Offline sonra
#1 Posted : 18 December 2019 23:33:28(UTC)
sonra
Israel
hi guys
I want to add signals to my HO layout . the controller is arduino board . I am looking for SMD leds that i can use( one for each color ) do you guide me what to buy ?
I need only the leds and I will design the circuit for them
Regards Doron
Doron
#2 Posted : 19 December 2019 00:04:42(UTC)
almost any SMD led will work for this application. I would order some that are presoldred onto fine wires.
I used type 805 LEDs some years ago before oe could get them prewired. See https://cabin-layout.mix...07/08/tunnel-signal.html
#3 Posted : 19 December 2019 07:40:08(UTC)
If you do it yourself and you make your own led board I would go for smaller smd leds (402) and you also get flat ones, have a look at ledbaron.de. (he is on holiday at the moment but his ebay website is still running.
Offline sonra
#4 Posted : 19 December 2019 11:26:15(UTC)
sonra
Israel
Hi guys
Thanks for quick help
Doron
Doron
Offline cintrans
#5 Posted : 21 December 2019 18:28:30(UTC)
cintrans
Aruba
Originally Posted by: sonra Go to Quoted Post
hi guys
Regards Doron
Doron
I used 0603 and 0805 smd leds on mine bought via Amazon . com, they are very small and not pre-wired, so you need to have some soldering skills to hook them up. I used 30 AWG coated magnet wire to hook them up
Good luck
Jean-Pierre
Offline sonra
#6 Posted : 21 December 2019 20:46:36(UTC)
sonra
Israel
Thanks for help .I have ordered 0402 leds . I think i will give the soldering work to some professional . ( I have soldering skills but not for this size )
Doron
Doron
This page was generated in 0.500 seconds.
