Offline Tom Jessop
#1 Posted : 02 January 2015 03:26:29(UTC)
Tom Jessop
I picked up a HAMO 3829 [ BR 191 ] a few years ago on EPay & have not given it a run till this morning . It had been converted to 3 rail & supposably digital . When placed on the programme track for the CS1 upgraded it was not a goer . Worked out how to remove the top body , 5 screws in hidden places & then removed the brushes to see what was stuck , still no go & then took off the brush plate which is a major operation having to remove the coupling rods & external transfer case to get enough room to get the brush plate off to access the anker , wheels now turned ok , counted the teeth on the anker ,7, & looking at the exploded view on the web there is no teeth shown, Part #245480 . I let off the 2 mounting screws a fraction & the motor will buzz but not rotate, but with no anker fitted wheels turn with no excessive friction I am concerned that a wrong anker has been fitted prior to me buying this engine . Can anyone advise which anker part # should be fitted & also advise what sort of Decoder ? is fitted to the engine please . See picture below .
Cheers Tom in Oz
Tom Jessop attached the following image(s):
Offline Shamu
#2 Posted : 02 January 2015 03:55:06(UTC)
Shamu
5 pin anchor with 8 teeth: 1 Piece 386820
If it has the original Decoder: 960820 (it is DCC)
As to the decoder, can't say I recognise it, could be a optical illusion but a couple of the diodes look burnt. Could you do a photo of the other side Tom.
Offline Tom Jessop
#3 Posted : 02 January 2015 07:48:56(UTC)
Tom Jessop
Other side of decoder.
Cheers Tom in Oz.
Well that's not a good shot, try this one .
Just a bit better, taken with a cheap Fuji camera with poor zoom /macro
#4 Posted : 02 January 2015 15:56:30(UTC)
I don't think anything is burnt, I think it is just paint on the body of the component.
As there are no dip switches this is very likely to be marklins early DCC decoder (IIRC 6081?).
#5 Posted : 02 January 2015 17:57:57(UTC)
I have the same one from Hamo digital 2-rail loco. I think it is from 6082 c82 decoder for 2-rail digital.
It work with Marklin 6027 2-rail Central unit= only, Changing coding with Marklin 6032 programmes.
Offline ieco
#6 Posted : 04 January 2016 23:27:16(UTC)
ieco
Hi. Do any of you have the manual or can provide the link for the 3829?
I got one too, second hand, but its missing its paperwork
Thanks in advance !
Guest (6)
This page was generated in 0.403 seconds.
