Offline Collector
#1 Posted : 12 March 2017 23:49:53(UTC)
Collector
Hi All,
Does anyone know if the steamer in this set is also available separately or which Marklin model number it is based on?
Marklin's database says: "The locomotive for prototypical double heading is available as item no. 37883"
But if I remember correctly the prototypical double heading often consisted of 2 different type locos?
DRG/DB/SBB Epoche II/III/IV
#2 Posted : 13 March 2017 00:09:13(UTC)
Originally Posted by: Collector Go to Quoted Post
Hi All,
I don't know that the loco in the set ever was available seperately with the same road number, but you have a couple of options vis: -
Check the other marklin 3788x series locos. Marklin tend to to assign blocks of numbers to a model and its variants. From memory the 37883 is different to the loco in the set, IIRC it is oil fired where the one in the set is coal fired, and I think this represents prototypical practice.
Secondly check for the Trix locos produced for the Trix version of the Lange Henry. I don't think the Trix version came as a set, so the two locos were produced seperately. It wouldn't be too hard to make it run on three rail. The Trix Lange Henry items were produced in the same year as the Marklin ones.
Another option may be to prowl ebay looking for the loco from the Marklin set.
While you are at it, if you are going to properly model the Lange Henry the Trix set of wagons has a different set of road numbers to the marklin set and additional wagons. With the set, the Marklin additional wagons and the Trix wagons you end up with an almost prototypical length train.
#3 Posted : 13 March 2017 00:09:31(UTC)
37883 was the additional oil fired loco for the Langer Heinrich set, but I don't know if Marklin separately issued the loco from the 26536 set, at least as a Marklin item.
Trix issued both locos as factory weathered versions - Items numbers are 22043 and 22044. Road numbers were the same as the Marklin locos - 44 494 and 44 100
#4 Posted : 13 March 2017 00:15:43(UTC)
None of the 3788x locos has the same road number as the 26536 loco (44 494) but 37880 might be the closest, although that's an era IV loco.
Offline Dave Banks
#5 Posted : 13 March 2017 01:04:23(UTC)
Dave Banks
I think David is correct in saying for Marklin #37880 & #37883 would be what you are looking for. But if you want the prototypical scenario you would need to get your hands on the Trix versions of those locos & note both are weathered versions & both would need to be converted to 3 rail & not difficult to do at all. Makes for a really nice set on anyone's layout.
https://www.google.com.au/search...=973&dpr=1.1#imgrc=_
D.A.Banks
thanks 2 users liked this useful post by Dave Banks
#6 Posted : 13 March 2017 02:15:05(UTC)
I've posted these before, but here are some photos of my two Trix LH locos.
Trix 22043
Trix 22044
#7 Posted : 13 March 2017 03:20:00(UTC)
Here's a document showing how to perform a 3 rail conversion of the Trix BR44's (German language) along with an English translation, partly done by a former boss of mine.
Converting Trix BR44 to Maerklin 3 rail.doc (16kb) downloaded 38 time(s).
Conversion of Trix BR44 to 3 rail running - 3LM-307 Umbau BR44 Trix.pdf (304kb) downloaded 41 time(s).
#8 Posted : 13 March 2017 08:21:16(UTC)
Many locos have been used for the Langer Heinrich and more than just two running numbers will be prototypically correct.
A BR 41 Oil or a BR V 200 can also be used as a second loco.
Double heading in MRR will be easier with two BR 44 (coal or oil) because they have identical gears and motors and in the best case identical decoders.
Offline Collector
#9 Posted : 13 March 2017 14:13:33(UTC)
Collector
Thanks guys. I asked because I already have the 37885. That however is also an era IV loco.
It SEEMS that the wagons are the only era III version with the short coupler mechanism. Can anyone confirm that?
Offline Collector
#10 Posted : 13 March 2017 14:15:07(UTC)
Collector
Mixing a steamer with a BR V200? Interesting.
Were these trains also pulled by just a BR V200 or any other non-steamer in era III?
#11 Posted : 13 March 2017 16:34:52(UTC)
In ere III the V 200 were primarily used for passenger trains.
Here are some pictures from era IV (see #15 and #24):
http://www.bundesbahnzei...014-10-16_Emsland-Diesel
The German Wikipedia mentions BR 50/BR 50 and BR V 100/BR 50 for era III (’60s):
https://de.wikipedia.org...ki/Langer_Heinrich_(Zug)
Offline Collector
#12 Posted : 13 March 2017 20:18:49(UTC)
Collector
Reading that wikipedia link I get the impression that if in the sixties the BR50 was used that the BR44 must have been after the sixties but according to Marklin this set is era III
#13 Posted : 13 March 2017 21:04:25(UTC)
I still have the 26536, 37883 and Trix 22043.
Also two video of long henry in action 1973 and 1976.
#14 Posted : 13 March 2017 22:19:48(UTC)
You could also use a double headed BR151 or a BR218...
Offline Collector
#15 Posted : 13 March 2017 23:59:29(UTC)
Collector
For those looking for the road numbers of various sets see here:
http://www.stummiforum.d...pic.php?p=676289#p676289
thanks 1 user liked this useful post by Collector
#16 Posted : 14 March 2017 02:41:56(UTC)
The wagon road numbers were posted in one of the previous threads on the Langer Heinrich / Long Henry topic, probably by Lutz Hemmerich. The list may have been deleted by Lutz when he left the forum.
I did keep a copy though, so here is the list.
Märklin #26536 "Langer Heinrich"
611 886
611 890
611 899
611 918
611 925
611 940
612 420
612 435
613 111
613 220
Märklin set #46255
612 100
612 321
612 389
613 078
613 150
TRIX set #24202
611 999
612 012
612 052
612 105
612 208
612 267
612 513
613 220
613 320
613 655
613 689
613 720
Märklin set #0775
611 892
611 900
611 905
611 910
611 915
612 022
612 026
612 109
612 221
612 261
613 014
613 091
TRIX set #24204
611 894
611 903
611 907
611 914
611 924
612 024
612 029
612 115
612 128
612 141
612 144
612 150
Offline dominator
#17 Posted : 14 March 2017 04:23:31(UTC)
dominator
37882 is a class 043. Could that be used as well.
Dereck
#18 Posted : 15 March 2017 14:55:02(UTC)
Dereck
Class 043 is just an Oil burning Br44. After the change to computer numbers the oil burning Br44 were renumbered Br043 and the coal burning ones Br044.
There is a similar case in the Br41 where the oil burners became the Br042 and the coal burners Br041
Offline dominator
#19 Posted : 15 March 2017 20:33:13(UTC)
dominator
Yup. bought the 37882 new in about 1999. Nice model and goes very well.
This page was generated in 0.647 seconds.
