Offline Nikolas
#1 Posted : 08 January 2019 20:59:30(UTC)
Nikolas
In the memori blue window, when I am programming an itinerary if I select the locomotives functions I cannot see the locomotives function icons as the bar where they should be is covered.
How can I change the position of the bar that is covering the locomotives function icons?
Thanks for answering
#2 Posted : 08 January 2019 22:26:28(UTC)
Hi Nikolas
Welcome to the forum.
Assuming you are programming itineraries on a CS2, when seleting a locomotive function (usually by first selecting a loco (through "CONTROL" Tab or pressing the loco button (near one of the speed knob), then you push the selected function.
When finished programming the loco's functions, you return to the "MEMORY" Tab (which is still blue because you are editing.
Then you finish your edition by saving (vertical blue arrow) or by saying OK (the green Tick symbol).
I hope I understood correctly your question
#3 Posted : 08 January 2019 22:42:42(UTC)
Hi Nikolas,
Welcome to the forum.Smile
Nikolas (Digital)
by Nikolas 02/04/2020 11:39:25(UTC)
Nikolas (Digital)
by Nikolas 27/03/2019 21:49:37(UTC)
Nikolas (Digital)
by Nikolas 05/03/2019 16:58:20(UTC)
Nikolas (Digital)
by Nikolas 12/02/2019 21:53:48(UTC)
