#1 Posted : 03 May 2017 05:15:04(UTC)
From MTV Extra 21
Edited by user 03 May 2017 22:37:14(UTC)  | Reason: Not specified
#2 Posted : 04 May 2017 06:33:07(UTC)
English
I really doubt the reference to DIP position 10 being for "mfx or non-mfx"
the mfx scan and configuration can be done regardless of the possition of Dip 10
Once configured and in operation the switch is used by the decoder to recognise DCC v MM protocol for the address
The clip showing mFX discovery is for an old version of CS3 firmware
With later versions you get an option to use the address from the DIP switches or (, if there is a conflict for example) assign a new address
(pity about the spelling and grammar)
Similarly, when viewing the list of accessories on the current version the CS3, recently discovered items have a red boarder to assist with picking the item out from the crowd.
Offline MaerklinLife
#3 Posted : 04 May 2017 06:44:09(UTC)
MaerklinLife
Clearly a mistake in the editing. I use DCC for all my signals and mfx still works with DIP 10 as ON. I use mfx when I set them up. I never use MM.
This page was generated in 0.221 seconds.
