marklin-users.net community
| Forum
Home
Community Forum
Login
or
Register
Forum
Active Topics
Login
Register
OK
General topics
Digital
CS2 - 32 functions - Update v4.2.1
3 Pages
1
2
3
Go to Page...
Email this topic
LinkBack Topic URL
Retweet this Topic
Share Topic on Google+
Like this Topic
Share on Facebook
Digg this Topic
Reddit this Topic
Share on Tumblr
Watch this topic
Print this topic
» Normal
Threaded
Previous Topic
Next Topic
PMPeter
#101
Posted :
08 August 2017 05:16:24(UTC)
Retweet
I have not made any changes to the S88 wiring in a year. The return wire is connected to brown at the first module only.
I have no L88s and I only use my CS2 or my laptop with Rocrail to control the trains.
It works just fine until suddenly while a train is moving and crosses an S88 actuator the CS2 powers down and the stop bar lights up. Once that happens I can roll any car over a contact section or trigger a reed switch with a magnet and the CS2 stops. Only a reboot puts it back to normal.
This is similar to an observation I made initially that while nothing was in operation for quite a while the CS2 screen went blank, the stop bar lit up, and after a few minutes the control screen came on. This is also similar to JJB's comments about the strange behaviour of the stop bar lighting up.
This is just one buggy update.
User Profile
View All Posts by User
View Thanks
PMPeter
#102
Posted :
08 August 2017 19:13:33(UTC)
Retweet
Out of all of the issues I have encountered after this update, here is the status and frequency of occurrence:
- MFX logo appearing for all locomotives on the Control screen regardless if they are MFX or not -
occurred once
- After shutting down the CS2 with power still connected, clicking the Stop bar occasionally will not restart the CS2. All I get is an "@ something" message each time I click the Stop bar. I have to shut all the power off to get it to restart -
Occurred twice but has not reappeared for a few weeks
- The network IP address keeps changing even though I have the CS2 configured to manually set the IP address and network server address since I use Rocrail and need to keep the addresses fixed. Previously I only had this issue right after an update, but not consistently with every reboot/restart -
This occurs consistently after any short circuit that shuts down the CS2, any check for software update, any USB update
- The transformer issue mentioned previously by another member shows partial numbers only such as "600" instead of the full transformer number. Hard to select the correct trafo -
- CS2 screen blanking out, the Stop bar starts blinking for several minutes and the screen came back. No short circuit reboot, just a strange behaviour while nothing is operating or running -
occurred once
- When adding a new locomotive, I get a choice of 8 or 16 functions only. How would you select a 32 function configuration?
- Since this update I can no longer add any PNG icon files to the CS2 icon database using the network. Only possible using the USB method
- Loco speed suddenly jumps on the CS2 to a higher speed with no Rocrail control or manual intervention. -
Occurred 3 times
- Activation of any S88 contact causes the CS2 to Stop and the red light to come on -
Occurred twice
- MS2 requesting an update after every reboot of the CS2 -
Went away after about 5-6 CS2 reboots
User Profile
View Thanks
Posted :
08 August 2017 22:08:51(UTC)
Retweet
Do you have an mfx loco that has more than 16 functions? I believe it will only make more than 16 functions available for a loco that has 16 functions. I don't have a cs2 to check this out however.
User Profile
View Thanks
PMPeter
#104
Posted :
08 August 2017 22:17:54(UTC)
Retweet
No I don't. However, when I add a new locomotive and specify DCC protocol I would have assumed that I have selection capability of 32. All I get is a choice of 8 or 16.
User Profile
View Thanks
#105
Posted :
09 August 2017 04:26:13(UTC)
Retweet
... when I add a new locomotive and specify DCC protocol I would have assumed that I have selection capability of 32. All I get is a choice of 8 or 16.
For DCC, 29 functions are supported
After selecting DCC as the protocal you may choose 24 or 29
Comment (This aspect is possibly more of CS3 consideration as that controller expands in groups of 8)
* You do need to SAVE this base configration , and re-edit before the F0-15 button works (to show the F15 + function placeholders
1 user liked this useful post by clapcott
ilekrib
User Profile
View Thanks
PMPeter
#106
Posted :
09 August 2017 04:41:51(UTC)
Retweet
Well therein lies the problem. I don't get that choice as shown in your screenshot. When I click the pulldown I only get the choice of 8 and 16, no 24 or 29.
User Profile
View Thanks
PMPeter
#107
Posted :
09 August 2017 04:55:07(UTC)
Retweet
In light of all of the problems I am experiencing it is clear that my download did not go right even though the network upgrade said it was successful. If I don't even get a screen choice as shown by Clapcott for the 29 DCC functions my download obviously is missing something.
If I try to upgrade from the network I just get a confirmation that my CS2 is already updated.
Can I try to download the files and do another update using a USB or will that give me the same message? Also for the cs2update.md5 48B file this may be a stupid question but how do you download that file? When I click the download for that file all I get is a new screen with this displayed:
aee33a784bda0208d3f216ca6abed991 cs2update.img
Do I just copy that on to my USB?
User Profile
View Thanks
PMPeter
#108
Posted :
09 August 2017 16:09:51(UTC)
Retweet
I think you provided me with the answer. If I add a new DCC locomotive, initially I only get the choice of 8 or 16 functions. One I save this base configuration and go back to edit it, the 24 and 29 show up in the pulldown menu. I believe that is what you meant by you do need to SAVE this base configuration.
User Profile
View Thanks
anthpao
#109
Posted :
19 August 2017 08:44:24(UTC)
Retweet
I miss the English keyboard layout after the update, only German available.
Meaning no "y", no "-", etc.
Anyone else with this problem?
User Profile
View Thanks
midwestbls
#110
Posted :
29 December 2017 18:08:38(UTC)
Retweet
Originally Posted by: Alberto Pedrini
Updated this evening my second CS2, 60215, all has gone right
Tested the functions and the other options, all OK.
The connection with the CS2 software on computer OK too.
Here the screenshot
OK, I have to add to this thread because it has NOT been clear to me how to get to those extra 16 functions after the update to 4.2.1. Alberto's post was VERY helpful in showing me what I needed to get to ... First, some background that may help others just now trying to get their CS2 up to CS3 function functionality!
I did a hard-wire network update and it worked like a charm - as have past updates for me, no glitches Maybe 45-minutes total with the stops, starts, re-boots, etc. that others have mentioned with a reasonably well-documented process. After the update, before I made a new attempt as function access, I would re-boot - just in case.
I got out my previously-registered 2017 DB 103 Insider lok, placed on programming track and re-established mfx loks. It worked well as before, and now I could see the new F0-15 button on the CS2 screen, but tapping it did nothing; still stuck with only 16 functions, it didn't change to F16-31. I re-booted and went through reestablishing mfx loks with same result ... LOTS of careful re-reading of a number of less-than-specific threads - especially this one led me to try to this:
It's not just a matter of "re-registering" previously registered mfx loks, but rather you must DELETE (trash can icon) the lok from the registration screen and then re-register. I realize I may have missed a subtle semantic idea here, but the trash can icon DELETE the lok button step is critical after the software update and before you try to use loks with more than 16 functions.
After the delete and then re-registrations it all worked fine - screens looked just like Alberto's above! And I could tap on all the new sounds! YAY!
I don't currently have any additional digital items hooked up (L88/S88, etc.) so I can't comment on experience beyond getting loks re-registered for functions 17+.
I do share the ??? about why the physical buttons don't map to the second set of F16-31 where you have to tap on the sound icon itself, but I suppose IF you can remember what the F0-7 buttons control, you can then control essentially 24 functions from the 2nd F16-31 screen.
Finally, I LIKE the fact that the CS2 now starts up to "STOP" mode. Makes total sense to me ... how hard is it to tap the Stop button to get running?!
I hope this helps some others, and that I've helped clarify without being too redundant!
Happy Rails!
- Bill
3 users liked this useful post by midwestbls
Br01
MikeR
User Profile
View Thanks
Posted :
30 December 2017 00:55:35(UTC)
Retweet
Happy Rails!
- Bill
Not too redundant - just a nice summary of what using the updated CS2 software is like.
I have had the same experience with previously registered mfx locos not accessing the second 16 functions, but as you point out you just need to delete them and then let them register again. I agree that the initial state being "Stop" is a big improvement. No more wandering out of my train room for a beer when the CS is booting up and then wondering what those noises I am hearing are all about.
I am really pleased that Märklin updated the CS2 for the 16 new functions, particularly since it lets me wait just a bit longer before I get a CS3.
User Profile
View Thanks
Thewolf
#112
Posted :
30 December 2017 13:11:35(UTC)
Retweet
Happy Rails!
- Bill
I agree with all what you wrote
Happy New Year
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
User Profile
View Thanks
Posted :
30 December 2017 13:34:30(UTC)
Retweet
Yeah. My Intellibox already started in STOP mode before the first Central Station was delivered.
Less than two decades later Märklin follow that good example.
Well, with the IB the user can decide between STOP and GO after power-up. Maybe Märklin will follow this example too, and maybe also within two decades?!?!?
a high level of quality
, the
, and
absolute precision
. You will see that
in all of our products
User Profile
View Thanks
Thewolf
#114
Posted :
30 December 2017 13:42:49(UTC)
Retweet
Hi Tom
About your Intellibox, what she is doing before Marklin is logical...in his name there is the word '' intelli'' for intelligence
Thewolf
User Profile
View Thanks
#115
Posted :
31 December 2017 05:33:45(UTC)
Retweet
Any experience , especially on subtle semantics from translated documentation, is good.
And I would be guilty of glossing over this aspect as I am unaware of how you may "re-register" an mfx loco/decoder
without
deleting it.
To me the update information from
https://www.maerklin.de/...update_4_2_0_info-en.pdf
Important: If models with more than 16 functions have already been registered with the CS 2 before the update, they must be registered again after the update.
... implies the deletion of the loco in order to register it again.
I am presuming (?) that you might be alluding to the "Configure new" dialogue and the "Manually search for mfx locomotives" which is seen to do a scan.
Can you confirm ?
Also Marklin might be interested to know how you came to this interpretation, and how they might have better addressed any implied equivalence.
User Profile
View Thanks
jerdenberg
#116
Posted :
01 January 2018 13:58:03(UTC)
Retweet
My (second-hand) CS2 updated without a problem some time ago, but it is a pity that the cs2.exe program is still in its <2017 state (version 3.8.1), which prevents me from accessing the extra functions from Windows.
WWW
User Profile
View Thanks
3 Pages
1
2
3
Go to Page...
General topics
Digital
General topics
- General MRR
- H0-scale
- Small scale
- Big scale
- Prototype
--- Videos
----- Steam
----- Electric
----- Diesel
----- Accidents
- Digital
- Model railroad software
- Model railroad photography
Reviews
- Loco Reviews
- Reviews of rolling stock
- Accessories reviews
- Model kit reviews
Collector's Corner
- Collector's Corner general
- Märklin Sprint
- Construction kits
- Steam engines
- Tinplate toys
- Märklin Factory Layouts
The Projects & Workshop area
- Track plans
- Painting & Weathering
- Model railroad wiring
The Club Corner
You
cannot
You
cannot
You
cannot
You
cannot
You
cannot
create polls in this forum.
You
cannot
vote in polls in this forum.
Powered by YAF.NET
YAF.NET © 2003-2024, Yet Another Forum.NET
This page was generated in 0.620 seconds.
