Offline LongHairedDavid
#1 Posted : 06 December 2019 18:42:18(UTC)
LongHairedDavid
I have found that my krok and some SBB coaches do not like going through a switch back - a quick right and then left on R2s - at over step 85 on my ECoS. I would like to put up an 80kph limit sign before the curve. What would this look like - SBB or DB, either way?
Long Haired David
AKA David Pennington
A mystified Maerklin Newbie
Offline Jimmy Thompson
#2 Posted : 06 December 2019 19:32:17(UTC)
Jimmy Thompson
David,
Here is a start:
http://www.sh1.org/eisenbahn/snlf1.htm
http://www.sh1.org/eisenbahn/snlf2.htm
And here is the main page:
http://www.sh1.org/eisenbahn/s.htm
Unfortunately he does not have SBB signalling, but I will bet someone does somewhere Smile
Jimmy
Jimmy T
Analogue; M-track; BR 111; KLVM; Primex; Sarrasani Zirkuswelt
#3 Posted : 06 December 2019 19:55:03(UTC)
LongHairedDavid
David,
Here is a start:
Jimmy
The information is great - a rectangular white plate with black border and the speed limit shown as 1/10th - 8 = 80kph. Any idea of the dimensions as these aren't mentioned?
Long Haired David
#4 Posted : 06 December 2019 20:59:12(UTC)
Jimmy Thompson
David,
From this (which is albeit for earlier eras) but I think the standard did not change much, which has has some dimensions (but not all):
https://www.themt.de/org-0510-49.html
generally it seems to be sign top to bottom 50 cm (20")/87 (and side to side for a square sign)
And height from ground 1,75 meters, although I have also seen 2,0 meters mentioned (80"/87) as a safety measure so that workers do not run into a sign on a pole and cut their head.
Hope this helps a wee bit.
Jimmy
Jimmy T
This page was generated in 0.353 seconds.
