Offline Gunnar
#1 Posted : 04 February 2021 20:13:01(UTC)
Gunnar
I have a lot of N scale tracks and some Rocos rolling stock inclusive MiniTrix locos etc.
Since I have this mobile station lying more or less unused I plan to build up a layout with these tracks. I plan to convert these locomotives to digital this year if time permits. I have seen that MiniTrix are DC operated and that this station is included in starter sets.
My question is:
Can this mobile/Central station 2 be used on a digital layout (DC) and the locos converted with a decoder?
Any information most welcome
Gunnar
#2 Posted : 04 February 2021 20:43:43(UTC)
Digital layouts are neither AC nor DC, they are "digital". The MS2 (either Märklin or Trix) can be used for two-rail and three-rail layouts of any gauge.
All locos need suitable decoders with DCC, mfx, or MM. Neither SX nor FMZ are supported.
Same goes for Central Station 2.
Offline kgsjoqvist
#3 Posted : 04 February 2021 20:48:42(UTC)
kgsjoqvist
My question is:
Gunnar
Yes, the Mobile Station 2 runs DCC trains as well as mfx and fx (MM). The grey and the black versions with Märklin or Trix logo are all DCC compatible. The track voltage can’t be changed, so it’s the same as H0, bit at least the decoders offered for Minitrix are OK for this.
#4 Posted : 04 February 2021 20:52:21(UTC)
The track voltage depends on the power supply that is used.
You can use 16 V DC or 14 V DC to get a lower track voltage for N gauge. But, as you write, this should not be necessary.
Mobile Station 2 power supply? (Digital)
by LA2019 05/03/2025 00:25:34(UTC)
, is mobile station 2 compatible with the ECoS, (Digital)
by river6109 22/11/2024 15:09:09(UTC)
Mobile Station 2 with N-scale digi locos (Small scale)
by einotuominen 23/10/2024 15:50:03(UTC)
Mobile station 2 not recognizing MFX decoder (Digital)
by Ivanmbrown 24/02/2024 01:55:36(UTC)
Configure M83 with Mobile Station 2 (Digital)
by abeeche 14/12/2023 19:46:36(UTC)
Mobile Station 2 - Changing Addresses (General MRR)
by camcath 29/11/2023 23:26:23(UTC)
Mobile station 2 updating help (Model railroad software)
by Model Railway shed D 13/04/2023 22:00:22(UTC)
Märklin 34989 DSB T 298 with Mobile Station 2 (Digital)
by sbendtsen 17/02/2023 18:24:39(UTC)
Will this schematic work with mobile station 2? (Model railroad wiring)
by 0Danne0 04/02/2023 15:14:28(UTC)
Uploading unknowns into a Mobile Station 2 (H0-scale)
by tinroofrusted 18/01/2023 01:43:04(UTC)
Mobile Station 2 (60657) software update without any CS (Digital)
by Pronto5 14/01/2023 17:56:23(UTC)
Mobile Station 2 update from V1.1 fails from MS2 or 3 (Digital)
by gcanton 30/04/2022 17:30:56(UTC)
Mobile Station 2 with DCC loco? (Digital)
by LA2019 03/03/2022 23:45:32(UTC)
Mobile station 2 update to v3.55 in uk (General MRR)
by Christos -uk 31/01/2022 21:53:56(UTC)
About Mobile station 2 voltage (H0-scale)
by Nalgangdo 10/02/2021 00:40:56(UTC)
LokPilot 3 DDC with Mobile Station 2 (Digital)
by crow79 29/01/2021 09:03:45(UTC)
MARKLIN digital TRIX Mobile Station 2 (Digital)
by lrlgartner 26/01/2021 12:17:01(UTC)
Mobile Station 2 and 29186 Delta set (Digital)
by jmallen622 24/12/2020 04:19:05(UTC)
Mobile Station 2 Finding an MFX Locomotive (Digital)
by MarcP 14/11/2020 21:19:59(UTC)
Mobile station 2 problem (Digital)
by Stiewie 16/09/2020 21:25:02(UTC)
Resetting 74461 turnout decoder with Mobile Station 2 (Digital)
by Arnello 11/09/2020 20:42:12(UTC)
Controlling BEMO HGe 4/4 II - Nr. 107 - Grimsel with Mobile Station 2 (Digital)
by dott.erich 25/07/2020 22:19:52(UTC)
Conflict in running two DCC Trains on Mobile Station 2 (Digital)
by Laurence 19/07/2020 12:46:45(UTC)
Booster for Mobile station 2 (Digital)
by kytumba@gmail.com 09/06/2020 11:41:18(UTC)
Mobile Station 2, ESU Loksound 5 and MFX Issues (General MRR)
by skeeterbuck 03/06/2020 12:53:30(UTC)
Mobile Station 2 question (Digital)
by LongHairedDavid 17/02/2019 16:59:36(UTC)
by AlphonseGreybeard 02/02/2019 15:47:52(UTC)
by carrobaires 15/01/2019 16:09:23(UTC)
Mobile Station 2 power limit (Digital)
by RonBisplinghoff 28/02/2018 22:56:29(UTC)
Help with frozen Mobile Station 2 (Digital)
by corywendorf@mac.com 18/06/2017 17:21:57(UTC)
How to load Piko decoders onto your Marklin mobile station 2 (Digital)
by danmarklinman 24/10/2016 17:10:36(UTC)
Can a new Mobile Station 2 up date an old Mobile Station 2 (Digital)
by Harryv40 27/04/2016 16:55:28(UTC)
Should I use Mobile station 2 or older Uhlenbrock systems (Digital)
by artfull dodger 17/03/2016 02:51:11(UTC)
How can check if there is an update to Mobile Station 2??? (General MRR)
by vnangli 01/02/2016 02:41:52(UTC)
Zimo sound decoder and Marklin Mobile Station 2 (Digital)
by Unholz 29/05/2015 14:45:38(UTC)
Marklin mobile station 2 with DCC (Digital)
by danmarklinman 25/05/2015 20:13:03(UTC)
Mobile station 2 not working (Digital)
by glight1 31/08/2014 18:48:23(UTC)
Mobile station 2 speed step problem (SOLVED) (Digital)
by Emil 19/04/2014 09:19:11(UTC)
Power Supply Mobile Station 2 (Digital)
by mike c 12/01/2014 02:05:39(UTC)
Mobile Station 2 - Master / Slave Problem (Digital)
by sjlauritsen 22/12/2013 11:38:04(UTC)
How do I turn off mfx with Mobile Station 2? (Digital)
by sjlauritsen 13/08/2013 14:26:51(UTC)
76372 Mobile Station 2 setup/use (Digital)
by Jvt1 11/05/2013 05:12:25(UTC)
K83 (6083) with Mobile Station 2 (Digital)
by Jvt1 04/05/2013 06:17:11(UTC)
Problem: Digitrax DN135D vs Mobile Station 2 (Digital)
by zii 05/04/2013 20:11:22(UTC)
Mobile Station 2 won't recognize MFX locomotives (Digital)
by NRB 19/12/2012 19:21:05(UTC)
Mobile station 2 60653 turnouts (Digital)
by matias 29/08/2012 11:35:42(UTC)
Consisting 2 engines into 1 on the mobile station 2 (Digital)
by michelvr 20/07/2012 14:25:49(UTC)
Mobile Station 2 and Digital Signals (Digital)
by tulit 20/05/2012 16:54:07(UTC)
Mobile station 2 - 60653 - Temperature readings?? (Digital)
by Joseph Meiring 13/04/2012 13:56:44(UTC)
76ΧΧΧ signals in Mobile Station 2 (Digital)
by skaliy 24/02/2012 20:19:04(UTC)
This page was generated in 0.417 seconds.
