Offline joyofmarklin
#1 Posted : 20 October 2020 05:00:13(UTC)
joyofmarklin
I am running two C track with a MS along with my M track. ( Both separate )
I will be running 2 locos per track and currently have two pairs of turnouts operated by the MS. Although there appears multiple slots for functions, can’t help thinking you need to be a magician to operate them on. MS. For the more senior UK members “Ted Rodgers 321!. So was thinking of using M style switches instead. I understand that I can hook them up to my existing M track switches as the power to the track is separate? That being so will the C track switches illuminate, or do I have to have a separate power supply?
Thoughts appreciated?
Offline David2
#2 Posted : 11 November 2020 12:50:09(UTC)
David2
If drive digital with the old metal M track with a CS2. That works fine for me. Switches are on a seperate lighttrafo and I use the white boxes to operate them.
You need a seperate trafo. Try it first with a little secton and one switch.
thanks 1 user liked this useful post by David2
Offline dominator
#3 Posted : 12 November 2020 02:24:59(UTC)
dominator
I do the same as David. Works well. Less confusing to us older codgers. I have a wall chart of my layout with letters or numbers for each switch, so i know what button to press. I have uncouplers coupled to the same switch which work when the switch is point towards that uncoupler. It's just so simple for an analog brain like mine.
Dereck
Mobile station 1 and CS3plus compatibility (Digital)
by biswasg 25/03/2024 10:00:10(UTC)
Mobile station 2 not recognizing MFX decoder (Digital)
by Ivanmbrown 24/02/2024 01:55:36(UTC)
Mobile station vs. Central Station - and new C track layout application (Digital)
by bpitchkites 19/02/2024 17:42:29(UTC)
Mobile station 60657 extension cable (Digital)
by SamGreen 03/02/2024 20:36:36(UTC)
where is the problem with the 60652 mobile station (H0-scale)
by mike@complexplastics 16/01/2024 17:10:14(UTC)
by mike@complexplastics 15/01/2024 18:36:38(UTC)
Märklin digital mobile station 1 compatible trains etc (Digital)
by Alex222 04/01/2024 18:57:50(UTC)
Configure M83 with Mobile Station 2 (Digital)
by abeeche 14/12/2023 19:46:36(UTC)
Mobile Station 2 - Changing Addresses (General MRR)
by camcath 29/11/2023 23:26:23(UTC)
Connecting Mobile station (Digital)
by DhG 09/08/2023 09:09:22(UTC)
Turnout decoder, mobile station (Digital)
by pBonavoglia 31/05/2023 17:04:10(UTC)
Mobile station 2 updating help (Model railroad software)
by Model Railway shed D 13/04/2023 22:00:22(UTC)
Marklin mobile Station 60657 (Digital)
by Barton 17/03/2023 20:36:56(UTC)
Mobile station 60657 (Big scale)
by Zurky 08/03/2023 16:04:07(UTC)
Märklin 34989 DSB T 298 with Mobile Station 2 (Digital)
by sbendtsen 17/02/2023 18:24:39(UTC)
Will this schematic work with mobile station 2? (Model railroad wiring)
by 0Danne0 04/02/2023 15:14:28(UTC)
Feasibility of Running 4 separate Marklin C Track Loops Using 2 Mobile Stations 60653 (General MRR)
by mjborelli 31/01/2023 02:44:06(UTC)
Uploading unknowns into a Mobile Station 2 (H0-scale)
by tinroofrusted 18/01/2023 01:43:04(UTC)
Problem Running Marklin 39568 Engine w Marklin 60653 Mobile Station (General MRR)
by mjborelli 15/01/2023 18:47:41(UTC)
Mobile Station 2 (60657) software update without any CS (Digital)
by Pronto5 14/01/2023 17:56:23(UTC)
Can I use mobile station 1's with a CS3? (Digital)
by Allan2805 08/01/2023 01:26:43(UTC)
Mobile Station bug? or mfx decoder fault? (Digital)
by nikdog 04/12/2022 22:45:58(UTC)
Mobile Station 2 update from V1.1 fails from MS2 or 3 (Digital)
by gcanton 30/04/2022 17:30:56(UTC)
Changing address of 6080/6090 with mobile station v 3.148 (Digital)
by Michanglais 24/04/2022 16:26:12(UTC)
Central Station, Mobile Station & 32 Volt controller not working? (General MRR)
by mattj70 06/04/2022 05:43:05(UTC)
Mobile Station 2 with DCC loco? (Digital)
by LA2019 03/03/2022 23:45:32(UTC)
Mobile station 2 update to v3.55 in uk (General MRR)
by Christos -uk 31/01/2022 21:53:56(UTC)
dcc controller (Mobile station) compatibility (Digital)
by MalvernStation 12/12/2021 21:35:41(UTC)
Mobile Station 60653 (Digital)
by mramstedt 23/10/2021 18:53:42(UTC)
Mobile Station automation (Digital)
by robertmamlok 08/08/2021 19:02:47(UTC)
Mobile Stations Re-Booting; Proper Way to Use (H0-scale)
by alehrfeld 25/07/2021 16:12:22(UTC)
MS2 mobile station connections - basic questions (Digital)
by kimballthurlow 19/05/2021 08:44:41(UTC)
About Mobile station 2 voltage (H0-scale)
by Nalgangdo 10/02/2021 00:40:56(UTC)
Main station and mobile station app not found (Digital)
by eduard71 07/02/2021 14:49:34(UTC)
Mobile station 2 (General MRR)
by Gunnar 04/02/2021 20:13:01(UTC)
LokPilot 3 DDC with Mobile Station 2 (Digital)
by crow79 29/01/2021 09:03:45(UTC)
MARKLIN digital TRIX Mobile Station 2 (Digital)
by lrlgartner 26/01/2021 12:17:01(UTC)
Lokpilot V4 and Mobile Station (Digital)
by Kenneth1 19/01/2021 20:42:44(UTC)
Mobile station not working - please help (Digital)
by fejobelo 03/01/2021 19:38:38(UTC)
bizarre problem CS2 / iPhone mobile station with turnout control (Digital)
by applor 03/01/2021 01:23:21(UTC)
Mobile Station 2 and 29186 Delta set (Digital)
by jmallen622 24/12/2020 04:19:05(UTC)
Mobile Station 2 Finding an MFX Locomotive (Digital)
by MarcP 14/11/2020 21:19:59(UTC)
Mobile Station 60653 (H0-scale)
by Gunnar 27/09/2020 12:28:37(UTC)
Mobile station 2 problem (Digital)
by Stiewie 16/09/2020 21:25:02(UTC)
Resetting 74461 turnout decoder with Mobile Station 2 (Digital)
by Arnello 11/09/2020 20:42:12(UTC)
Mobile station 60653 (Digital)
by Gunnar 09/09/2020 16:30:50(UTC)
Controlling BEMO HGe 4/4 II - Nr. 107 - Grimsel with Mobile Station 2 (Digital)
by dott.erich 25/07/2020 22:19:52(UTC)
Conflict in running two DCC Trains on Mobile Station 2 (Digital)
by Laurence 19/07/2020 12:46:45(UTC)
by charles Sharpe 27/06/2020 13:54:42(UTC)
Booster for Mobile station 2 (Digital)
by kytumba@gmail.com 09/06/2020 11:41:18(UTC)
This page was generated in 0.498 seconds.
