Offline Rwill
#1 Posted : 29 November 2016 11:19:42(UTC)
Rwill
On my tentative "Dear Santa" wish list is a rotary crane. I think they look fabulous and can see just the setting on my layout and have also always loved anything craney.
However when you see them in action on the likes of You Tube they seem very jerky and toy like. The latest version 76515 seems to be more so than the very old original 7051.
Is this because the film maker is not a competent crane operator?
Don't get me wrong I am not obsessive to prototype detail and realise that this is by its nature something of a novelty item which suits me fine.
Now I know from photos on here a number of you have these items on their existing layouts so are my worries of any foundation?
#2 Posted : 29 November 2016 20:38:26(UTC)
It could be because the rotary crane does not slew and raise/lower the hook at the same time. Real cranes do though.
Here is how one can rectify that problem with the Märklin crane: https://cabin-layout.blo...05/06/digital-crane.html
Offline dominator
#3 Posted : 29 November 2016 22:15:59(UTC)
dominator
I have one of the older ones [ 7051 ] which has never been used, apart from testing. I don't see why you cant slew and raise the older one at the same time. Also, if you couple it up to its own transformer, you should be able to adjust the power to it and give a more realistic slower motion.
Dereck
#4 Posted : 29 November 2016 22:28:40(UTC)
Dereck
yes correct, it is the way Märklin designed the digital one that added the limitation.
The older non-digital one was (I think) controlled by pressing buttons so each axis was either on or off, no speed variation.
Adding two loco decoders would give you speed control as well as independent movement.
Offline dominator
#5 Posted : 29 November 2016 22:31:53(UTC)
dominator
Digital can get bloody expensive eh.
#6 Posted : 29 November 2016 22:46:23(UTC)
yup for sure, but one can use old 6080 or delta decoders from an old loco that got upgraded to a better decoder. Probably cheaper than buying the digital crane too.
Offline ixldoc
#7 Posted : 29 November 2016 22:47:01(UTC)
ixldoc
The rotary crane 7051 will indeed slew and raise/lower simultaneously. Each function has it's own motor.
A friend of mine has two cranes mounted on a base , each controlled by a Mame type joystick on his Marklin display layout.
Both functions can be controlled at the same time. .
Children line up to use them and get a great kick out of it.
I have the same setup. Beats push buttons any day. I have controlled the Heljan container crane the same way.
The jerkiness you refer to may just be the U Tube playback as the crane movement is very smooth.
As Derek suggests, a good idea is use and old Marklin blue controller, variable power outlet supplied to the motors and full power outlet to the magnet or grabber.
Howard.
rotary Crane,CS3+,M84 (Digital components and Software reviews)
by ULI1944 10/12/2023 20:34:57(UTC)
Digital rotary crane - 7651 (Digital)
by Dean24 25/07/2019 06:11:54(UTC)
Help needed with the 76515 Rotary Crane. Problem solved (H0-scale)
by Piggy 24/03/2010 12:23:40(UTC)
Troubleshooting with rotary crane 7051 (H0-scale)
by Rocca 25/07/2005 00:51:56(UTC)
This page was generated in 0.416 seconds.
