Offline CCS800KrokHunter3
#1 Posted : 09 January 2019 15:18:49(UTC)
CCS800KrokHunter3
Hi Marklin Friends,
I came across this on eBay-DE and was intrigued. Certainly a fairly common item but the box caught my eye. It has a correct early "two child faces" label for the early versions (usually pre-1937 or so). However it has a pink Marklin label that I haven't seen before. On locomotive boxes this would typically be a "20 V" label but here is the term "MARKLIN" ... has anyone seen this before? It is perhaps a replica label that was added?
https://rover.ebay.com/r...hcNRbT%3Ark%3A1%3Apf%3A0
The box and label look original, with the perforation exactly as Marklin did it during that time frame, but that pink label does not seem familiar to me.
All the best
Paul
thanks 2 users liked this useful post by CCS800KrokHunter3
#2 Posted : 10 January 2019 05:17:42(UTC)
Hi Paul, For some reason I'm sure I've seen a label like that before but can't recall where, or it might just be similar.
Will be interesting what other examples are bound to come out now you've raised it.
Edited by user 10 January 2019 11:35:17(UTC)  | Reason: Not specified
#3 Posted : 10 January 2019 09:59:51(UTC)
Using Google, I found an almost similar label: http://uykmje.biz/M%C3%A...V-Spur-312248334134.html
#4 Posted : 11 January 2019 14:26:25(UTC)
CCS800KrokHunter3
Hi Per,
Thanks for the reply and good find!
Here's the direct link:
https://www.ebay.de/itm/...d=p2047675.m43663.l44720
That TWE appears to be from the same time period around 1935 so that is a very good clue!
Paul
This page was generated in 0.247 seconds.
