Offline LMichel
#1 Posted : 23 September 2016 16:21:11(UTC)
LMichel
I'd like to upgrade an old locomotive (3163) with a new mld3 decoder but I hesitate between the reference 60982 and 60972.
Which decoder best fists for the 3163 ?
Thanks for your help !
Michel
Offline TEEWolf
#2 Posted : 23 September 2016 20:10:55(UTC)
Michel
Well, both new decoder have no sound, they are only loco decoders.
60982 has a wiring harness soldered to it with an 8-pin NEM interface connector plug for installation
60972 has a 21-pin interface connector and an accompanying interface connector circuit board for converting analogue and digital locomotives.
But first of all, what motor does your loco have? This will define your choice. I guess, first you have to find a new motor for your loco, because it might be still an analogue one.
Have a look here (even it is not in English)
Descripton of the 3163
and there
explosion drawing of 3163
P.S.: No offence Michael, brrrrr, but look up your word "fist", please Wink - I guess you mean "fit". If an Aussie is reading this, he will explode in laughing. OhMyGod
#3 Posted : 23 September 2016 20:58:01(UTC)
As TEEWolf says, if it's not a previously digital converted loco (ie not just a decoder upgrade) you will have to replace the motor parts too.
As I can see the 3163 has a DCM motor, and the motor replacement kit for that is 60941.
I would take the 60972 with the decoder module & plate. The 60982 will of course also work fine, but the 60972 will fit nicely - replacing the relay.
Offline dickinsonj
#4 Posted : 24 September 2016 01:55:17(UTC)
What he said!
All excellent advice Juhan, maybe because that is exactly what I would do as well. BigGrin
That AC to DC upgrade kit with 5 pole armature makes the old DCM motors run very well. Once you solder in the 21 pin plate, future decoder swaps will be just a simple plug in affair. Cool
Have you considered a sound decoder instead? They are not really all that expensive and I find that sound adds an important dimension to my locos.
Offline TEEWolf
#5 Posted : 25 September 2016 05:10:32(UTC)
Michel
Hi Michel,
here another link for descritption and explanation of the difference between the 8 and 21 pin decoders. It is a bit more than the pins.
Information about 8 and 21 pins decoder
The advantage of this internetside is the bilingual documentation in German and English. And I think dickinsonj is right. You should select the 21-pin decoder. This keeps you a lot more options for the future. And in your loco is enough space for the bigger decoder.
Wolfgang
This page was generated in 0.414 seconds.
