Offline Gregzim
#1 Posted : 18 March 2016 11:22:35(UTC)
Gregzim
HI
I wish to use reed sensors on c track. Because there is a center rail (studs) - it means I have to place the read contact on one side - but where does the magnet go as its required on both sides of the logo if the train is scheduled on the track from the opposite direction (magnet now on other side of train?
Al the magnets I see are little 'round things - so I assume I actually need 2 magnets per loco? Or is there something I am missing?
If my assumption is right - are there rectangle magnets that will cover the whole width of the loco? If so can someone advise who stocks them please?
Greg
Offline PMPeter
#2 Posted : 18 March 2016 14:29:00(UTC)
PMPeter
Hi Greg,
Both the Marklin and Viessmann reed switches are designed to fit on one side or the other of the centre pukos. The magnets available from Marklin are rectangular and come in various thicknesses and magnetic strength. Since I operate my layout as you describe with trains running in both directions I have seen the problem that you describe that depending on locomotive and location of the magnet, if the magnet is off-centre it may not trigger the reed switch in one direction. For those locos I have either added a second magnet, one on each side, or switched to the more powerful neodym magnet. (Be careful with those if you have small kids around. Swallowing these can be fatal.) I find these magnets have so much strength that they trigger the reed reliably each time. However, they are also so powerful that they can lift the moveable points of the older style switches and cause the loco to stall or derail.
So the key is the magnet positioning. If you use computer control software to run your railway, ideally you would want the magnet to be located at the same position on each loco so that you stop at the same location for signals, switches, etc. Unfortunately this is not possible due to bottom mouldings, slider position, etc. and I find that I have up to a 10" difference in magnet location between a short and a long steam loco.
Hope this helps.
Offline Gregzim
#3 Posted : 19 March 2016 01:19:49(UTC)
Gregzim
Tks Peter. Where do you get the neodym magnets from ?
Rgds
Greg
Offline PeFu
#4 Posted : 19 March 2016 06:59:40(UTC)
PeFu
Originally Posted by: Gregzim Go to Quoted Post
HI
Just being curious: Is there any specific reason for this? Smile IMHO, using C tracks, it could be easier to just cut the outer rail and connect it to a proper module for S88 bus, or similar? ThumpUp
Cool Peter
Offline PMPeter
#5 Posted : 19 March 2016 14:08:44(UTC)
PMPeter
Rgds
Greg
Greg,
I got them from a local North American crafts store called Michaels. However, they are also readily available from eBay under "neodymium magnets".
Offline waorb
#6 Posted : 21 March 2016 15:30:01(UTC)
waorb
Brazil
Hello Peter.
Yes, there is a reason. Wink
When you use a magnet, you got just a single trigger on the S88.
If you use the contact-track, you could have several triggers/hits on the S88.
Since the axles are the electrical contact, you should take care on the distance between the axles, so at least one axle is everytime on that specific track segment to guarantee a single trigger.
(you cannot use a small segment of track that fits betwwen the axles of a long passenger wagon for example)
Walter
Offline PeFu
#7 Posted : 21 March 2016 20:04:02(UTC)
PeFu
Hello Peter.
But if your contact track - the c track with outer rail cut - is long enough, you will have only one but long/permanent trigger on the S88? Blink
Cool Peter
#8 Posted : 21 March 2016 21:33:53(UTC)
Its the tension between wanting a single signal and wanting a precise location signal.
There are multiple ways of addressing the digital signals that result and defining how to react to create a reaction when you want - but I'm not familiar with the way systems using S88 can react to signals and what they can program (can one program in logic and timing?).. to know whether digital processing techniques can be applied in the control software used in model railroads. I'd hope one could.
Offline PeFu
#9 Posted : 21 March 2016 22:21:22(UTC)
PeFu
In the TrainController manual http://www.freiwald.com/software/Manual.pdf on page 135-138, I believe the difference between momentary contects (e.g. reed contacts) and occupancy sensors (e.g. contact tracks) is explained pretty well from a software point of view. The entry to an occupancy sector will also give you a precise location signal. I only have experience from using occupancy sectors, having outer rail cut, or by current detection. Therefore, I am still curious on the benefit of using reed contacts... Cost? Easier to implement on an existing layout? Blink
Smile Peter
Offline Harvey
#10 Posted : 22 March 2016 02:08:56(UTC)
Harvey
Certainly more than one way to accomplish a task. I use reeds exclusively, just preference.
- at entrance and exit of hidden yard and passenger station - CS2 memory will execute sequence of commands when magnet activates a reed.
- at signals - to turn prior one green or red.
- in covered sections, to turn current on or off for blocks
Harvey
Offline Danlake
#11 Posted : 22 March 2016 07:04:58(UTC)
Danlake
Hello Peter.
Walter
With PC software the optimal solution is that a block is showing occupied as long as it is physically occupied. That's one reason why you have the ability to put in delays in the software so a contact will show occupied for e.g. 2s extra. This elimate the potential flickering of the sensor due to dirty wheels or the distance between wheels.
For CS 2 that relies on simple event based logic, momentary sensors are adequate. Personally I would still opt for contact tracks (just make a short piece), as I believe they are more reliable than reed or switching tracks. My second preference would be IF sensors.
Brgds Lasse
Offline waorb
#12 Posted : 22 March 2016 19:14:38(UTC)
waorb
Brazil
I think it all depends on the application/logic/layout/expectation... Smile
Reed contact: just one hit from the train, usually direction dependent (only works in a one-way direction).
Circuit track: several hits from the train, one for each pickup shoe, no direction dependent (two-ways trigger, identifying both directions).
Contact track: could have one or several hits depending of the track length, no direction dependent (two-ways trigger, but just one identification regardless of the direction).
I think IR sensors could have the same application of the contact track; could have one or several hits depending of the position of the sensor (horizontal/vertical) with/without triggering between cars.
Walter
#13 Posted : 22 March 2016 19:25:04(UTC)
Peter, I buy magnets from UK... Will try to find the dealer...
Ah, found it - http://www.first4magnets.com/
Offline Thewolf
#14 Posted : 22 March 2016 19:34:05(UTC)
Thewolf
Hi everyboyBigGrin
I join the TCO of Itrain.
The reeds contacts are the small rectangles placed in the extremities of cantons. However in hidden station the least accessible ways are provided with rail of contact
By hoping to help you
Thewolf
Offline PMPeter
#15 Posted : 22 March 2016 23:01:07(UTC)
PMPeter
I assume you meant this for Greg who asked where I get my magnets from.
Offline Gregzim
#16 Posted : 29 March 2016 08:31:05(UTC)
Gregzim
Thanks for all your comments and details of where to buy magnets. I like the idea of track sensing but not of cutting rails. I like the use of magnets - but not sticking them under every loco, I favor IR as neither is required - but there's the cost and wiring :) There's always a pro and a con it seems. I also like the GamesonTrack - wireless positioning - but we're back to sticking transponders on trains and wiring them ?
I had high hopes for 'virtual blocks' on pc software - and it seems that as long as there is 'one' of the above per block TC can manage all the other contact points along the block through measured distancing. I will experiment over time and see what the best combination really is.
Rgds
Greg
Offline siroljuk
#17 Posted : 29 March 2016 10:56:04(UTC)
siroljuk
Hello Greg and others too.BigGrin
I have studied WinDigipet latest versdion 2015. You should inspect that too. There are many advantages and possibilities to handle virtual contacts. WinDigipet is not very easy to learn, but worth of looking at.
I have had WinDigipet for years and I have studied very closely how to automate my layout so that it would not be too automated.
The more I have studied the more I have understood WinDigipet. It is complicated and huge, but you can do anything you want with it.
Of course I wait eagerly CS3+ and all it's possible new features ThumpUp ThumpUp.
I can recommend you all to download WinDigipet English manual and study it( only about 800 pages LOL LOL )
Until my next post
Happy Training everyone
Jukka
thanks 1 user liked this useful post by siroljuk
Guest (11)
This page was generated in 0.457 seconds.
