Offline analogmike
#1 Posted : 21 July 2018 02:35:12(UTC)
analogmike
Drool
thanks 6 users liked this useful post by analogmike
Offline Tom Jessop
#2 Posted : 21 July 2018 04:28:34(UTC)
Tom Jessop
I have seen this close up when I was a Loco driver before I retired , the actual lathe work was quickly done but aligning the wheels to the machine takes at least twice as long . I am a bit surprised that no coolant was used on the cutting bars which do the hard work on each wheel . We also had a weighbridge which used the deflection of the rail when a engine or carriage was positioned in the position between 2 support pads . Also a wheel analyser was used on main line tracks which not only checked for flat spots on wheels as seen in this video but also had heat detectors & audio devices which listened for faulty bearings . The heat detector had problems when a steam engine passed over it & gave false readings to a computer which then gave an alarm indicating bad bearings requiring the train to stop & engine crew examine the wheel concerned .
Cheers Tom in Oz .
thanks 2 users liked this useful post by Tom Jessop
Offline analogmike
#3 Posted : 21 July 2018 14:10:43(UTC)
analogmike
Cheers Tom in Oz .
I believe the coolant was kept off for the video. I wonder if the tires would get so hot from the cutting process as to cause them to shift due to the lack of coolant? Probably not.
01-202 has got to be one of the most beautifully restored Loks in existence.
Mikey
This page was generated in 0.213 seconds.
