Offline FV1974
#1 Posted : 25 March 2018 22:49:15(UTC)
FV1974
I am building an M track layout on a wooden baseboard. I just had my first trial run and the trains make quite some noise. Would I be better off putting cork on the table?
Or do you guys use other material to lower the noise levels?
How easy would it be to paint, landscape, glue soil/grass/foam, etc... on cork instead of wood?
Frederic
Offline Michael4
#2 Posted : 25 March 2018 23:42:56(UTC)
Michael4
I have used a layer of 3mm high density closed cell foam. Others use all sorts of different coverings. There is lots of info on this forum about baseboards, noise and M track, using the search function will help.
Offline kweekalot
#3 Posted : 26 March 2018 00:12:05(UTC)
kweekalot
Hello Frederic,
Marklin made for her M track these rubber '7171' sound mufflers (Gummi-Schalldämpfer).
These are pretty effective and reduce noise by 50%.
I have used them on my 3600 track layouts, see pictures.
Marco
#4 Posted : 26 March 2018 00:42:40(UTC)
The noise is part of the character of m-track.. What also helps is a good quality (e.g. 18mm dressed pine) base for them to run on.. I used Marco's solution some years ago, but it made the layout too quiet. To each their own I suppose.. Smile
MrB32
#5 Posted : 26 March 2018 01:58:59(UTC)
Martin ( a forum user) did a nice video on this topic.
Offline FV1974
#6 Posted : 26 March 2018 10:37:47(UTC)
FV1974
Thank you all. The felt option as seen on Martin's forum sounds like a good option. Will look into it.
Offline hennabm
#7 Posted : 27 March 2018 18:26:26(UTC)
hennabm
Hi all
I'm with Adrian on this and my exhibition layout is M track straight onto the wood. It makes lots of lovely M track noise.Cool
However if I were to build/run something in the house I may have to consider some reduction. Using the proper M rubber strips does a good job, if you can find enough from ebay.
Otherwise the felt is also a good option.
1957 - 1985 era
What's digital?
Offline sudibarba
#8 Posted : 29 March 2018 05:47:22(UTC)
sudibarba
I run C track now but in my M track days I used to buy foam track bed and cut it to fit. The fewer the screws you put through to the plywood the
better in reducing the sound. The screws transmitt a lot of the noise.
I even cut foam pieces to go into each section. I love M track and have kept all my old stuff. I plan to do another layer above my C track with it if
I live long enough. Got enough troubles with the CS3 and decoder addresses right now so expansion is not an option now.
Eric
This page was generated in 0.448 seconds.
