Offline marklin61
#1 Posted : 06 March 2015 06:16:32(UTC)
marklin61
I'm looking at installing ( maybe ) ball bearings in a selected number of my older loco's. But have some reservations on whether I will see any improvement in noise reduction and running characteristics. So I am interested in what others have experience by installing these bearings.
My second question is what type/ size of bearings are used and where does one purchased them from.
Appreciate any feedback, and apologises if this subject has been covered before . My googling seem to throw up more questions than answers...
Thanks steve
Steve...............
Life with Pinot Noir, Chocolate and Marklin trains..........
Offline NS1200
#2 Posted : 06 March 2015 07:00:57(UTC)
NS1200
Steve,
I wonder where to find those bearings.
I never found them but perhaps i have not digged deep enough....
The strain put on the drive motor and wheelsets of a Marklin locomotive is soo low that i reckon no bearings are required,it is just bare metal on bare metal i believe.
The number of revs of the Marklin motor does not warrant the use of bearings.
There are miniture bearings for sale for RC airplanes and RC cars,where the strain is much higher.
I have a job as purchaser in shipping and buying ball bearings on a regular basis.
These bearings are used in high rev. applications such as drive motors for pumps and separators,where high revs.will cause undesired wear and generation of heat.
Running such motors without bearings will cause trouble within minutes.
Not so for the average Marklin locomotive.
Paul.
Offline biedmatt
#3 Posted : 06 March 2015 12:22:27(UTC)
biedmatt
Hello Steve,
You'll learn a lot here: https://www.marklin-user...parts--motor-shield.aspx
Matt
Era 3
Offline Modelleisenbahnfan
#4 Posted : 06 March 2015 20:43:32(UTC)
Modelleisenbahnfan
I've installed ball bearings in three locos yet. If it is an older loco, who's bearings are used al lot, a ball bearing will birng al lot of sucess, espcially in noise reduction.
Your loco makes noises a bit like a real diesel? Then try ball bearings!
Also they are a good for the gear box (they prevents wear).
The size of the ball bearings should be: 1.5 mm inner diameter; 4mm outer diameter and 2mm height.
I by them here, but this won't be useful for you, because it's a shop in Germany.
kind regards
Robert
P.S.: For installing ball bearings, your locos must have the "HLA", I don't know, if it's possible if they have older motors.
Märklin, what else?
Offline Janne75
#5 Posted : 06 March 2015 21:49:13(UTC)
Janne75
I have installed ball bearings in around 100 locos with DCM (drum commutator motor) 3-pole or 5-pole. Ball bearings reduce that DCM motors "coffee grinder" noise, but not completely. Motor runs more freely, but the gears have also resistance and make noise so there will still be some noise after modification. DCM type motor without ball bearings needs often small drops of oil, but when there is ball bearings installed this lubrication need is almost non-existent. When I install ball bearings I put a very tiny drop of lightweight oil in their inner hole. Motor shield drilling must be done precisely in the middle. Original 1.5 mm hole is drilled first to 2.0 mm, then 2.5 mm, 3.0 mm, 3.5 mm and finally to 4.0 mm. Also the brush holders can be positioned incorrectly and cause some unwanted excessive noise as the brushes are not positioned then correctly 90 degrees from commutator.
I'm very happy with all my modifications Cool . I feel like my locos are more special when they have been modified. I must mention that in many older Märklin locos from 1940's and 1950's there is a brass bearing in their LFCM type motors. Those motors run also surprisingly quiet when all is ok otherwise in these (gears, wheels etc.).
I have also installed one ball bearing in all my C-Sinus motored locos (replaced that plastic bushing on the frame side with a ball bearing).
Janne
#6 Posted : 06 March 2015 21:57:03(UTC)
Modelleisenbahnfan
for drilling the hole, you can also take a center (or centre) drill (1,6mm -> 4mm).
kind regards
Robert
Märklin, what else?
thanks 1 user liked this useful post by Modelleisenbahnfan
#7 Posted : 06 March 2015 22:06:49(UTC)
Modelleisenbahnfan
Hello again,
in every case, you should use ball bearings closed on both sides, that the abrasion of the brushes don't go into the ball bearings.
kind regards
Robert
P.S.: Commonly, you haven't to oil the ball bearings, because they have grease enough. Oil could possibly damage more than help, I think.
Märklin, what else?
#8 Posted : 10 March 2015 13:57:42(UTC)
I thank the honorable member Matt for guiding the member Steve to my topic which I can see has had considerable success and followers.
Paul I can assure you. ball bearings do help the motor and there are several benefits associated with. drum collector armatures or any other type of motor has a plastic motor shield or brush plate and we can now confirm the friction is between metal and plastic. for instance if there is no friction on the back of the motor = metal to metal, why is there a provision to add oil, furthermore you may have heard from members or sellers who sell locos: the loco hasn't been used for years and the motor may need some oil as it could be ceased up, although it is a hint but it doesn't work in practice. the armature axle is made of a different metal than that of the motor housing and therefore oxidation can take place. you may have noticed in later years the back of the motor had a brass insert and later again a plastic insert.
The most important benefits are: a.) the brush plate needs no longer to be oiled and this prevents from oil going onto the brushes and the 3 or 5 pole segments, b.) the axle at the back again doesn't need to be oiled, c.) the running characteristics are smoother and especially at low speed and this helped further by following my discovery about the motor shield or brush plates construction and assembly in itself and its deficiency.
regards.,
thanks 7 users liked this useful post by river6109
Ball Bearings for Lok Armatures - UXCELL ? (General MRR)
by analogmike 12/05/2023 15:23:07(UTC)
Tools for modifying older Märklin locomotive motors to ball bearings (H0-scale)
by Markus Schild 16/03/2019 08:56:15(UTC)
60901 new motor sets with ball bearings in eBay (Digital)
by Janne75 24/01/2015 16:59:18(UTC)
Märklin BR 221 conversions (#29811) - Ball Bearings, LED lights, pickup shoe (H0-scale)
by Moritz-BR365 13/11/2014 08:46:17(UTC)
Märklin BR 120 (3653) - 60760 HLA conversion - Ball Bearings, Buffer Capacitor, F1 and F3 enabled (H0-scale)
by Moritz-BR365 01/10/2014 09:11:24(UTC)
Stator, ball bearings and a DCM with an LFCM part (Digital)
by rugauger 28/11/2008 02:15:55(UTC)
This page was generated in 0.684 seconds.
