Offline chpscott
#1 Posted : 02 December 2016 22:18:35(UTC)
chpscott
I am extremely frustrated because I have unsuccessfully attempted basically all day to get my Marklin train running. I guess I am used to simply plugging in the transformer and running the train, but I am finding operating Marklin trains to be much more complicated, and I need some help. I have a starter set number 29532 which has everything I need to run the set, including a mobile system what we call a transformer in the USA. And therein lies the problem. In the process of attempting to synch the numbers and everything else in the system with the loco I got so frustrated that I decided to reset the system and alas subsequently realized that now all the originally factory data is gone. When I turned on the system the letters BR 86 always was there, and they are no longer there.
The question is: Is it possible to restore the original factory setting on my own or do I need to send it somewhere to get restored to original settings?
Obviously if I can do it I need some help with this.
Any help you can offer is greatly appreciated! I simply want to get this up and running for my Grandchildren this Christmas and it should not be this complicated!
Thanks!
Chpscott
Offline manou
#2 Posted : 02 December 2016 23:33:21(UTC)
manou
You have to register the locomotive in the mobile station again. in the manual on pages 4 and 5, chapter Putting a Locomotive into the Locomotive list, describes the procedure. i would start with possibility B entering the number 29532 (i don't remember if the database contains starter sets) and if you fail you can go with possibility C entering the locomotive address which in your case should be 78.
Yannis
Best Regards
Yannis
This page was generated in 0.408 seconds.
