Offline Elsleuth1
#1 Posted : 14 February 2019 01:58:16(UTC)
Elsleuth1
I have a shuttle route which has run well with various locomotives and passenger cars for the last two months. Today I received an AC H0 DCC-Sound-Decoder AM0303 Schienenbus which I entered into the CS2 and tested it out. Sound, direction, speed all work fine except the lights blink. In any case I placed the rail bus on my shuttle route and programmed it using the CS2 shuttle commands. It doesn't stop at either end. The S88's dots at both ends do turn orange when the rail bus is present but the rail bus doesn't stop. The sensors seem to be working. I tested the wheels which are not insulated. Any ideas are appreciated.
Offline Harvey
#2 Posted : 14 February 2019 04:37:48(UTC)
Harvey
Elsleuth1
Likely my comments do not address your problem - I use 3 rail. I recently had issues with my L88 recognizing sensors and then, when that issue was resolved my shuttle stopped working. That has now been resolved. On the shuttle, I use a circuit track to activate the shuttle code. I believe a contact track would be what most people use. The problems I had were 1) the L88 was not set up correctly (see recent topic under digital). I needed to set up the L88 to single (not matrix) and at the bottom of the screen in setup, set the rows and columns to 0. Then, I had to connect the rail to the inverted T (with brown wire) on the L88.
One other thought - is your shuttle route programmed to a specific locomotive or to any locomotive. The Marklin digital news letter has some articles on this topic and my understanding is that it is not possible at this time to write code in the CS2 to apply to a general locomotive. Others can comment on this.
Hope this helps
Harvey
Adding sounds to a Shuttle route using a CS2 (Digital)
by Elsleuth1 29/06/2021 21:56:13(UTC)
Programming a shuttle route (Digital)
by Harvey 12/02/2019 17:38:42(UTC)
Shuttle Route issue (H0-scale)
by JoeB 14/01/2019 04:10:14(UTC)
Simple Shuttle Route (Digital)
by gharris198 28/04/2013 22:16:09(UTC)
Shuttle routes with the new 60214 (H0-scale)
by loegerk 25/07/2011 02:54:52(UTC)
Shuttle routes in CS2 (Digital)
by kgsjoqvist 20/10/2010 18:49:37(UTC)
This page was generated in 0.493 seconds.
