Offline ae66green
#1 Posted : 06 February 2018 18:40:41(UTC)
ae66green
I am using the M84 to control the hobby signal and I know that the CV38 can be changed to control the brightness of the signal. I have configured the M84 in MFX mode under my CS2, and it would only display the first 6 CV under that mode (it could not show all the CV under MM or MFX mode). If I want to change the CV38, I know that the M84 must be set to DCC mode. Since my M84 is currently in MFX mode, how do I change it to DCC mode ? Do I need to set it up again as a new device in DCC mode in the CS2 so that I can change the CV38? If it need to set up again as DCC mode, should I use a new address for the M84 so that it would not conflict to its current address setting in the CS2? What should be the steps to achieve that purpose to access to CV38?
Offline TEEWolf
#2 Posted : 06 February 2018 23:18:53(UTC)
First have a look inside the manual:
https://www.ajckids.com/...arklin/60841_betrieb.pdf
This is in English too. Another source is this article:
https://www.maerklin.de/...3_Digital_MM_2014_02.pdf
translator software: https://www.deepl.com/translator
Just for your information:
https://www.maerklin.de/...5_Digital_MM_2014_04.pdf
For your convenience I translated with the deepl translator the following passage from page 28 of the Maerklin Magazine 02-2014, but it is the third episode of these article series.
"How to program effects
In order to achieve the desired effects per
to be able to program, we need
a system that uses our decoder via
address the DCC format. The
Central Station 60215 is the same for this.
as the Mobile Station 60653.
If the decoder is normally set via
the MM2 format must be switched, then
now to switch on the corresponding
Effects of the decoder changed to DCC
will be. With the same address, simply
the switch 10 (0) is set to "On".
Important: At the Mobile Station and
of course, the Central Station must also be equipped with
the data format for
the switching of the
corresponding magnet articles on DCC
must be converted. These DCC-improvements
programming also works by the way
during operation (POM).
Translated with www.DeepL.com/Translator
All 5 articles episodes about the new decoders m83 and m84 you find here (sorry all in German only)
https://www.maerklin.de/...men-specials-und-serien/
Note:
Meanwhile I was informed that you cannot achieve this side via the English homepage of Maerklin. You first must switch to the German homepage version to go there.
This page was generated in 0.197 seconds.
