Offline Timnomads
#1 Posted : 10 April 2020 17:44:16(UTC)
Timnomads
Hi All
I have just downloaded the latest CS3 software with the new track board. I have tried to put in my track design and can not figure out how to associate a point with the digital reference.
Also does any body know how to delete a track board. As usual the help is not too helpful.Confused
Tim
Offline siroljuk
#2 Posted : 12 April 2020 15:44:06(UTC)
siroljuk
Hello.
Firs how to delete the whole layout. Just delete all items in the layout first then you can find only trashcan on in the middle of the layout, click it and layout picture will disappear.
Points then:
'You have to assign all digital items in the CS3 before You can put them on the layout. Put the CS3 in edit mode not layout but the other Article and there you can add articles and afterward just pull them to empty layout.
Hope this help a bit
Jukka
Offline Tower
#3 Posted : 01 May 2020 22:41:18(UTC)
Tower
I also battled with this, it is basically a two step process:
1: Add the item you want by adding it to your "Article List" here you set the address, orientation etc.
2: Next step, edit your Track Board, the item will now appear in your "Article List", drag it down and drop it where you want it on the track board.
Hope this helps
Leon
This page was generated in 0.408 seconds.
