#1 Posted : 30 January 2019 17:00:50(UTC)
I have been using a standard shaver type plug for my two pin CS3 and CS2 but I have found that these do not last long with the fuse going. Is there a better type of converter with say a three amp fuse. I do not intend to cut off the plug and fit a three pin.
By now you will have realised I am not an electrician.
Offline twmarklinfan
#2 Posted : 30 January 2019 17:13:09(UTC)
twmarklinfan
I use a standard Europe/uk travel adapter and given we are all on 230v this has no problems. Boots,Smiths etc have them.
In fact I have the travel adapter plugged into the wall sockets and I plug into that a power block that I bought in Germany and into that are plugged my transformers etc with their two pin plugs.
thanks 1 user liked this useful post by twmarklinfan
Offline LongHairedDavid
#3 Posted : 30 January 2019 18:38:32(UTC)
LongHairedDavid
I did a search on Amazon for continental 4 way sockets and found this. Not ideal but would accept up to three continental two pin plugs.
https://amzn.to/2MIcIRO
Described as:
Power Strips with USB ports 3 Way Outlets 6 USB Ports Surge Protection Power Strip Universal Power Socket with 2 Meter Bold Extension cord With Fuse and Shutter Extension Lead
So it has three flat continental sockets plus some USBs.
David
Long Haired David
AKA David Pennington
A mystified Maerklin Newbie
thanks 1 user liked this useful post by LongHairedDavid
#4 Posted : 30 January 2019 20:21:52(UTC)
You can buy UK style plugs that clip onto EU style plugs. I have some around here, I'll try and take a photo later.
#5 Posted : 30 January 2019 21:06:55(UTC)
Why not just buy some 3 Amp fuses and use them in your shaver plugs?
If they are 5x20mm, you can buy 20 pieces for 0,99£, delivery included. BigGrin
https://www.ebay.co.uk/i...98f56:g:7cIAAOSwX6Rb21zO
#6 Posted : 30 January 2019 23:04:27(UTC)
Hi Per. I have some 5 amp fuses but they are bigger than the 1 amp ones and dont fit a standard shaver plug.
Its not a major problem but have had to replace three 1 amp fuses in ther past few months. Maybe a surge in power at times.
Just wondering what others used.
#7 Posted : 31 January 2019 09:30:00(UTC)
Hi Per.I have some 5 amp fuses but they are bigger than the 1 amp ones and dont fit a standard shaver plug.
Please measure the fuses sitting in your shaver plugs and we'll find the right ones for you Cool
Offline Michael4
#8 Posted : 31 January 2019 10:40:20(UTC)
Michael4
Views messages in topic : 705
I am not an electrician either but what stops you from cutting off the plugs and switching to UK?
Surely this is electrically better/simpler than adaptors?
#9 Posted : 31 January 2019 15:17:15(UTC)
I use these adaptors, it is a lot easier than clipping the plug off and rewiring.
Makes a real neat job without the hassle.
A number of alternatives are available as well.
#10 Posted : 31 January 2019 15:26:50(UTC)
Thanks guys. I have meanwhile replaced the 1 amp fuses with the same and will order the plug as suggested by Alan.
Cutting the plug and connecting to a UK three pin is not advised I am told by an Electrician although no idea why.
I understand that in the future Europe will need to supply electrical goods with the correct three pin plug.
Thanks again to all who have responded.
Dave.
#11 Posted : 31 January 2019 15:59:23(UTC)
Don't worry David; I'm a electrician too, and I also don't understand why LOL
Edit: Maybe he's thinking of warranty ???
We do it quite often when we take power-tools from Europe to UK Cool
#12 Posted : 31 January 2019 16:29:02(UTC)
These days I use these adaptors:
They are very solid mechanically and a much simpler solution than cutting off the plug and re-wiring.
They are also the best solution for a "wall-wart" type power supply like the one for the MS2
#13 Posted : 31 January 2019 17:31:27(UTC)
Dave.
Dave,
Just check I did pick the correct one (I just selected the first item in the second link) for the plug you have. The one I photographed I got from lying around that weren't wanted.
#14 Posted : 31 January 2019 21:22:41(UTC)
Dave.
Dave,
Thanks Alan. The one in the pic is 13amp so will buy one with probably 3 amp. Looks good though.
#15 Posted : 31 January 2019 21:49:52(UTC)
I'm in the US and running at 120v of course, so when I first got my starter set I dug out my old transformer from the 1980's that we used in Germany to convert the 220v line voltage down to 110v. The simplicity of a transformer is it works in reverse too, so it was simple to rewire the inside and voila, I've got 110v in producing 220v out. But none of that pertains to your issue. This following bit may help though.
As I didn't want to get a bunch of transformers for every 220v item I needed to plug in, I purchased a German power strip from Amazon.de. Then I only had to convert ONE plug on the power strip and could directly plug in all of the German plugged 220v items into that.
So if you get a German power strip, solve that plug problem once, you'll at least have many slots to plug into going forward.
https://www.amazon.de/Br...amp;keywords=power+strip
You just need to convert this strip's plug into a UK plug.
thanks 4 users liked this useful post by Minok
#16 Posted : 02 February 2019 16:46:01(UTC)
The UK is not part of Europe ? Really ?
Originally Posted by: twmarklinfan Go to Quoted Post
I use a standard Europe/uk travel adapter...
...when we take power-tools from Europe to UK...
#17 Posted : 02 February 2019 19:09:06(UTC)
Well, we are currently trying very hard not to be ... BigGrin BigGrin BigGrin Confused
I don't know why we are trying to Brexit, I would prefer to stay in Europe ... Crying
Offline ChrisWV10
#18 Posted : 02 February 2019 20:12:21(UTC)
ChrisWV10
thanks 1 user liked this useful post by ChrisWV10
#19 Posted : 02 February 2019 20:19:23(UTC)
Well, geographically you always will.
#20 Posted : 03 February 2019 11:38:54(UTC)
There is Europe the geographical continent, Europe the land mass, and Europe the political countries who are part of a Union (The EU).
Britain is part of the first, not part of the second, and at the moment (but half-heartedly) part of the third. Because of its island status Britain will always "feel" a little bit apart from the rest of the continent.
#21 Posted : 03 February 2019 12:54:36(UTC)
To be clear I said that Europe (including the UK) when supplying goods that need a plug this will require to be three pin. This includes electrical goods made in the UK as being part of Europe.
I am grateful for the assistance with a suitable adapter but the thread has nothing to do with the UK being in or out of the EU but only for goods being manufactured outside the UK.
Ray the UK will ensure that Spain does meddle with your Gibraltar which the appear to want to do.
Anyway thanks to all for the plug comments.
#22 Posted : 03 February 2019 23:08:33(UTC)
Thank you all. When I was (very) young, I was taught that I should say Great Britain instead of England when referring to what became later known as United Kingdom. I was eager to do so in order to be precise, respectful and politically correct. So, in return I would appreciate equal treatment when it comes to distinguish between the European Union and Europe (or the European continent).
Cheerio fellows, and I really love you and your island(s) and territories, honestly.
:o)
#23 Posted : 04 February 2019 08:18:43(UTC)
And why does this matter in this context ?
Not only the UK but also Switzerland (continental Europe, not EU but EFTA member) and Italy (continental and "insular" Europe and EU member) have special plug standards:
https://www.worldstandar...g-types-map/?location=ch
I learnt this the hard way when once buying an electrical appliance in Switzerland which I could not plug into the wall outlet in Germany.
#24 Posted : 04 February 2019 10:30:03(UTC)
:o)
There is a technical difference between Great Britain and the United Kingdom. Great Britain consists of England, Scotland and Wales. United Kingdom consists of Great Britain plus Northern Ireland. However, despite this difference the two do tend to be used interchangeably.
#25 Posted : 04 February 2019 10:42:46(UTC)
#26 Posted : 04 February 2019 12:00:11(UTC)
Furthermore, the UK and Ireland are sharing the same plug standard. How about the Isle of Man, the Channel islands, Gibraltar, Akrotiri and Dhekelia (just concentrating on Europe here)?
#27 Posted : 04 February 2019 13:55:34(UTC)
Gibraltar definitely has UK standard plug. I believe also the Isle of Man and the Channel Islands.
Not sure about Cyprus...
Offline Rwill
#28 Posted : 04 February 2019 16:31:40(UTC)
Rwill
Vaguely thinking of moving house -went to see a prospect "in need of some modernisation" and was surprised to see the three types of round plugs and sockets still in use. WAs even more surprised that you can still buy them:
www.tlc-direct.co.uk/Mai...74f619c7091b00542df5896d
Our present house is not exactly "state of the art". Needed to buy a card bobbin of the three types of fuse wire. Went to our local little hardware shop and nervously asked "don't suppose you can still get these can you?". He smiled and said "actually its one of my best selling items"
This page was generated in 0.675 seconds.
