2 Pages<12
Offline Crazy Harry
#51 Posted : 01 August 2020 21:32:59(UTC)
Crazy Harry
Hi all
Here is a video on programming my first mSD decoder using the Marklin Mdecoder Tool.
Marklin Sound Decoder Tool
RegardsBigGrin
The link above isn't correct, I think you meant this one: mdecoder programming
Thanks for the video. Cheers,
Harold
Offline Johnvr
#52 Posted : 02 August 2020 10:12:47(UTC)
Johnvr
Views messages in topic : 1,307
Hello Harold
You are absolutely correct !
The link which I posted was another Swiss Railways Cab ride which I had been watching. !
The link which you have posted is the correct link.
How did you manage to find the correct link ?
RegardsBigGrin
Offline Crazy Harry
#53 Posted : 02 August 2020 20:50:15(UTC)
Crazy Harry
Hello Harold
RegardsBigGrin
I searched for mdecoder in YouTube and saw your name associated with the video.
Good video! How long does it take to update a decoder via the CS and programming track? Do you have the decoder tool that plugs into the computer as well? I understand putting the decoder on the computer tool allows much faster updates.
Harold.
Offline Johnvr
#54 Posted : 02 August 2020 22:14:51(UTC)
Johnvr
Hello Harold
I have 60215 Central Station 2 with the loco on the programming track.
It takes probably 45 mins for the Sound to be updated in the loco.
That's no problem for me, I can set it to run while I get on with other things.
I don't have a Sound Programmer. Yes, I believe that would be much quicker. However, I have mostly mSD decoders without the 21pin plate, so the decoder wires are all soldered and attached in the loco, so the Sound Programmer wouldn't work for me.
RegardsBigGrin
#55 Posted : 03 August 2020 00:05:36(UTC)
I am in the exact same situation. Yes programming is a little longer compared with a sound programmer but works without opening the loco, wiring changes, decoder handling. Speed is even a little faster (35 to 40 minutes).
#56 Posted : 25 September 2020 11:53:36(UTC)
Just a catchup 3.2.2.0
But you may wish to take note of the sound volue comment
Introduces a couple of new decoder boards
- 347463 for 245,246,246 (Sound,64Mb,mfx)
- 347464 for 239,240 (G,64Mb,mfk
Version: 3.2.2.0 (May 19, 2020)
Feature: New logical function "Alternative engine sound" implemented for gear locomotives
Feature: Electric locomotive rear derailleur now available in three different variations
Feature: The volumes of the two channels of the driving noise can now be set individually
Feature: Electric locomotives now have more gear steps in the lower speed range
Improvement: The volume is now linear to the set value (previously logarithmic), the volume may have to be reset after an update
Bugfix: An error in the load-dependent sound has been fixed
Bugfix: An error in the DCC mapping has been fixed
Bugfix: A sound that was switched off in buffer mode is no longer switched on accidentally
Bugfix: An error where locomotives with a connected buffer stopped restlessly has been fixed
Bugfix: An error in which it was no longer possible to approach in Analog AC after changing direction has been fixed
Bugfix: Bug when playing the prelubrication loops (diesel locomotive) engine 2 eliminated
Bugfix: Software PWM now goes correctly to its initial state when all outputs are switched off
Bugfix: Corrected an error which in a Märklin sound module caused SUSI Wait to be ignored
Bugfix: Corrected an error that prevented calibration under DCC and MM from being triggered
Bugfix: The sound of three-cylinder steam locomotives when transitioning to high speed ranges has been improved
Bugfix: Incorrect behavior removed when stopping and bridging paths were zero
Bugfix: Corrected an error that prevented a decoder with a buffer from being operated on a decoder tester
Bugfix: Fixed bug in internal sound processing
Bugfix: Fluctuations in pitch and volume when a turbocharger runs out on diesel locomotives eliminated
Bugfix: Fixed bug that prevented starting after a stop in a braking section
Bugfix: Corrected an error where a sound could no longer be triggered
Bugfix: An error in the stopping behavior has been fixed
Bugfix: The programming recognition in Motorola mode has been improved
Version: 3.2.1.3 (March 9, 2020)
#57 Posted : 10 November 2020 08:40:53(UTC)
decoder firmware 3.2.2.1 is available with mDT3 3.4.2 October update library
Version: 3.2.2.1 (October 12, 2020)
Bugfix: An error that led to the fact that the intervals between the steam chuffs on steam locomotives with a sinus motor could no longer be set has been fixed
Bugfix: An error in the engine sound of three-cylinder locomotives has been fixed
Bugfix: A random sound that should only be triggered when driving is now ended faster when the locomotive stops
Bugfix: An error which led to a cluttered sound when steam engines accelerated rapidly has now been fixed
Offline jonas_sthlm
#58 Posted : 18 November 2020 19:32:25(UTC)
jonas_sthlm
It would have been great if the mDT program could read locomotive CV through CS3.
Other desired function should be upload project files to SD card or USB stick and then update with CS3.
Offline DaveCowl
#59 Posted : 24 December 2020 03:03:40(UTC)
DaveCowl
Just wanted to say thanks for this thread and the contributors here. I managed to update my CS2 and then use it to update a couple of M loks to 3.2.1.0 directly.
I hope to learn more, like getting it to work through the mDT etc. which might hopefully get me to a more recent release.
Note that these loks had 'built in' decoders, so technically I guess not the mSD3 decoder but similar I am sure.
In any case, happy to be making forward progress and to give my CS2 something to do! BigGrin
Cheers! Dave.
#60 Posted : 27 February 2021 03:56:03(UTC)
decoder firmware 3.2.2.2 is available - limited to the two G decoder boards - via CS2 v4.2.13 package
Version: 3.2.2.2 (November 18, 2020)
Feature: The PID controller can deliver more power to the motor in load situations
Bugfix: An error in the analog mode, where the locomotive was already running before the sound "start engine" came, has been fixed.
Bugfix: An error when the rear derailleur clicks has been fixed
Bugfix: An error in the steam locomotive sound where the playback order of the steam chuffs got mixed up has been fixed
Maintenance: The approach control has been revised
#61 Posted : 22 June 2021 12:27:36(UTC)
The same 3.2.2.2 is available for the 2 x 1 Gauge decoders as of an incremental 31May2021 CS2 update
Edited by user 30 July 2022 13:15:30(UTC)  | Reason: Not specified
#62 Posted : 17 April 2023 09:06:59(UTC)
Re: 3.3.0.4 - available via mDT update initially
also see https://www.marklin-user...e-to-v3-3-0-x#post659671
Introduction to RailCom and "N"
comment: the documentation implies a capability for both mfx and RailCom which needs validation .
There also appears to be a "copy'n'paste" of the text for 346715 and 379408 (Nachrüstdecoder / Digital : MM, DCC, MFX , RailCom)
In the ChangeLog (but not the header definition, which does not supply HW implementation) both also state "mSD3 PluX22 decoder with RailCom"
#63 Posted : 03 December 2023 10:09:04(UTC)
3.3.1.0(12 Jul 2023) available via CS3 2.5.1(0) package update
Bugfix: An error in which idle sounds and brake squealing no longer occurred in the braking section has been fixed
Bugfix: An error in handling the DCC programming timeout has been fixed
#64 Posted : 03 December 2023 12:14:34(UTC)
I believe the decoders that are fitted to Trix locos have both Railcom and mfx. I haven't validated this as yet. The decoders fitted to Marklin locos seem to have the Railcom disabled.
Offline bph
#65 Posted : 03 December 2023 13:52:05(UTC)
I noticed that Märklin decoder projects saved according to the latest firmware, have some hidden railcom settings. (in msd3 and factory-fitted decoder projects, and not Plux22)
and when enabled, some railcom options appear in the mDecoderTool (same as in Plux22 projects). however, I have not tested to program it to a locomotive/decoder, as I don't have any rail com controller to test with.
However, I don't know if the decoders actually support it?, and if I have found all the settings required........
The standard mSD3 retrofit 21MTC decoder project with RailCom "enabled":
#66 Posted : 03 December 2023 18:07:55(UTC)
Ah, interesting. I don't have a Railcom controller either. Be interesting to see what the results are.
Anyone got an ECoS ???
#67 Posted : 01 March 2024 08:01:22(UTC)
3.3.1.0 / SpurN (09 Feb 2024) available via CS3 2.5.2(6) package update
Comment:
If is possible that the SpurN reference relates to a separate code family.
- 3.0.5.3 is the latest posted
The 245 signature does however tie them together
- 245/359215 -
- 245/341059 -
Version 3.0.5.3 (January 24, 2024)
Bugfix: Fixed a bug that caused CV235 to be ignored.
Bugfix: Fixed a small bug in the handling of the DCC programming timeout.
Bugfix: Fixed a bug that prevented conditions from being changed in mapping via CV35 and 261+3*n with n out of [0,79].
Edited by user 03 March 2024 00:23:45(UTC)  | Reason: Not specified
Offline jonas_sthlm
#68 Posted : 01 March 2024 13:36:49(UTC)
jonas_sthlm
also inside mDT
Offline QQQ1970
#69 Posted : 11 March 2024 19:42:29(UTC)
QQQ1970
I have BR80 37046. Märklin sound library only has 37063 which has 16 functions vs. 12 on 37046. Both are mfx decoders but not mfx+. Can I use 37063 sound project to replace the factory sound project on 37046?
#70 Posted : 11 March 2024 19:55:28(UTC)
Do they both have msd/3 decoders? If not then no.
It sounds to me like the 37046 may have an earlier msd decoder. Only items with msd/3 decoders have the sound project published on the product page, but I don't know if any early msd/3 decoders have unpublished sound files.
Offline Trevor G
#71 Posted : 05 June 2025 04:39:58(UTC)
Trevor G
I have only just come into this discussion.
I have been having issues with CS3 version 2.5.1 in that I could not load a project from the CS# to the mDecoderTool3.
I now have version 2.5.2, which I see is meant to fix the issues.
The problem is not only that I cannot read the locos, but I also cannot open the CS3 on the computer interface.
I have played around with the various options, but not being that technically minded, I cannot get it to work.
I have also heard that you can backload version 2.4.1
The question here is How?
Any help appreciatedConfused
Offline bph
#72 Posted : 05 June 2025 19:27:47(UTC)
You could also try to reinstall the 2.5.2 dated 28.03.2025 from USB before you downgrade. An update is also rumoured to come "soon"
But regardless of what you decide, here is how to do it:
CS3, downgrading to a previous version, or forcing the installation of the current version again:
  1. Download the installation file from Märklin, and load the desired version as the only file in the root directory of your USB stick. Insert the stick into one of the two white USB sockets on your CS3.
  2. Remove all connected cables from your CS3, except the power supply. (Including LAN and CAN etc.)
  3. To start the CS3 update: press and hold down the red left control button, and at the same time, press and hold down the stop bar, until the screen flashes. You can then release the button and bar.
  4. Wait while the CS3 processes the update. Do not try to interrupt the process. When it’s finished, the CS3 will automatically boot and start up normally.
Note that if you leave the LAN cable plugged in and connected to the internet, the CS3 will download installation files from the internet when you initiate an update using this method.
Offline Trevor G
#73 Posted : 06 June 2025 06:48:52(UTC)
Trevor G
Thanks for this. Sorry I didn't answer sooner, but I've been out all day.
Will try the newer version 1st and see how that goes.
Again, thanks heaps.
Trevor
Offline jonas_sthlm
#74 Posted : 06 June 2025 09:34:10(UTC)
jonas_sthlm
Feels more like a network issue than something that requires a reinstallation.
When you say read the locomotives, this is not done through the mDT3 program from the CS3 with a locomotive connected on the programming track.
The only way to read from the decoder is by using a connected USB programmer, since Märklin hasn't made any progress since the last release in 2023.
So are you using DHCP or a static IP address? and using a Wi-Fi bridge or a direct cable connection to the router?
Offline Trevor G
#75 Posted : 06 June 2025 10:20:36(UTC)
Trevor G
Trevor
I'm sorry, but I am still having trouble.
I have retrofitted the 2.4.1
I can see the CS3 & I can select any loco on the tracks.
The loco that I want to update is on the programming track and is a retrofitted decoder.
Works well, but the icons are not related to the various functions. It is this that I want to update.
When I have the loco identified I click on the 3rd button down that says (Read out decoder (mLD3 / mSD3))
A window pops up saying (No Decoder programmer present)
If I go to settings/Programming I get a choice of Decoder or Sound Programmer.
Clicking on either, it says no port configured. The drop down arrow only echoes this comment.
Please how do I read the decoder in the loco?
Very confused now.
Trevor
Offline bph
#76 Posted : 06 June 2025 11:45:49(UTC)
Very confused now.
Trevor
Note that the readout decoder function in mdecodertool, is for reading out a decoder (mLD3/mSD3) from a 60971 connected to your pc. (Only works with retrofit decoders). Take a look at the diagrams on the programming paths window, there you can see that the red out symbol are only visible on the path to the USB programmer.
So, in order to program your locomotive, you need to load the desired decoder project first in the mdecodertool.
You can start from scratch or modify an existing one from Märklin.
If you just want to modify the default project delivered with the decoder, you can find those under: "load projects from Mäarklin server" scroll down to the folder named "M60_L55" and then select the correct one. If you are just using the default sound projec,t take also note of this thread: https://www.marklin-users.net/forum/posts/t52301-Automatic-sound-effects
When you have modified the project as you want, you can then program the decoder. (mLD3/mSD3)
1. Make sure that the locomotive is alone on the programming track and has good contact.
2. selct the locomotive in mdecodertool.
3. Click on the program icon above the CS3 i medcodertool
4. If you have not changed any sound settings, you can program/transfer settings only. If it's a sound decoder.
i you made any changes to the sounds or sound settings, you also need to program the sounds. tick the check box.
Full programming with sounds takes approx 50 min. But programming settings only are much faster.
The mdecodertool should look like this when it's ready to program a locomotive through a CS3 or the USB stick.
Ignore the actual locomotive, it's just for illustration.
Offline Trevor G
#77 Posted : 07 June 2025 01:31:47(UTC)
Trevor G
Thanks for this info.
I am using static IP address and a direct cable from a router extender to the CS3.
Trevor
Offline jonas_sthlm
#78 Posted : 07 June 2025 09:08:56(UTC)
jonas_sthlm
Sometimes I've had the feeling that it's better to let CS3 use DHCP and then let the router assign an IP address based on the MAC address.
One might wonder what happened to the promised update for CS3...
Just as a bit of trivia: I’ve updated sixty locomotives using the CS3 with the latest mLD3/mSD3 firmware 3.3.6.2 (October 7, 2024), and the only issue occurred with the Danish steam locomotive E 991 (39491), where the upload froze at 50%. I sent that decoder to Märklin, and they reinstalled the firmware.
#79 Posted : 10 September 2025 11:04:00(UTC)
This is likely telegraphing a new announcement of a mSD/3.5 (256Mbit)
3 variants are evident all classed as H0
- base (factory)
- retrofit
- base with GamesWorld - i.e mFX+
Changelog
This changelog is intended to help you identify the improvements made to the firmware from version to version. Please note that minor or insignificant changes cannot be included here. Jumps in version numbers indicate internal improvements that have not been released.
Version: 3.5.1.1 (August 13, 2025)
Feature : In RailCom channel 2, ID 1 and ID 2 are now sent in addition to ACK ACK or ACK NACK if nothing else is to be sent
Improvement : Analog starting voltage improved
Improvement : Improved handling of flash memory, preventing deletion of empty area and duplicate saving of values
Bugfix : In certain situations, the very first mfx read attempt read a 0 instead of the real value
Bugfix : Corrected error in SUSI module detection when the SUSI module had the participant number 3
Bugfix : In the SUSI block of the mfx CC structure, if participant 2 and participant 3 were present, the CVs of participant 2 were displayed twice instead of those of participant 2 and participant 3
Bugfix : The control of the motor output has been corrected, the PWM was not set appropriately
Bugfix : The direction change with Analog AC (switching pulse) was not saved
Bugfix : Error in Märklin dynamic sound (mDS) corrected, each sample was used twice
Bugfix : Fixed a bug in the sound that could lead to permanent crackling and crackling
Bugfix : In DCC mapping, the functions SUSI-F21 to SUSI-F24 could not be programmed
Bugfix : In the FGL coupling output mode, the period value of 0 led to a switch-on time that was too long
Bugfix : For a locomotive in game world mode with consumption, the current supplies were empty (0) instead of full (255)
Bugfix : If the direction bit was set in the traction address CV19, this was distributed at RailCom as part of the address in ID 2
Bugfix : Motorola programming with a connected power buffer has been improved. For control panels without an automatic programming sequence, such as the Control Unit 6021, you must wait at least 10 seconds after pressing the "Stop" button before continuing with the next step.
Bugfix : The control of a voltage buffer remains activated during Motorola programming
Version: 3.5.0.12 (February 3, 2025)
Corresponds to the first delivery state of the series/game world decoder mSD3.5
Edited by user 12 September 2025 11:19:23(UTC)  | Reason: Not specified
2 Pages<12
This page was generated in 1.146 seconds.
