Offline Jabez
#1 Posted : 01 August 2017 00:10:51(UTC)
Jabez
Does anyone have any views on the Marklin 72442 braking module vs the less expensive Viessmann 5232?
I mean apart from the wider argument for not using braking modules at all in favour of total PC control.
Jabez
Offline franciscohg
#2 Posted : 01 August 2017 00:15:36(UTC)
franciscohg
Chile
Hi, i use this, with no problems at all
http://www.floodland.nl/...nfo_afremmodule_en_1.htm
#3 Posted : 07 August 2017 15:18:08(UTC)
Jabez
Hi Jabez,
I know you don't want to raise the issue but I gave up using those braking modules mainly because of the added wiring complexity. I used Marklin, another German manufacturer and finished with my own. Later I got fed-up to do wiring Under the lay-outCursing
I switched to PC control (Rocrail). Yes there is some learning to do (forums help) but so much flexibility later and added security that I wouldn't consider returning to wired signals
Here is my train in operation:
#4 Posted : 07 August 2017 15:50:53(UTC)
Jean,I fully agree with you but for the moment I'm still using braking modules and yes the wiring is becoming a nightmare. from my activation point to the stopping point its about 3.5 m and the length of wires needed is 28m for 8 tracks, than I have opto coupler sensors which need another 28m. and this is only one set up, I have 3 of them so the total of wires: minimum is 56m x 3 = 168m and than there are all the smaller connections.
I just want to get it going and when I had a good running time I'll hopefully get the courage to install the Rocrail system.
braking modules for my layout (Digital)
by river6109 21/03/2017 06:49:13(UTC)
Viessmann 5232 Digital Braking Modules Problems (Digital)
by casdeop 25/07/2016 20:45:47(UTC)
Z-Scale Braking Modules (Small scale)
by Johnvr 22/08/2014 22:52:24(UTC)
76ΧΧΧ signals + braking modules + CS2 (Digital)
by svgeorgiad 22/02/2012 19:57:36(UTC)
Nielsenr - Braking Modules (Digital)
by Nielsenr 17/02/2012 06:30:08(UTC)
This page was generated in 0.615 seconds.
