Offline kaanair
#1 Posted : 02 December 2015 11:17:52(UTC)
kaanair
Turkey
I'm new to this site and I have decided starting of model train with Marklin locos and equipment.But I need some your previously experince as I following my question;
1 ) I knew it Mobile Station 2 controller runs DCC locos but is that C-track or K-track with compatible any of HO US locos ? Just like a MTH or Broadway Limited.
2 ) I need some flexible track for my small layout but I can't find Marklin C- flexible track on the web.Which is best flexible track for MS2 controller ?
Apologies for these simple question but I am new as you knew that.
Thank you very much
Kaan
thanks 1 user liked this useful post by kaanair
#2 Posted : 02 December 2015 11:32:52(UTC)
Hi, Kaan,
Welcome to the forum!
Re 1: There are MTH locos for three-rail that should run on Märklin C track or K track. There are MTH locos for two-rail that should run on Trix C track.
I think Braodway Limited only make two-rail locos - and those should also run on Trix C track.
Re 2: For three-rail there is the flextrack from the K track system. For two-rail there are many brands to choose from.
If you want to use Märklin H0 locomotives, then better stick to Märklin track. This means you cannot use Broadway Limited locos out of the box and when buying MTH locos make sure to get the three-rail version.
With MTH locos always check the minimum radius.
thanks 6 users liked this useful post by H0
This page was generated in 0.240 seconds.
