Offline LenV
#1 Posted : 24 February 2021 09:49:11(UTC)
LenV
Hi everyone. I have a Trix 420 railcar M22654. Unfortunately I have had a accident with it and it has broken one of the coupling pins that is the electrical connection between the centre coach (with motor in) and the next coach (with pickups). The railcar is now totally dead, won't run and no lights. Does this mean that nothing (electrical) will work as the other 4 pins are intact? Can I get a replacement for this connection? I cannot seem to be able to send an email to Marklin as it asks for order number which I do not have. Any help would be appreciated. Len
#2 Posted : 24 February 2021 16:37:44(UTC)
So far I can see the spare part number is E139042 and E 139 044 and they both in stock, for future references look up Trix.de, enter your catalogue number under spare part list and look up the required spare part you need
Offline ocram63_uk
#3 Posted : 24 February 2021 16:43:21(UTC)
ocram63_uk
Try writing here:
service@maerklin.de
ask if they can help you. Enclose as much info as possible in the contact form / email
Do you know the item number you need to buy ?
They will reply, it takes a bit though.
This is the service sheet
Trix 22654 Service Sheet.pdf (335kb) downloaded 21 time(s).
There aren't many spares available on Trix's website though
https://www.maerklinshop...p;iBrandId=2&submit=
Offline LenV
#4 Posted : 24 February 2021 17:52:52(UTC)
LenV
Thank you guys. Will look tomorrow. Len
This page was generated in 0.364 seconds.
