Offline strummer
#1 Posted : 30 November 2017 20:47:27(UTC)
strummer
If I may kind of go off into "left field" here for a moment...
I just have to put a shout out here for the Marklin wire product: it's got enough "substance" to be easy to work with, it solders nicely, and is very flexible.
I'm really liking it, and will be purchasing a lot more in the future, I'm sure.
Ok, that's all.
Mark in Oregon
thanks 1 user liked this useful post by strummer
Offline PMPeter
#2 Posted : 30 November 2017 21:21:50(UTC)
PMPeter
Probably an expensive way to go for small gauge wire. Considering you live in Oregon you probably have a Frys near you and can most likely get a similar gauge of stranded wire for a lot less per foot.
#3 Posted : 30 November 2017 21:31:31(UTC)
I am with Mark.. It is hard to get wire that feels good and solders well.. That Marklin stuff is very good quality..
Offline PMPeter
#4 Posted : 30 November 2017 22:08:00(UTC)
PMPeter
I'm not saying there is anything wrong with it, just commenting on his statement that he is going to buy a lot more. In that case there may be a less expensive alternative for just as good a quality wire and a greater selection of wire gauges. Frys is an electronics store chain only found in the US West coast states and since he lives in one of those it might be worth his while to check it out.
Whenever I get a chance to go down the US West coast I stop in at a Frys store and buy a years supply of wire and other electronic goodies to use on the train layout.
#5 Posted : 30 November 2017 22:42:33(UTC)
Marklin do not 'make' their own wire, they will be sourcing it from a specialist supplier and anyone purchasing this is only paying a middle-man markup.
Supplier to Marklin
Marklin to Dealer
Dealer to Customer
For an item like wire, you will definitely get more bang from your buck purchasing larger quantities by the roll from a wholesale wire supplier.
On the other hand, if you are stuck, and need a smaller amount to finish a section then the convenience of going to your local dealer and getting the branded product can same a lot of hassle - assuming of course you even have a dealer within reasonable distance.
#6 Posted : 30 November 2017 23:38:58(UTC)
The manufacturer is quote possibly Brawa, which has an extensive wire production plant, and markets at least three gauges of wire in multiple colours for MRR use.
I don't know who supplies the wire that Viessman markets, but that could also be Brawa.
Offline strummer
#7 Posted : 30 November 2017 23:50:54(UTC)
strummer
Well, whoever makes it, I like it very much... :)
Mark in Oregon
#8 Posted : 01 December 2017 00:52:21(UTC)
I only use orange wire from Spain., yellow wire from China, black wire from Russia, brown wire from Africa, blue wire from Australia, green wire from Amazon, white wire from Greenland, red wire from Japan.
thanks 6 users liked this useful post by river6109
#9 Posted : 01 December 2017 10:40:37(UTC)
Offline Henrik Schütz
#10 Posted : 11 December 2017 00:05:04(UTC)
Henrik Schütz
Nothing wrong with Brawa, but the Märklin wire is 0.19 mm and Brawa 0.14 mm .
Some times it makes a difference, usually not...
Henrik Schütz
thanks 1 user liked this useful post by Henrik Schütz
#11 Posted : 11 December 2017 03:28:48(UTC)
I've bought a lot of ESU (0.5mm) wire and this is very thin, its ok when you just connect wires and solder them but they don't like to be bend around a lot and they soon break off from their soldering point., lately I'm just using insulated copper wire especially when I add Led's to locos, they can be bend many times without breaking and being a single strand breaking off at the soldering point is more or less impossible.
I'm not concerned about the price more about the sturdiness and at the same time flexibility.
for my layout I buy 100m rolls of wire from Jaycar electronics for around A$ 10.00 a roll.
#12 Posted : 11 December 2017 03:31:33(UTC)
Henrik Schütz
I think we have to rectify the thickness of the wires its not 0.19mm or 0.14mm its 0.19mm² and 0.14mm² which makes a lot of difference. ESU wire is 0.5mm and this is very thin
#13 Posted : 11 December 2017 09:38:04(UTC)
I doubt that this is official marklin-users trademarked orange wire, which comes from Norway and Denmark.....
#14 Posted : 11 December 2017 17:51:49(UTC)
And he forgot to add #8 wire from right here in NZ! Galvanised colour only but can be painted.
Not easy to solder but works well twisted. A regular trackside accessory here.
This page was generated in 0.715 seconds.
