Offline Torstein
#1 Posted : 14 July 2019 16:28:25(UTC)
Torstein
I have Marklin BR 78 440 nr. 55077 who works fine except for the cylinder exhaust. It smoke little - almost nothing. I have read the instructions about overflow smoke fluid who interrupt the cylinder smoke, but I have not turned it upside down or overfilled it but it had some fluid in it when I got it. So I do not know.
Is it some way to fix this problem? Clean it up or something? Keep on running it? Please give me an advice.
Torstein
Solution: A little air pressure in the cylinder valves clean them and fix the problem.
Have fun.
Torstein
Edited by user 18 July 2019 13:48:52(UTC)  | Reason: Not specified
thanks 2 users liked this useful post by Torstein
Offline cramcke
#2 Posted : 04 September 2019 20:55:39(UTC)
cramcke
Torstein,
Did you use Marklin smoke fluid?
I'd say you have two options (my opinion here): Option one is to use a pipette to draw excess smoke fluid out. The other option is to wait- the smoke fluid evaporates fairly quickly.
Not sure about just running it. I can imagine that if the ventilator (fan) is in fluid, it could do damage. If the smoke just wisps out the issue is likely already the fan, which may not be turning.
- Carsten
thanks 1 user liked this useful post by cramcke
This page was generated in 0.325 seconds.
