Offline Bahner
#1 Posted : 27 May 2019 03:59:07(UTC)
Bahner
Back story: Not too long ago I bought a Minitrix 12264 R4/4 analog steam locomotive. I've put 20-30 hrs. of run time on it and it's never missed a beat. Today, I had it running for about a 1/2 hour, then went to lunch (unplugged the transformer during this time) and then when I came back to run it a bit more it wouldn't move at all (however, lights front and rear would come on).
The first thing I checked, after taking it apart, was all the gearing from the main worm gear to the smaller bottom gears and all turned freely. I then dismounted the motor from the gearing and ran it with power pick-up from the wheels. Dead motor. I then hand turned the motor shaft and after a bit of stuttering I could get the motor to run at a variety of speeds. Then I reversed the power via the transformer and I while I can feel the motor trying to turn, it just won't turn the shaft. So, basically, the motor turns one way (albeit a bit reluctantly), but not the other way. I can turn the locomotive 180 degrees, and get the same results (motor turns one way only).
The next obvious thing was to try a different locomotive and it went forward and backwards without any issues.
I'm at a loss to explain this behavior since I'm not sure how these locomotives processes the polarity (if it isn't just a 'plus/minus' directly to the motor). Anyone with experience, please chime in as I'd like to fix this instead of sending it off for a long stay at Marklin/TRIX, if possible).
Ralph.
#2 Posted : 27 May 2019 14:57:42(UTC)
Ralph.
This sounds like one of the brushes has collapsed and the brush spring is now acting as a ratchet on the armature.
Offline Bahner
#3 Posted : 27 May 2019 15:21:07(UTC)
Bahner
Ralph.
Thanks for that. I do suspect the motor, but being of the enclosed type, I can't see what's going on inside. Just seems unusual that after 20-30 hours of normal running that it would fail, but stranger things have happened.
Looks like a trip to Marklin/Trix warranty service department is in order.
Ralph.
Offline Bahner
#4 Posted : 31 July 2019 06:56:04(UTC)
Bahner
I sent this 'Made in China' locomotive (first released in 2012, but bought new from a retailer last year) off to Marklin in Germany and I received this reply: 'Due to missing spare parts unfortunately a repair of the item is no longer possible' and that they'll send a replacement item (of my choice) with a similar value. Unfortunately, the other steam locomotives that show as 'available' on the Marklin (or Trix) online shops are quite a bit more expensive, so we'll see how this goes.
Shame really as the R 4/4 locomotive was a very smooth and quiet runner right up until it malfunctioned, but good to see Marklin making the effort to send me a comparable replacement.
This page was generated in 0.376 seconds.
