Offline walter__
#1 Posted : 29 November 2016 16:32:36(UTC)
walter__
We have created our own DCC controlled light switch, and it works fine when controlled from PC by sending an "ON" instruction over CAN.
The lights stay on as expected and we can turn them off again same way.
On the CS2 we see the actions happen, but we cant (or dont know) how to do it from CS2
we can define the module, and like with an "uncoupler rail" we can keep the lights on while holding the button.
the time-out setting cant be lower than 100 ms, and should be 0 for permanent use (as used from PC).
hope someone alredy used this, so all help is welcome.
Tks, Walter
#2 Posted : 29 November 2016 20:14:19(UTC)
I would need more information about what you have your PC doing.
It sounds like you may be trying to use DLC=8 when DLC=6 should be sufficient.
However I do wonder if there is a bit of misunderstanding about what On and Off means.
In summary there are four commands NOT two
1) Activate the On pulse ... - Press the Green button down - D-Byte4=1, D-Byte5=1
2) Deactivate the On pulse . - Release the Green Button .. - D-Byte4=1, D-Byte5=0
3) Activate the Off pulse .. - Press the Red button down . - D-Byte4=0, D-Byte5=1
4) Deativate the Off pulse . - Release the Red button .... - D-Byte4=0, D-Byte5=0
If you are using the Activate/Deactivate of either the On or Off pulse, to actually mean On and Off then you will have your symptom (like an un-coupler')
Further there is an inherent timeout value with the CS2 user interface. i.e. whereas holding the green button down on a 6021 for a 6083 would hold an un-coupler energised for as long as your finger was held down, the CS2 will timeout and send the "2) Deactivate the On pulse - Release the Green Button" regardless.
Offline walter__
#3 Posted : 30 November 2016 12:22:35(UTC)
walter__
Thanks for your reply Peter,
The program on PC, there I use a single button to act as ON/OFF for the lights, its not organized as the standard keyboard RED/GREEN combination (16 points on a keyboard) but 4 rows of 8 buttons giving up to 32 lights to command per keyboard.
With the DLC=6, CS2 automatically sends a byte 5 OFF after timeout (after button release)
So I do use the DLC=8 command CAN-ID 0x16 to switch ON/OFF the light decoder outputs from PC as follows
Byte 0..3.= 0, 0, 0x38, 163 ... DCC basic Button address for pair/impair
Byte 4....= 0 or 1 ............ for Pair/Impair button
Byte 5....= 0 or 1 ............ for OFF/ON
Byte 6,7..= 0, 0 .............. for permanent
I did build the custom light decoder on these specs using AtTiny 2313, and this works perfect.
So far we have not found how to set up a single (light) button on CS2 that can provide us this DCC ON/OFF function, as I don't use individual activate/deactivate, perhaps that's why we will not be able to test with CS2 direct unless the button is hold.
If there is a way to set up a single ON/OFF button on CS2, I still can change software for the light decoder accordingly.
Hope this shines some light on what we are looking for Cool
Walter
#4 Posted : 30 November 2016 21:46:47(UTC)
I think I understand now.
And No,
I too am unaware of how it is possible to set up a CS2 keyboard item to act as a single button with a specific On/Off toggle
(i.e. prevent the GFP from always turning off after a period)
This page was generated in 0.278 seconds.
