Offline baggio
#1 Posted : 19 December 2017 04:06:29(UTC)
baggio
I saw on the Marklin website a very nice red loco with lots of sounds at a decent price (220 Euros); catalogue no. 36630.
What puzzles me is that it has a DCC decoder and MFX capability.
Why?
I mean what is the point of having DCC when you already have MFX?
Am I missing something?
Here is the link to the website:
New loco with DCC and MFX
#2 Posted : 19 December 2017 04:37:22(UTC)
Reasons might include ...
- only needing to produce one decoder, not two, which would mean duplication with subtle difference of packaging instructions etc.
- - equals greater market penetration.
- - future resale value
- not alienate user who have a DCC only or MFx only or MM/Fx only controller
- - includes those who wish to disable a protocol in their controller
- provide those same users the opportunity to take their loco to a colleagues/club layout using the alternate protocol
thanks 5 users liked this useful post by clapcott
Offline baggio
#3 Posted : 19 December 2017 06:24:46(UTC)
baggio
But this is an HO scale 3-rail loco.
Up until VERY recently, I have not seen an HO 3 rail loco that runs on DCC. This is one of them.
US HO locos run on DCC, but they are 2-rail. The same with Roco and others that are primarily 2-rail.
From what I can gather from what you said, Peter, this DCC capability on a Marklin loco is simply to cater to 2-rail users who wish to convert to 3-rail. Is that it?
Somehow, I doubt too many 2-rail users care to go 3-rail. Normally, it's the 3-rail users who may like some specific 2-rail locos and want to convert them to 3-rail, not the other way around.
In my book, if the loco is HO and intended to be used on a 3-rail platform, adding DCC to the decoder is a waste of money. Better to add even some simple sounds instead with a cheap speaker.
That is how I see it, anyway.
Offline applor
#4 Posted : 19 December 2017 06:46:23(UTC)
applor
I disagree with this, I have been using DCC for years on my Marklin layout - since the release of the MS2, though I have wanted it long before then.
This is because the majority of ESU decoders (ie. lokpilot/loksound 3.0/3.5) used in other manufacturers locos (ie. Roco, Liliput) did not support MFX, only DCC or MM.
While ESU did release the v3.0 M4 decoder which supported MFX, it came later and was not the included decoder with Roco loks.
You could previously use MM but it limited you to 27 speed steps while DCC supports 127 - a huge improvement.
Marklin including DCC support costs them nothing and gives users the flexibility of what protocol they want as well as allowing for universal support of DC or AC systems.
Offline Danlake
#5 Posted : 19 December 2017 06:57:31(UTC)
Danlake
You have been a member since:: 03/08/2011(UTC)
Hi Baggio,
DCC does not mean 2 rails.
DCC is just the name for a decoder protocol.
Lots of users are running DCC on 3 rails with different controllers or even with Marklin controllers.
On most decoders you will find more configuration settings on a DCC protocol than when using Mfx protocol and some users don’t like the constant auto registration with Mfx protocol or issues auto registration in the first place.
Brgds Lasse
Offline Swimmer
#6 Posted : 19 December 2017 07:09:50(UTC)
Swimmer
Correct me if I am wrong. MFX is just a protocol used to set the Loco's Address Automatically depending if your controller supports MFX.
Basically what happens is when you place a new Loco on the track it communicates with the controller and checks if its default address is available, if it is then it uses the default address.
If the defualt address is already being used then it checks for the next available address and assigns it to the loco.
Carsten
Offline ktsolias
#7 Posted : 19 December 2017 08:21:59(UTC)
ktsolias
All the Märklin Decoders from 60942 and on are multi protocol DCC and mfx.
Many new locomotives like the TRAXX, VECTRON and other series are ready for 2 rail DC operation.
That means the wheels are of the DC type and the contacts are already there.
To converse a such loco from 3-rail to 2-rail is just a case of minutes.
Remove the center hot shoe and just change the connections of the red and brown cables with the circuit board. (Red right wheels, brown left wheels) and the loco is ready.
You can understand why they are do it this way.... Actually the Trix models are exactly the same etc.
About the same happens with ESU locos...
Costas
#8 Posted : 19 December 2017 08:24:58(UTC)
I am using DCC and three-rail since I bought my second Roco loco. DCC was around before mfx and it was used for three-rail too - by everybody except Märklin.
Märklin were indeed very late to include DCC in their three-rail locos, thus avoiding quite a bit of my money.
I do not use mfx on my layout. Sometimes I do not buy locos simply because they do not support DCC.
I do not need both protocols.
Good if the manufacturers offer all protocols they can - and let the customer decide what they use.
You are wrong: there are no default addresses with mfx and the controller will always assign a free address to any decoder.
mfx is a complete protocol that does everything; it is not just an extension to the MM protocol that assigns addresses.
With DCC locos have manually assigned addresses. RailCom+ can negotiate a free address automatically if the manually assigned address is already in use. RailCom+ is just an extension to DCC and only used to negotiate an address when needed.
All? After the introduction of the 60942 they continued to sell locos without DCC for years.
#9 Posted : 19 December 2017 18:44:52(UTC)
Well, i don't know where you have been for the last 18 months or so, but ALL the locos with Marklin msd3 and mld3 series decoders have both DCC and marklin protocols. This capability has been widely talked about on this list when these decoders were first announced.
Now not all marklin and Trix locos use these decoders, it is evident that the cheaper items use older design decoders that don't have DCC capability, but these have limited numbers of functions and can only do specific sounds, so as soon as a large number of functions is required and/or sounds other than simple ones wanted, then the latest series of decoders is required to meet requirements,
Offline baggio
#10 Posted : 19 December 2017 19:01:00(UTC)
baggio
Well, i don't know where you have been for the last 18 months or so...
Where have YOU been? Taking a course in manners, no doubt.
#11 Posted : 19 December 2017 19:55:31(UTC)
Now you get offended again, by people who tries to help you.
The same thing happened when you mixed the same things up 7 months ago:
https://www.marklin-user...d-stations-are-available
You keep making statements as if only your way of seeing things is the correct way, and after a while,
the other users here might use a bit stronger language to make you understand.
Somehow it seems like you don't want to understand.
#12 Posted : 19 December 2017 20:41:13(UTC)
My take, is Märklin realized finally they are hurting their own sales by insisting on MFX based protocol exclusively.
For those modelers that may want a 3 rail or even 2 rail (Märklin makes Trix after all), that have an existing controller such as one of the many DCC controller solutions, they can sell product to them by simply making that protocol available.
If I've got a Z21 or Digikeijs DR5000 controller, I'd then be able to still buy a Märklin product. Not everyone wants the cost of a CentralStation.
Its just a smart business move. Let the customer pick which protocol they use to communicate to their components - you want to sell components to whoever would want to buy them and not prevent purchases.
Offline baggio
#13 Posted : 19 December 2017 21:53:32(UTC)
baggio
I don't know why you decided to butt in; you would have been much better off to say nothing. Particularly because your own comments are offensive and you were not called upon to say anything.
At risk of stating the obvious:
1. No-one here has the right to offend anyone;
2. If you disagree with something, you are free to say so but without being offensive;
3. If a person makes a statement that you consider wrong (or for that matter, even if it is wrong), you do not have the right to reply in an offensive manner.
4. No-one has the obligation or duty to respond to any post but if you do so you must watch your manners and remember that you are not at a sports bar having a couple of beers but on a forum where a different decorum applies.
5. If you disagree with any of the above four points, then maybe you are on the forum for an ulterior purpose: you are a troll that wants to create conflict.
Thank you.
Offline baggio
#14 Posted : 19 December 2017 22:01:52(UTC)
baggio
Today I went to Mike's to buy my Christmas present. BigGrin
I happened to ask Mike what his price was on that very loco discussed above. I had no hope that it was available to purchase.
You guessed it: Mike had it and put it on his layout for me to see how it ran. Love
Now this loco is safely in my home under the tree waiting to be opened the evening of the 24th. ThumpUp BigGrin
(One thing is for sure, I will not use it in DCC - I much prefer MFX.)
Life is good.
thanks 3 users liked this useful post by baggio
Offline baggio
#15 Posted : 19 December 2017 22:30:31(UTC)
baggio
IfI've got a Z21 or Digikeijs DR5000 controller, I'd then be able to still buy a Märklin product.Not everyone wants the cost of a CentralStation.
But in the above case, would you not be running a 2-rail system? If so, then, why would you not look to Trix locos that are much the same as Marklin's but in 2-rails?
If your intention is to run a 3-rail system, why would you not buy Marklin gear?
Is there any other manufacturer out there that sells a wide variety of 3-rail locos that are better than Marklin's? I don't know of any.
For example, Roco does have some 3-rail locos, but are only a fraction of their 2-rail locos.
Offline michelvr
#16 Posted : 19 December 2017 23:29:15(UTC)
michelvr
Life is good.
I missed you at Mike's store today, was Christmas shopping in the morning.
#17 Posted : 19 December 2017 23:31:28(UTC)
Maybe other brands offer better details, or better decoders, or are more affordable, or the model is not available from Märklin.
There are many brands beyond Märklin and Roco that offer three-rail locos - and many of those come without mfx.
#18 Posted : 19 December 2017 23:31:48(UTC)
No, not necessarily! That's the whole point of the discussion, which you seem to have missed both in this thread and the one referred to by Per.
Both the DCC and mFX protocols, the controllers and locos that use them are agnostic to the type of track used to run them on. I'm not sure how much more clearer we can make this.
Your seeming befuddlement on the issue lead to Clapcott's 'What absolute rubbish' comment in the previous thread (which you took offense to), and it has lead to the comments made by Per and others. So please do not start to take offense at comments made by others who try to get you to see the light as it were. You've already got me close to locking this topic.
The BR187 loco you purchased is a great looking loco, and I want to get one myself. Because it has a decoder that operates on either DCC or mFX, it can run on 3 rail track with either of those protocols. Likewise, if you changed the pickups on the loco so that it would run on 2 rail, the loco would also run happily with either protocol (and also with MM if you were that way inclined).
If folks really wanted to, they could run a Z21 or Digikeijs DR5000 controller with 3 rail track.
So please do not get offended when folks try to point stuff out with what might seem to be stronger comments, they are trying to get you to understand even if it is causing them some increasing frustration. You should be glad that they are still trying to help you.
#19 Posted : 19 December 2017 23:32:11(UTC)
3. Attacking the person who made a statement that you consider wrong (or for that matter, even if it is wrong) does not give you the right to reply in an offensive manner.
Thank you.
0. Since you didn't exclude me in this topic, I think I'm free to answer just as everybody else.
00. I'm stating the obvious, why you get offended I don't know.
1. I'm not trying to offend anybody; i'm trying to tell you that you shouldn't be so easily offended, especially since you've been told the same things 7 months ago, you also got offended in that topic, without me writing a single word, and now you're starting all over.
2. That's what I did; but then you told me I would have been better off to say nothing. Are you trying to offend me??
3. I'm not attacking anybody; i'm trying to help you. Unfortunately it seems like you don't want help or don't want to understand, which I also wrote in my first reply.
4. You're trying to tell me when to write and what to write, and at the same time you're writing about manners. Try reading you own posts again.
5. Again, you write about manners, and now you're calling me a troll ??? This is too funny.
It might be hard for you to accept; but all my locos ( except one Hübner ) are Märklin, they all run 2-rail and I only use MM or MFX protocols.
And believe me, I didn't buy any of those locos to offend you.
Offline baggio
#20 Posted : 20 December 2017 00:11:43(UTC)
baggio
I wish you had told me you were planning on coming down. Sad
Next time, please call me so we can take a trip together. ThumpUp
Offline baggio
#21 Posted : 20 December 2017 00:24:39(UTC)
baggio
Purellum: The "you" in my post was a general "you" and not meant to apply to you necessarily.
It applies to anyone who feels he has the right to talk down to someone else simply because he thinks the other ones knows less than he does. A self-appointed "professor" in other words, without manners to boot.
If one does want to correct someone else, it's easy to do without being arrogant: Just stick to the facts and leave the editorial comments aside.
As for me, I will stick to my MS2 and MFX (that has never given me a problem) and the DCC to others. However, I also run 2-rail trains, in analogue. ThumpUp
#22 Posted : 20 December 2017 00:37:42(UTC)
Can you please explain how these "you"s don't apply to me ??
The above sentence was written just below a quote of my first reply in this tread.
If you haven't read it before, then please read GlennM's comments here:
https://www.marklin-user...attacks---very-concerned
#23 Posted : 20 December 2017 00:58:12(UTC)
Time to lock this thread, Baggio's response to Per notwithstanding.
This page was generated in 0.758 seconds.
