Offline rhfil
#1 Posted : 04 May 2019 16:33:53(UTC)
rhfil
I am planning on keeping my layout to era II at the latest and wonder what signals are available for that period. Were electrified signals in use that early?
Offline michelvr
#2 Posted : 04 May 2019 16:43:57(UTC)
michelvr
Hello rhfil,
Era 2: Time Period Approx. 1920-1945 the period after the formation of large state railways in Europe. Yes, electrified signals were in use.
What country are you modelling?
Remember most countries had their own type of signals so it's important to know which country you are modelling.
Offline rhfil
#3 Posted : 04 May 2019 21:43:38(UTC)
rhfil
Germany and as early as possible. Preferable era I but with early era II.
Offline applor
#4 Posted : 07 May 2019 03:24:43(UTC)
applor
Semaphore signals, mechanically driven.
Offline rhfil
#5 Posted : 07 May 2019 16:00:13(UTC)
rhfil
That is what I thought. Where can I get an HO scale version of them? Are the Viessmann Bavarian signals the closest I can use?
Offline TEEWolf
#6 Posted : 07 May 2019 17:29:40(UTC)
These are the eras you talking about.
https://www.themt.de/mr-0115-49.html
https://www.maerklin.de/...formation/eras-overview/
http://web.hs-merseburg.de/~nosske/EpocheII/
http://web.hs-merseburg....pocheII/ds/e2d_9600.html
http://web.hs-merseburg....I/ds/e2d_0601.html#sig13
https://www.themt.de/org-0500-49.html
The Bavarian Länderbahn hd slighly different signals, as you an see. But I myself have never seen them.
As you see the semaphore signals have not changed since this era II. And honestly, still today the DB AG is using the signal technique mostly, which is about 80 to 100 years old. Only slowly and partially they have changed to a elctric new system for signals. Even the high speed lines are only 2 equiped with the newest signal technique ETCS (European Train Control System)
https://en.wikipedia.org...ean_Train_Control_System
The biggest change was form the semaphore ones to the light signals. So actually using the Märklin semaphore signals for your purposes will be fine.
Perhaps you find somewhere a specialist for this era II offering very special ones. I do noz know anybody.
Here are the Märklin signals:
https://www.maerklin.de/de/lp/2017/signale/
https://www.maerklin.de/...x210_8seitig_1222_DE.pdf
Even most of the text is in German, nevertheless you can see all kind of signals by pictures.
#7 Posted : 08 May 2019 05:18:55(UTC)
In my modelling I revert to the thought that 99.99% of people who might look at my layout will never know what is correct.
Maerklin sepmaphore signals will look attractive and purposeful on any layout from era I to VI.
Searchlight signals (the so called light signals) were in use from the early 1930s.
Maerklin makes them too.
Offline applor
#8 Posted : 08 May 2019 06:53:39(UTC)
applor
If your layout is set in Bavaria then I would use the Viessmann Bavarian style signals. Anywhere else use the standard Viessmann semaphore signals (or equivalent).
Depending on your layout control, a lot of signals now come with built in digital decoders, or you can still buy the standard version (and connect those to a digital decoder if you want).
I use the Viessmann semaphore signals and like them. They have slow arm movement which looks good, though they are noisy on activation (they make a loud thunk noise) is the only detractor.
Märklin signals - for M not C ? (H0-scale)
by fbaube Yesterday at 11:40:02(UTC)
Converting old signals to LED (H0-scale)
by DaleSchultz 14/08/2025 04:10:49(UTC)
How to clean old solenoid signals and turnouts (points) (General MRR)
by Aussie Susan 19/06/2025 07:44:46(UTC)
Weinert Bavarian Signals (H0-scale)
by BwanaJoe 19/05/2025 15:47:10(UTC)
Rocrail - synchronized signals? (Model railroad software)
by JohnMishler 17/05/2025 03:19:04(UTC)
Setting Up Märklin 76393 Signals with CS3 and C-Track (Digital)
by tgj 27/04/2025 16:29:13(UTC)
Using M signals with C track (H0-scale)
by Luna 27/04/2025 05:02:03(UTC)
Does anybody recognise these signals ? (H0-scale)
by Johnvr 25/04/2025 15:50:45(UTC)
need help to reset viessmann multiplexer signals (Digital)
by fabstar68 19/04/2025 17:46:44(UTC)
Marklin Z-Scale Signals Part 2 (Small scale)
by Fluegelmeister 07/04/2025 01:07:03(UTC)
New Toporama Video - Z-scale Signals! (Small scale)
by Fluegelmeister 10/03/2025 04:36:10(UTC)
Manual enter linked signals into the CS3? (Digital)
by Nick_40034 13/02/2025 10:22:05(UTC)
info on distant signals with Rocrail (Model railroad software)
by fabstar68 11/02/2025 20:48:24(UTC)
Signals (H0-scale)
by Mjn2ts 07/02/2025 21:44:40(UTC)
Marklin or Viessman signals (General MRR)
by obb_taurus 13/01/2025 20:33:03(UTC)
External power supply for Märklin signals (General MRR)
by micknudsen 19/12/2024 21:30:03(UTC)
Static signals......supplier for Z gauge (Small scale)
by spinnerguy 12/12/2024 19:14:54(UTC)
dcc brake signals & marklin cs3 (Digital)
by fabstar68 12/06/2024 19:27:49(UTC)
C track signals (Digital)
by joyofmarklin 31/05/2024 19:46:52(UTC)
Marklin Semaphore Analog Signals (H0-scale)
by MALAVIKA 30/05/2024 14:45:23(UTC)
Automatic signals and braking without CS3 (Digital)
by intveltr 21/05/2024 02:48:31(UTC)
Connection of Fleischmann Signals to Märklin Systems (H0-scale)
by Eddie7979 18/05/2024 03:24:27(UTC)
Question about Marklin Semaphore Signals (H0-scale)
by WetterauSüd 13/05/2024 05:01:18(UTC)
switching Märklin Semaphore wingsignals with INFRARED gates (H0-scale)
by Holz1 25/04/2024 14:24:55(UTC)
Can Marklin signals work with the c-track from Trix? (General MRR)
by Sniklz 25/01/2024 23:35:50(UTC)
Light Signals (Track plans)
by PhilipS 04/01/2024 23:09:23(UTC)
Working with Marklin M track signals (General MRR)
by tandrschaefer 03/01/2024 21:41:00(UTC)
76442 braking module and 7649x signals (H0-scale)
by fabstar68 26/12/2023 23:44:25(UTC)
Set signal read after train passes with 7649x signals (H0-scale)
by fabstar68 26/12/2023 01:02:24(UTC)
New layout with C & K track. Will older M signals work? (Digital)
by matiSon 23/11/2023 02:53:09(UTC)
M84 Decoder & Signals (H0-scale)
by Eddie7979 18/10/2023 02:57:41(UTC)
Signals on bridges (Digital)
by Mille 27/08/2023 12:42:46(UTC)
viessmann signals multiplexer (Digital)
by Alfred Bugeja 20/08/2023 09:22:45(UTC)
where to put signals (H0-scale)
by heinrichhess 28/07/2023 21:39:03(UTC)
Use of Signals instead of Stop Markers in Train Controller (Model railroad software)
by garben 19/05/2023 20:18:57(UTC)
Question about Marklin signals (Digital)
by MegaExo 14/03/2023 18:58:43(UTC)
signals with yellow light (Digital)
by Mille 06/02/2023 04:15:35(UTC)
Signals and Ecos (Digital)
by cintrans 22/01/2023 14:06:59(UTC)
Wiring up Hobby signals without decoder or 72751 box. (H0-scale)
by Kaspar 24/11/2022 15:30:49(UTC)
How to mount analog signals to table? (H0-scale)
by Brian_BR96 06/10/2022 02:44:03(UTC)
Programming 763xx signals with CS3 help. (Digital)
by luckas 26/08/2022 15:57:31(UTC)
What do you control yours turnout and signals? (Digital)
by Goofy 11/07/2022 08:35:18(UTC)
Requirements and wiring for 'cosmetic only' signals (Model railroad software)
by luckas 10/06/2022 17:06:17(UTC)
New Marklin Digital Signals, any Online Primers or Guides? (Digital)
by 5HorizonsRR 29/05/2022 21:50:03(UTC)
Vintage signals, digital power and led bulbs (Model railroad wiring)
by BenP 08/05/2022 00:14:22(UTC)
Viessmann Regular or Multiplexer signals (in a computer controlled layout) (Digital)
by pmgsr 24/04/2022 21:21:35(UTC)
Circuit Track - HO K Track Configuration with Signals (H0-scale)
by rfeist 09/04/2022 20:58:07(UTC)
Cosmetic signals for CS3 (General MRR)
by Pasquiles 07/04/2022 23:16:09(UTC)
Advanced signals (General MRR)
by Thewolf 09/12/2021 04:01:46(UTC)
Signals in storage yard (Prototype)
by DaleSchultz 02/08/2021 00:05:41(UTC)
This page was generated in 0.474 seconds.
