Offline Hics
#1 Posted : 15 March 2020 11:41:44(UTC)
Hics
Hello
I received a Swiss Engine 3739 from a friend for a service. And as it goes forward it has 2 lights in front (1 bottom and 1 top) and 3 at he the back at the same time. They changes as it revers. Is this all right?
Cheers.
Offline Bart
#2 Posted : 15 March 2020 20:02:45(UTC)
Bart
Originally Posted by: Hics Go to Quoted Post
Is this all right?
Definitely not.
Front should be 3 white; rear 1 white - at lower right side
3739 should have a 6090 decoder and a 62255 (or 622550) diode board for wiring of the bulbs.
First step is to check whether those are present
*Bart
Offline Dave Banks
#3 Posted : 15 March 2020 21:54:36(UTC)
Dave Banks
I apologize in advance that the picture is not clear but it will give you an idea what that loco requires to have two lights lit forward & one in the back travelling in forward direction:
[img]UserPostedImage[/img]
D.A.Banks
Offline Hics
#4 Posted : 15 March 2020 23:55:56(UTC)
Hics
Hi.
First looks like gray was swapped wit yellow. I returned them and now as it goes forward it looks like this
Forward is on the right. All 3 are flashing and at the rear one bulb only which should be bottom right. Unfortuantelly light is transmitted to top as well. I think "light wires" ( what is the right word?) are not working correctly. Am I right? Why is it?
#5 Posted : 16 March 2020 00:08:48(UTC)
Hi.
Does the loco have the little black paper "shades" inserts between the front of the body and the light tubes?
I'll take a picture tomorrow to show you what it should look like.
On the other hand , the "blinking" is probably due to the decoder
Not sure 100% (it's been too long...Laugh ) , but if I remember right, some older generation decoders using the loco's chassis as return where exhibiting this "pulsation" .
Jacques
Offline Dave Banks
#6 Posted : 16 March 2020 00:25:16(UTC)
Dave Banks
Jacques that loco has the orange wire meaning electronic ground & should not flicker or pulse. Just checked mine & all good. Paper shades a must to get the three headlights.
D.A.Banks
Offline Hics
#7 Posted : 16 March 2020 00:25:19(UTC)
Hics
Hmm, I don't think so. It lookes like this on both ends.
Please do. That would be very usefull. Thanks
Offline Dave Banks
#8 Posted : 16 March 2020 00:34:16(UTC)
Dave Banks
No we are referring to the body ends. They have paper shades placed in between the plastic light diffuser. Can you take a photo of that at each end please.
D.A.Banks
Offline Hics
#9 Posted : 16 March 2020 00:50:37(UTC)
Hics
here it is.
Offline Dave Banks
#10 Posted : 16 March 2020 02:50:22(UTC)
Dave Banks
You are missing the paper shades hence your seeing all lights on at once.
D.A.Banks
thanks 2 users liked this useful post by Dave Banks
Offline Hics
#11 Posted : 16 March 2020 11:46:22(UTC)
Hics
Great pictures, thanks!!
I will work on new separator tonight. I'm just thinking what to use? Will thick paper be temperature resistant to a bulb?
#12 Posted : 16 March 2020 11:59:19(UTC)
Thanks Dave, you've been faster ...taking advantage of your earlier time zone!!! Laugh Laugh
Yes, just black cardboard /bristol paper will do .
#13 Posted : 16 March 2020 14:00:50(UTC)
Did you check to see whether the cardboard insert fell out when the locomotive was opened?" That happened to me when I first opened by 3638.
Offline Hics
#14 Posted : 16 March 2020 16:41:30(UTC)
Hics
Did you check to see whether the cardboard insert fell out when the locomotive was opened?" That happened to me when I first ...
They definitely weren't there.
But thanks to the pictures I managed to do this. I will check it tonight how it actually work.
#15 Posted : 16 March 2020 18:16:28(UTC)
I bet you it will.
Good job!ThumpUp
Offline Hics
#16 Posted : 17 March 2020 08:39:40(UTC)
Hics
It works perfectly. BigGrin
Big Thank You to all of you guys for help and support.
Cheers.
thanks 1 user liked this useful post by Hics
#17 Posted : 17 March 2020 11:34:20(UTC)
Cheers.
Yesss! Laugh Laugh
Offline Bart
#18 Posted : 17 March 2020 16:24:13(UTC)
Bart
The decoder depicted in post #4 is a 6090 (as was standard for 3739), not 60902.
The 6090 does not have a rectified (+), and the light bulbs are wired to ground.
This may cause flicker.
Yes, the wires are orange, but they are connected to the 62255 lead with the ground screw, and, if I see correctly, a brown wire, probably to the wheels.
For the electronics savvy, there are ways to add an orange (+) lead to the 6090
http://www.hanno-b.de/index.php?id=43
*Bart
Offline Hics
#19 Posted : 17 March 2020 16:29:01(UTC)
Hics
This may cause flicker.....
Yes, they flicker a lot BigGrin
Nothing I can do about it
Offline Bart
#20 Posted : 17 March 2020 17:11:15(UTC)
Bart
Unless you do the decoder surgery as in the link above, or have a spare 60902 (or newer) for exchange.
Both would also require a bit of rewire of the orange leads to the 62255 - happy to post the scheme if required
*Bart
Offline Hics
#21 Posted : 17 March 2020 17:22:26(UTC)
Hics
Both would also require a bit of rewire of the orange leads to the 62255 - happy to post the scheme if required...
No, thank you. It's already on its way back to my friend.
Offline Bart
#22 Posted : 17 March 2020 17:37:24(UTC)
Bart
He'll be pleased with the correct lights anyway!
*Bart
This page was generated in 0.510 seconds.
