Offline klafleur3
#1 Posted : 31 July 2017 04:14:54(UTC)
klafleur3
Will the Marklin 6021 and 6035 work with Marklin G scale trains?
Someone on eBay is asking me this question and I wasn't sure how to reply since I've only tested them on my Marklin HO layout and trains. Ken
#2 Posted : 31 July 2017 07:18:39(UTC)
The 6021 only supports the MM and MM2 protocols, so if your G scale trains can use those protocols then the 6021 will work with them.
If the trains require DCC or mfx then you're out of luck.......
Offline Markus Schild
#3 Posted : 31 July 2017 07:40:04(UTC)
Markus Schild
Hi Ken,
"G-scale" is usually used for products from LGB and other manufacturers where narrow- and regular gauge locomotives run on the same track (45mm) in scales between 1/19 and 1/29. Märklin never offered such trains. Märklin sells 1-gauge trains which are 1/32. They also run on 45mm tracks but the rails have a smaller profile than the G-scale rails. G-scale trains from LGB, PIKO or others usually don't work with the 6021.
Digital Märklin 1- gauge trains produced from 1986 - 1993 need the DCC-protocol and don't run with a 6021. Locomotives produced from 1993 until today can be used with the 6021.
Markus
Edited by user 31 July 2017 13:59:51(UTC)  | Reason: spelling
This page was generated in 0.352 seconds.
