Offline rudolf
#1 Posted : 14 June 2019 09:37:58(UTC)
rudolf
Romania
Hi everybody. A friend gives me a gift, a Marklin train, model 185 . Please can you explain me the power polarity(the central is plus or minus ?) Thank you very much.
#2 Posted : 14 June 2019 11:09:44(UTC)
Welcome to the forum!
With most Märklin trains the polarity switches at least 100 times per second, so central will be plus at least 50 times per second and minus at least 50 times per second.
Which ref. number does the loco have? I assume it is a product with a 36xxx or 37xxx ref. number.
Do you have appropriate tracks?
Which controllers do you have?
AC up to 16 V should drive the loco while 24 V will reverse the direction.
Most likely digital operation is also possible, but the supported digital protocols vary.
#3 Posted : 14 June 2019 17:02:52(UTC)
Rudolf,
Maerklin models are 3 rail AC. In normal analog operations, the centre rail (slider) is the live and the tracks function as the return. Most modern models with built in digital decoder now function using DC power when used with a digital controller (Central Station/Mobile Station). I do not know exactly how this works, but I don't think it is as simple as saying that the centre rail is + and the rails are -. In addition to the voltage used to power the motors and lights, there is a carrier wave which provides instructions to the decoders.
The Maerklin 185s all belong to the Hobby (36XXX) line with the exception of a few converted Trix models with plastic shells released as 37XXX models.
Do you have other Maerklin models and a transformer? What other equipment/models do you have?
If your other models are 2 rail DC, you probably would want to exchange the AC model for a Trix DC model.
NOTE to Admin: If this topic refers to HO scale models, it should be moved to the appropriate section.
#4 Posted : 14 June 2019 17:08:44(UTC)
Digital current is not DC and polarity changes a few thousand times per second. There is no separate carrier wave, there is just track voltage that conveys information by changing the polarity at specific intervals.
Offline rudolf
#5 Posted : 19 June 2019 17:14:22(UTC)
rudolf
Romania
Thank yuou very much !!! It is clear to me.
Offline Bones
#6 Posted : 28 June 2019 07:31:37(UTC)
Bones
Dear Rudolf
I think people are being overly technical here whether your dealing with AC or DC you have only a + and - side to the output from any source
With marklin the centre studs are your + Active or live side
and the two rails are - Negative, Neutral, earth or ground or for the classic one none positive
Usually the terms earth or ground are used for houses, buildings and the like because they can be 1 2 or 3 phases
The most important thing is try not to get them confused
You could spend a day discussing the diference between AC and DC characteristics but I presume you weren't asking for that
#7 Posted : 28 June 2019 09:24:52(UTC)
With Märklin 1 and Märklin Z there are no centre-rail studs. And this question is still in the Big scale forum.
Maybe call them "red" and "brown" or "live" and "return". Calling them "+" and "-" makes no sense in digital or AC configurations. People who try to connect LEDs may get confused.
This page was generated in 0.438 seconds.
