Offline Rwill
#1 Posted : 27 October 2017 13:25:26(UTC)
Rwill
I have seen this before, I thought it was a sticky, I have printed it out, I have tried to search, but now I need it again naturally I cant find it and I definitely cant remember.
How do I set up a 6021 to have more than Four (five) functions using a follow on address?
Offline manou
#2 Posted : 27 October 2017 13:50:15(UTC)
manou
Best Regards
Yannis
thanks 1 user liked this useful post by manou
Offline Rwill
#3 Posted : 27 October 2017 14:20:56(UTC)
Rwill
Thanks for the quick response but no!
Assume I have only a 6021 and no CS2
If we have a lok at address 56 we can get aux function plus function f1 -f4
Now there is a simple way of linking address 57 so we can get the next 4 functions of lok 56.
Its so simple but I cant remember it!
Offline manou
#4 Posted : 27 October 2017 14:50:57(UTC)
manou
Yes as far as i remember you have to program CV 75 with the desired address, in your case 57
Hope i am right
Yannis
Best Regards
Yannis
#5 Posted : 27 October 2017 14:51:23(UTC)
On the CU 6021 you can use the L and F keys to have speed knob and function/off control one address (e.g. 56) and have f1 through f4 control another address (e.g. 57).
See this post and scroll down to "Tip for Control Unit 6021":
http://blog.mailez.de/eb...unctions-with-mfx-locos/
Offline Rwill
#6 Posted : 27 October 2017 17:07:35(UTC)
Rwill
Thank you all for nudging me in the right direction
What I finally found was a paragraph from a post in 2011 from the other side of the world from the forums font of all knowledge :
QUOTE
To answer your question:
To program Locos with 6021
1) reset - stop + go
2) dial up number 80
3) stop
4) reverse + go - lights should flash
5) select parameter (e.g. 01 for address) - select reverse
6) dial value (lights should start flashing real fast) - select reverse
7) stop
8) go
9) test new setting
Common CV Settings
01 Address - value 01 - 80
03 Acceleration/Braking Delay - value 01 - 31
05 Max Speed - value 01 - 63
08 Reset - value 08
75 2nd loco address for decoders that support this feature
END QUOTE
Which is what I needed I couldn't remember the stop go lights flashing turn around and jump in the air things
The mission is now acomplished
This page was generated in 0.356 seconds.
