Offline Agrawal
#1 Posted : 22 April 2019 12:29:18(UTC)
Agrawal
India
hello,
I purchased new Marklin 72751 control box for connecting Signal 74380/74391 for my C track and as advised by Marklin also purchased 66360 trafo. which according to them is must for safety reason and should be used for connecting new 72751 and signals 74380 series.
I also bought 194548 . The extension cable 71054 as suggested by Marklin was also bought..
However no where could find a combined sketch for connection and installation of all above.
earlier I had control box 72750 which was so easy to install and connect with my existing operating trafo (6647) etc but NOW with 72751 things are complicated and Marklin has not provided any sketch for connections.
Can i get help from the learned/experienced Marklin community with a detailed sketch .
thanks 1 user liked this useful post by Agrawal
#2 Posted : 23 April 2019 01:42:55(UTC)
Hi Agrawal,
I had the same problem, and received this information from helful people on the forum.
Instead of 60061, you use 66360.
I will send PDF instructions by email. It may be available direct from the Maerklin website.
#3 Posted : 23 April 2019 01:49:15(UTC)
You might try this link to the PDF.
72751 instructions
Offline Agrawal
#4 Posted : 23 April 2019 05:08:20(UTC)
Agrawal
India
Thanx for sketch. I hv it. But problem is extention wire sold by Marklin .one end fits 757251 but other end for 194548 does not as the other end of wire is incompatible. It has two clips while need only one. Why Marklin now so unconcerned and selling incompatible items?
This page was generated in 0.390 seconds.
