Offline dadboy12345
#1 Posted : 10 March 2019 17:08:02(UTC)
dadboy12345
I have a CS2 with the latest firmware and software (4.2.8(4) & 5.1). I am thinking of buying
Traincontroller 9 (gold) and running it from with a PC with windows 10. I have been testing it for the past couple of weeks.
Everything seems to work fine (S88, contact & circuit tracks, engines, regular turnouts, etc.), except my Marklin 3-way switches, and 3 (76493)
& 4 (76494) aspect signals. The 3-way turnout will either go straight or right, but not left. With 76494, I was able to get the two
aspects red-red and green, but not the other two. I believe that Traincontoller does not recognize the 2nd address for the signals or the 3-way switch.
The 2-way turnout and double slip switches work fine (they have only 1 address).
The signals & the 3-way switch work fine when I just use CS2 to operate them. Doe anybody have any ideas? Thanks.
Offline blid
#2 Posted : 10 March 2019 22:24:49(UTC)
blid
The default address order in TC is Right followed by Left. You have to change the red and green blobs in the turnout property. Top is 2 green for straight. Middle green – red for right. Bottom red – green for left.
I have not had any problems with 3 and 4 aspect signals.
In the early days there was restrictions for double address items but I don't think there is now. Anyway, all my double address items start with an odd number.
#3 Posted : 10 March 2019 23:41:21(UTC)
Might depend on the controller but I think the first address must be an odd number.
Offline dadboy12345
#4 Posted : 11 March 2019 00:56:22(UTC)
dadboy12345
I finally got it all of them corrected. It all depended on setting red, green and no color sequences properly to get the signals correct. I got the sequence for the 3-way turnout correct, by hooking a 3-way turnout to manual switch box and seeing how it worked.
This page was generated in 0.356 seconds.
