Offline arievered
#1 Posted : 22 July 2019 11:44:27(UTC)
arievered
Israel
I understand from Maerklin support team that in order to work with L88 I have to upgrade my CS2 to the last software version 4.2.9 (0).
I tried to dowload from Maerklin website but could not find this version.
Is someone can send me the link for this software version?
Thanks,Arie
#2 Posted : 22 July 2019 12:54:49(UTC)
Hi Arie
You need only to connect your CS2 to internet using RJ45 cable and set IP into AUTO mode
Alternately on marklin website you may download the files once you have clicked to accept their terms & conditions
Offline 60904
#3 Posted : 22 July 2019 23:03:54(UTC)
60904
I read today that you might have a problem after installing the new version. So be careful.
Greetings
Martin
Offline TEEWolf
#4 Posted : 22 July 2019 23:14:27(UTC)
Thanks,Arie
Indeed very strange at the English website to find the download. Try it via the German website from Maerklin
https://www.maerklin.de/...e/downloads/cs2-updates/
Go down to the last line of the side and set a tickmark into the grey circle and the page will be etxtended. Then you can download a file. There I do not have a CS 2. I cannot say which version it is. Maerklin says no word about the version. Just hope it is the latest one - 4.2.9 (0).
#5 Posted : 23 July 2019 08:00:18(UTC)
What is new in 4.2.9?
#6 Posted : 23 July 2019 11:49:05(UTC)
4.2.9 was publish weeks ago. There is at least a bug fix for 4.2.8. It also brings 32 functions to the MS2.
See #47 and #48 in this thread:
https://www.marklin-user...ction-support#post595560
#7 Posted : 23 July 2019 12:56:25(UTC)
Apart from what Tom (HO) says, the major bug fix appears to be that it now loads the ms2 with the necessary code to load into the ms2 track box, which the 4.2.8 version didn't do.
#8 Posted : 23 July 2019 16:04:17(UTC)
Thanks Tom & Alan.ThumpUp
Offline arievered
#9 Posted : 28 July 2019 08:52:23(UTC)
arievered
Israel
I downloaded the file CS2Update.img
Should I use a USB to update? Is it the only file needed? What is the proccess to download it?
Arie
Thanks. Got a file -
Offline TEEWolf
#10 Posted : 28 July 2019 18:20:37(UTC)
Arie
Please read these technical informations by Märklin and in English!
http://streaming.maerkli...fo_above_3_6_english.pdf
http://streaming.maerkli...update_4_2_8_info-02.pdf
And I don't believe it:
the Maerklin website for a CS 2 update in English is available again!
This page was generated in 0.629 seconds.
