657. Most of my locos ( new and old ) have DCC decoders and I have no issues in registering and running them. I am however having problems in registering a few of my old MFX locos including a new ICE 2 ( 36712) that I just purchased. I have two other MFX locos ( that came as part of starter sets 29074 & 29752) which I was able to run earlier, but not anymore. The MS just keeps on prompting 'NO LOCO' at the end of the search. I have checked the wiring from the MS to the layout. The RED Wire is attached to the pin marked 'B' and the BROWN wire is attached to the pin marked 'O' at the back of the track. I ensure no other loco is on the layout while attempting the registration. As a last resort, I deleted all the registered locos from my MS and started afresh to see if this enabled me to register the locos. This however did not work as well and the issue remained.
I cannot think of any reason why the MFX locos won't register and run any more.
Appreciate suggestions / help !
Rohit
#2 Posted : 27 February 2021 09:34:50(UTC)
The MS2 will not automatically register DCC locos, you have to manually enter them into the MS2.
Are you able to drive mFX locos that you previously registered on your MS2?
Check that you haven't disabled the mFX protocol in the MS2's system settings. That will stop them from registering.
Offline Rohit279
#3 Posted : 27 February 2021 10:22:41(UTC)
Rohit279
Bahrain
Hi !
Thanks for responding. Yes, I do the manual search for DCC locos and MS detects. That's how I am able to run them. In case of MFX locos, it used to detect automatically. I have checked my MS2 again and all the three listed protocols ( MFX, DCC and MM2 ) are enabled. I notice that there is an option to reset the MS2 to 'factory settings'. Would this help ?
#4 Posted : 27 February 2021 12:09:29(UTC)
Originally Posted by: Rohit279 Go to Quoted Post
Hi !
My MS2 acted the same st first. I think if you reset it, all entries are erased, including updates, but not certain. What I did if a loco couldn't be found by search, I scrolled through the entire database list. In one example, I entered one of the same class which showed multiple item numbers, and it worked. You then can edit the road name, loc number, etc. If loc item number doesn't work, try another. More function icons may be shown than your model has.
Also, mfx is first protocol priority. Mine will occasionally reboot to my after 2 to 3 "warning no mfx loco" prompts. Be sure version 3.55 software is present.
Hope this helps.
Offline Rohit279
#5 Posted : 27 February 2021 12:27:26(UTC)
Rohit279
Bahrain
Hi !
#6 Posted : 27 February 2021 12:32:09(UTC)
Hi !
Also, mfx is first protocol priority. Mine will occasionally reboot to mm after 2 to 3 "warning no mfx loco" prompts. Be sure version 3.55 software is present.
Hope this helps.
Also, you may need to enter your locs address after selecting one of same class from database.
MS2 is basic. I have discovered since getting a CS3 that a whistle for example blows once on MS2, but 3 times on CS3. Item 37080 mm from 1999, before mfx.
Offline Rohit279
#7 Posted : 01 March 2021 15:18:29(UTC)
Rohit279
Bahrain
Thanks everyone for their help and suggestions.I finally decided to reboot my MS to back to it factory settings. Thereafter, the problem got resolved. all my mix locos are registering automatically. I also noticed that the SW version that I have is 2.5. Do I need to update my MS and how do I go about it ?
#8 Posted : 01 March 2021 23:11:54(UTC)
Hi Rohit
Yes it is advised to update your MS2.
To update it you have 2 solutions:
* connect it to an up-to-date CS2 or CS3
* connect a, second MS2 with an more recent version
Here is an extract (translated from German) about MS2 update from another one when both are connected to the track box
"For operating a mobile station with locomotive cards and several mobile stations
The devices next to each other should have the latest software version
Detection if the MS2 is up-to-date : you can use SHIFT + accessory key.
Under MS2 information, the software version is in second position from the top.
If you scroll down to the right, you get to "Update Gleisbox" and "Update MS2".
Via the selection on the left the update is carried out if necessary.
To do this, the MS2 has to be connected to a connected Central Station.
If you don't have a CS, one friend may have, your dealer or Märklin
Service performs the update.
Here is the original Märklin text in German
MM_71_Special_Seite50-57_MM_4-2018_071618_DE_se.pdf (4,667kb) downloaded 21 time(s).
Fragility of non-Marklin mfx decoders. (Digital)
by dave55uk 27/12/2025 00:16:00(UTC)
Conversion dc to ac mfx full sound (Digital)
by Adrian666 08/12/2025 19:57:45(UTC)
important questions mfx delta digital analog (Digital)
by Adrian666 24/11/2025 10:43:47(UTC)
ZIMO decoders with MFX support (Digital)
by Donb 26/10/2025 15:15:44(UTC)
CS2 not recognizing MFX loco (Digital)
by Zazza 28/08/2025 19:39:37(UTC)
Minitrix and mfx? (Digital)
by Kriegslok 06/06/2025 09:07:36(UTC)
Marklin 37342-01 SBB Swiss Re 4/4 mFx loco (H0-scale)
by Paul187 29/05/2025 10:31:48(UTC)
Unexpected MFX Behavior Resetting Turnout Addresses (Digital)
by tgj 05/05/2025 10:40:28(UTC)
Help! CS3+ seems to be changing my turnout addresses when I add mfx device (Digital components and Software reviews)
by tgj 04/05/2025 19:44:59(UTC)
Driving MFX locomotives without CS 2/3 or MS2 (Digital)
by bobyAndCo 20/03/2025 21:47:22(UTC)
MFX & ncer (Digital)
by Imagine 08/01/2025 04:32:17(UTC)
Did I kill the mfx decoder? (Digital)
by MartinS 07/01/2025 21:03:17(UTC)
Having trouble registering mfx loco to mobile station (Digital)
by Evergreen 04/01/2025 17:29:23(UTC)
MFX decoder coding (Digital)
by marklinist5999 12/12/2024 13:20:39(UTC)
Locomotive (mfx) not showing up in list on CS3+ (Digital)
by micknudsen 24/11/2024 12:49:35(UTC)
MFX loco not found by Mobile station when placed on track (H0-scale)
by Nibelungen 22/11/2024 13:30:40(UTC)
MFX Sniffer Carriage (Digital)
by revmox 18/11/2024 05:00:38(UTC)
Marklin Locos -- MFX or DCC? (Digital)
by Kiko 01/11/2024 04:21:06(UTC)
MFX decoder addresses (Digital)
by marklinist5999 23/09/2024 20:21:19(UTC)
Addresses for Mfx decoders (Digital)
by biswasg 19/04/2024 11:02:17(UTC)
Roco 69618 AC digital (MFX decoder) br118 won't work on digital (H0-scale)
by Lev.Sever 18/03/2024 23:39:27(UTC)
CS3 with it's new update 2.5.2. & ESU Loksound 5 (mfx) (Digital)
by bygger01 14/03/2024 20:11:58(UTC)
CS3 and mfx locos in maintenance mode (Digital)
by rhfil 27/02/2024 23:23:05(UTC)
Mobile station 2 not recognizing MFX decoder (Digital)
by Ivanmbrown 24/02/2024 01:55:36(UTC)
Marklin MFX+ Alzheimer Sympton (Digital)
by Kiko 07/01/2024 01:36:14(UTC)
Deactivate sound of mfx locomotives (Digital)
by trainman11 14/11/2023 13:04:28(UTC)
CS 2 not finding an MFX loco (Digital)
by artvegas 26/10/2023 05:26:35(UTC)
mfx with CV adress? (Digital)
by Goofy 09/09/2023 11:11:37(UTC)
Functions 25-32 not available in mSD3 with MFX? (Digital)
by einotuominen 10/08/2023 06:37:13(UTC)
Loco mfx adress (Digital)
by Mille 25/06/2023 08:49:59(UTC)
address MFX LOCO help (H0-scale)
by heinrichhess 14/06/2023 22:48:53(UTC)
Märklin MFX+ is not registering to CS2 after factory reset (Digital)
by applor 11/06/2023 23:12:15(UTC)
editing a 76496 mfx home/exit signal time on CS3 (Digital)
by marklinist5999 11/04/2023 14:25:20(UTC)
ESU Digital Lighting 50708 with MFX+ (Digital)
by Kiko 25/03/2023 22:52:53(UTC)
MFX or DCC (H0-scale)
by Seadog67 18/02/2023 22:16:50(UTC)
Mapping 32 bit MFX decoders to production specs (Digital)
by Bryan 08/02/2023 03:39:49(UTC)
How often do you use mFX cab view; what do you most engage? (H0-scale)
by Mark5 24/01/2023 07:13:52(UTC)
MFX DCC On my club layout (H0-scale)
by Timnomads 06/01/2023 16:19:38(UTC)
loco mfx registration problem (Digital)
by Thewolf 01/01/2023 14:11:14(UTC)
MFX registration (H0-scale)
by David Dewar 06/12/2022 12:31:01(UTC)
Mobile Station bug? or mfx decoder fault? (Digital)
by nikdog 04/12/2022 22:45:58(UTC)
Looking for MM, MM2 Mfx packets format (Digital)
by Papymouzot 15/10/2022 10:17:01(UTC)
CS3 not storing MFX decoder (Digital)
by Diesel2000 29/07/2022 16:46:20(UTC)
MFX and 6021 controller (Digital)
by cintrans 16/07/2022 01:37:41(UTC)
Marklin mfx world operation (Digital)
by marklinist5999 28/04/2022 18:41:51(UTC)
How to reset an MFX Item (Digital)
Belarus thulasa 24/03/2022 12:36:51(UTC)
MFX on ZIMO (Digital)
by Timnomads 16/03/2022 19:02:41(UTC)
Mfx Marklin Loco 37327 (Digital)
by Uthred 30/01/2022 19:32:10(UTC)
CS3+ cannot find locos based on mfx protocol (Digital)
by eldar760 12/01/2022 03:30:09(UTC)
mfx+ does it also work on DCC (Digital)
by Cheshy 15/11/2021 14:16:35(UTC)
This page was generated in 0.477 seconds.
