Offline Ausipeet
#1 Posted : 02 January 2015 01:45:27(UTC)
Ausipeet
Came across a strange and fascinating loco the other day, i can not recall the model number but it did say Marklin on the side of the cabin, the thing that made it stand out was that when i turned it to look at the pick up shoe there was no pick up shoe, instead the was a round spring loaded metal plug situated slightly of centre that acted as pick up for this loco, having seen this set-up the thing that intrigues me is if this spring loaded pin is of set from centre then how can it pick up current from the centre rail? this leads me to believe that it might not be a three rail loco.
Is there any one here who might be able to shed some light on this please.
i will try to get some pictures in the next few days and post them here.
thank you
PeterConfused
Edited by moderator 05 January 2015 18:08:53(UTC)  | Reason: heading
#2 Posted : 02 January 2015 02:31:47(UTC)
Sounds real interesting.. Photos would be good.. Was it H0 scale?
Offline Ausipeet
#3 Posted : 02 January 2015 02:44:17(UTC)
Ausipeet
yes it is HO hope to be able to post pics tonight or tomorrow.
Offline Shamu
#4 Posted : 02 January 2015 03:05:25(UTC)
Shamu
Originally Posted by: Ausipeet Go to Quoted Post
the thing that made it stand out was that when i turned it to look at the pick up shoe there was no pick up shoe, instead the was a round spring loaded metal plug situated slightly of centre that acted as pick up for this loco....................Confused
Sounds like the old setup on the Fleischmann engines, can't recall the point of the "button" but IIRC it was on all the pre '70's loco's, maybe it was for triggering points/accessories ?. Perhaps its a early Hamo loco .Confused
Offline jcrtrains
#5 Posted : 02 January 2015 03:17:04(UTC)
jcrtrains
Yes;
Fleischmann had 2 mechanisms for triggering. One was as described; the other was a small indented square so that a small additional magnet could be placed inside.
#6 Posted : 02 January 2015 10:15:35(UTC)
..... there was no pick up shoe, instead the was a round spring loaded metal plug situated slightly of centre that acted as pick up for this loco, having seen this set-up the thing that intrigues me is if this spring loaded pin is of set from centre then how can it pick up current from the centre rail? this leads me to believe that it might not be a three rail loco.
i will try to get some pictures in the next few days and post them here. thank you
PeterConfused
Hi Peter,
Pure speculation here, on the description, but both Hornby Dublo (UK) and VB (France) used round spring loaded pick-ups on some of their devices.
Trix Twin (UK) used an offset spoon shaped pick-up, in conjunction with the normal centre slider.
#7 Posted : 02 January 2015 10:23:58(UTC)
Hi peter, your description matches what one would see on the bottom of a Hamo locomotive. Please post photos so we can confirm.
#8 Posted : 02 January 2015 10:47:04(UTC)
thank you
PeterConfused
I think you mean it´s for switch contact rail?
It´s for two rail and why it sit on the AC model i don´t understand.
www.fleischmann.de/en/pr...0-0-005006/products.html
Offline Renato
#9 Posted : 02 January 2015 11:11:10(UTC)
Renato
Hi Peter,
My speculation: till the late 50's the Märklin tracks had the third rail as a solid centre rail, so instead of the slider a sort of spring loaded metal button was installed to pick-up the voltage (or current).
I have no locomotives of such a type, but IIRC I saw this device on pictures of older locomotives or at a Modellbahn Treff in Göppingen.
I think it is not suitable for running on tracks with the "pukos", specially for the problems that could occurs on turnouts.
Renato
#10 Posted : 02 January 2015 12:02:25(UTC)
Exactly correct, I have a couple of HAMO Loco's and they too have the button - it's not a pickup however, it's grounded to the chassis.
It is indeed for a detection track, as used by Fleischmann (as noted by Goofy) who would most likely have been a significant market for HAMO.
Here is an image of the underside of an 8322 (3022) as well as the track image Goofy links to.
Edited by user 02 January 2015 19:39:03(UTC)  | Reason: Add image and clarification
#11 Posted : 02 January 2015 12:21:12(UTC)
thank you
PeterConfused
It's not on an 'AC' model, it's on a DC model = HAMO. Wink
Offline Ausipeet
#12 Posted : 02 January 2015 23:18:17(UTC)
Ausipeet
Thank you all, the images Cookee posted are what i was referring to and has cleard up for me my inqiury. so now i know i will not be looking at purchasing this unit.
thank you all
#13 Posted : 03 January 2015 04:39:16(UTC)
thank you all
If you like the loco and the price is right they are often not hard to convert to three rail. What is the model?
Offline Ausipeet
#14 Posted : 05 January 2015 00:47:34(UTC)
Ausipeet
Received the pictures of the Loco in question, this is the unit i was making inquiries about
Ausipeet attached the following image(s):
Offline analogmike
#15 Posted : 05 January 2015 03:02:08(UTC)
analogmike
hi peet; it looks like a dc lok because of the one-sided ground pickups on the tender. the box also does not match what's inside and it looks like someone has carved-out the styrofoam to fit the new ''mysterylok''. if 3-rail a.c. is your thing i would stay away from this one if you haven't purchased it yet. good luck, mike.
#16 Posted : 05 January 2015 10:08:25(UTC)
Hi Peter,
Hard to tell without seeing the road number clearly but my guess is that it's a 3047 Class 44 in the HAMO version making it 8347 and it should have Telex which is a bonus. As for the box, it sure is munted. 'Nuff said about that.
** Side note; how does Telex work with DC - anyone know?
In my opinion, conversion would not be too much of a problem but there are two aspects to it.
1: The wheels and pickups. The thing with HAMO is that the wheels are isolated each side (with a plastic bush in the axle) and this can pose some problems with smaller models. Fortunately, that model has wheels for Africa so a reliable rail contact is really not going to be a problem despite the fact that one full side of the Loco & Tender are isolated. Where it 'might' be a problem though is if you make use of Circuit Tracks having the isolated outer rail (for activating automated crossings, and also Station lights), is the isolated rail happens to be the same side as the grounded wheels, it will stop.
You will need to change the existing pickup from the current style which rubs against the inside of the wheels, to the traditional pickup shoe and this will involve obtaining those parts needed - the pickup shoe itself and the plate with wire that the shoe attaches to.
Interestingly, that one looks like the pickup is from the Tender wheels, and quite a few models are like this but the 3047 has its pickup under the Loco itself so this could actually give you two options but does mean at least one wire between the Loco and the Tender. Note the 3047
2: The Motor - now here's an advantage because it's already a DC motor, means it has the all-important permanent magnet instead of the reversing switch so you should fit a Decoder instead of trying to install a reverse unit - even if you only ever intended to run Analogue, it will be easier and I dare say cheaper and more reliable.
So yes there's a bit of work involved, and other have already said to pass on it, but heck, if it's cheap enough (ie $50 or less) then you might get a lot of satisfaction from the project. Anything more than that I think you could get a better one already 3-rail.
My two HAMO models are both Electrics so I have the added option of overhead operation anyway.
Hope this helps
This page was generated in 0.758 seconds.
