#1 Posted : 20 January 2018 08:30:17(UTC)
Is there possible to shop protective paint for the K tracks under frame?
I want to spray paint the tin to avoid rust when i add water glue on the ballast.
I did tested with acrylic spray paint and used water glue on the ballast.
So far not see any rust.
#2 Posted : 21 January 2018 07:51:55(UTC)
I did bought an spray metal primer paint and this product are excellent to protect tin plate like Märklin K-tracks.
It works really good by spray thin and don´t need spray too much.
#3 Posted : 21 January 2018 07:54:23(UTC)
I forgot to write...it takes about 12 hours to let metal primer dry.
#4 Posted : 21 January 2018 08:06:18(UTC)
I think you should measure your track with an Ohm-meter now; because to me this looks like a short-circuit between pukos and rails.
#5 Posted : 21 January 2018 08:13:41(UTC)
I don´t understand why you did write like this.
It´s paint and yes i did tested and no short-circuit.
It´s paint to protect tin from rust.
#6 Posted : 21 January 2018 08:22:31(UTC)
All zinc sprays I know off are electrical conductive; I just wanted to warn you.
#7 Posted : 21 January 2018 10:28:44(UTC)
It looks to me that the spray has only put a coat onto the underside of the metal base.
When you use water-based glue for your ballast, the moisture will possibly get between the base metal and the sleepers - I suspect that area is not protected because the zinc spray would not get into that gap.
Attached are images showing the base removed from a double-slip (for example), for full protection you would need to remove the metal base completely and spray both sides and I can tell you (from experience), you do not want to be doing that to every track piece! OhMyGod
You will reduce the chances of rust for certain, and perhaps long enough for the expected life of your layout but do not be surprised to still see rust develop where the zinc spray cannot reach.
Good luck anyway Smile
Steve
#8 Posted : 21 January 2018 14:22:08(UTC)
I did tested another way.
Did sprayed with Tamiya redbrown on both side of the track.
Later did sealed flat clear TS-80 under frame of the track.
This to protect the color contact with the water glue.
#9 Posted : 21 January 2018 14:47:29(UTC)
Steve
(snip images)
You have right!
To protect the tin from rust i must spray both side of it.
This is not for me.
Edited by moderator 22 January 2018 00:57:09(UTC)  | Reason: Remove repeated images
#10 Posted : 22 January 2018 01:00:30(UTC)
Steve
(snip images)
You have right!
This is not for me.
Just thinking about this some more, is there a water-based rust-inhibitor? - surely in this modern world there must be.
I'm thinking something along the lines of an additive that you would put into your car cooling system - you can get 'anti-freeze', but for climates where this is not a problem you still need to protect against corrosion. Most modern engines are alloy of course but older engines are cast-iron so the car enthusiasts must use something - you just need to find something that will be compatible with glue??
Then you don't need to worry about protecting the track.
Something to think about ThumpUp
Offline Legless
#11 Posted : 22 January 2018 10:12:40(UTC)
Legless
The primer you have is cold gal or zinc enriched primer.
The zinc is the slave metal that corrodes before the normal metal and zinc conducts electricial currents.
As for rust converters, this is ferric acid and that as the name says converts the rust over. Note do not use both together as the converter will attack both, the zinc first then the metal.
If you use fish oil underneath the track that will form a barrier that will stop the moisture from the PVA attacking the metal but the down side is that it tasked a long time to dry. I haven’t tried a conductivity test while still wet. (I can do One if asked).
Legless
#12 Posted : 02 February 2018 14:03:13(UTC)
As I have already written so many times;
Wet the ballast with a spray of cleaning alcohol.
I know that the glue should till be diluted with water (and a little soap), but the total WETTING of everything with an alcohol-mist doesnt damage the tracks.
That, and maintating the humidity of the train-room on about 55% helps prevent ANY rust.
Has done so far in my wet and cold basement for the last 12 years!
PS: The 55% humidity is by the book. In reality I just keep it around 65%, as the room otherwise is unfomfortable to be in, and static electricity can sometimes be generated.
This page was generated in 0.479 seconds.
