Offline twmarklinfan
#1 Posted : 01 October 2019 21:06:01(UTC)
twmarklinfan
Hi All,
The other day I got my old 45 out for a run. It works fine on my test bed using a 6021 controller. However when I put it on my layout controlled by CS3+ and CS2 slave.
I noticed that the box that it has a label indicating that at some point the loco has been to Marklin for a repair and perhaps they fitted a different type of decoder.
Have a look at the photos and see if you know what type of decoder it is and how I can get it to run again.
Thanks in advance
Offline ktsolias
#2 Posted : 01 October 2019 22:42:19(UTC)
ktsolias
Märklin 60945 is an mfx decoder
#3 Posted : 01 October 2019 23:04:08(UTC)
twmarklinfan
Is that what it is? If so I should delete from my CS3 and reregister?
Offline applor
#4 Posted : 01 October 2019 23:20:09(UTC)
applor
They would have replaced the old 6090x MM decoder from the 37450 with the newer MFX decoder they used in the 37452, 37453.
I would delete it from the CS3 and allow it to register as MFX on your programming track.
This page was generated in 0.328 seconds.
