Offline Moritz-BR365
#1 Posted : 06 August 2014 12:57:44(UTC)
Moritz-BR365
V 3201 with Sound - Märklin 3720 Insider Model converted
Sound conversion with Doehler&Haass SD21A-4 Sound Decoder and NSB MY NOHAB Sound Project
New: With new sound project based on P8 steam and V36 Diesel engine!
Home made field magnet - replacement for Esu permanent field magnet
Create permanent magnet from the field magnet coil
Brawa KLv 60.9001 Catenary Test Coach - Sound and Light mod
Brawa KLv 60.9001 (Brawa #0527) with new decoder, sound, circuit board mod, ...
Klima Snowplug BA 845 DB Ep. IV - #46116
LED headlights and rear lights, interior light and diital function decoder
Märklin Rotary Snowplow / Snow Blower #49963 - Conversion of Decoder
Enables to control snow plow speed and switch motion independently from sound - Includes demo video!
Märklin C Track switch drive - how to disable defect limit switching (1 video tutorial)
Video tutorial - You can continue to use faulty switch drives when disabling the limit switching!
New C-Sinus / Soft Drive Sinus driver board - first test run and report
There is a new C-Sinus / Soft Drive Sinus driver board under development to replace old driver boards with integrated decoder to be able to use standard mtc21 or PluX-Decoder, e.g. with sound.
Convert 85 007 (Märklin #3309) to digital
Convert 85 007 (Märklin #3309) to digital with HLA motor, sound decoder and new LED head light board (to be continued)
Märklin V80 (36080) Sound Decoder conversion (with Video)
Märklin V80 (36080) Sound Decoder conversion with Doehler&Haass SD16A-4 PluX16 sound decoder
Märklin BR 216 (3075) - Ball Bearing and LED rear lights
Märklin BR 216 (3075) - Large slice collector motor equipped with ball bearing motor shield and new LED rear lights (case mod needed)!
Märklin BR 221 conversions (#29811) - Ball Bearings, LED lights, pickup shoe
Märklin BR 221 conversions (#29811) - Ball Bearings, LED lights, silence pickup shoe
Märklin BR 120 (3653) - 60760 HLA conversion with Ball Bearings, Buffer Capacitor, F1 and F3 enabled
Märklin BR 120 (3653) - 60760 HLA conversion with Ball Bearings, Buffer Capacitor, F1 and F3 enabled inc. circuit plan and link to external documents. The F1 AUX port must be am´plified with a transistor (circuit plan included).
Märklin VT 75.9 (37705) - RTS current-carrying clutch
Pictures of the VT 75.9 (37705) and how to insert a contact spring on the other side of the trailing car
Märklin MaK 1206 / 37635 / with switchable rear lights
The MaK 1206 (Märklin 37635) can easily modified to enable switchable rear lights.
Märklin V36 - "Doppeltes Lottchen" (37355) - 2nd Part - The Sound loco
Märklin V36 with new LED headlights with rearlights and additional bell sound - with Video!
Märklin V36 - "Doppeltes Lottchen" (37355) - 3rd Part - Maxon Motor!
Märklin V36 with new LED headlights, rearlights, additional bell sound and Maxon bell-type armature motor - with Video!
Märklin BR 185 (36850) with low beam, high beam and rear light
How to implement a new light board, based on Märklin E190372, high beam LEDs must be soldered by your own.
Märklin Einheitsmesswagen 49960 - Conversion to DCC Decoder
Replace the decoder with a DCC function decoder and white-red switchable headlight
Märklin 191 099-1 (3329) - Self made LED circuit board with red rearlights
Perfboard with SMD LED for head lights and rear lights
Märklin NS 1202 - New frontlighting with LED and red rear light
Next project, I will show, is the Netherlands NS1202. This model has a three point front light and two (unused) rearlights. Märklin modelled the light guide for all five lights, but only the white lights are used.
Märklin Bi-level Cab Control Car (43586) - Function decoder, high beam and LED illumination
How to change head lights and implement a function decoder into the Märklin Bi-level Cab Control Car (43586) with buffer capacitor and current-conducting coupler (switchable)
LED illumination for Märklin Bi-level Car
How to insert LED illumination into the Märklin double stack waggons with buffer capacitor and current-conducting coupler
Silence pickup shoe for Märklin MaK locos
How to convert a standard pickup shoe from a Märklin MaK 1206 (37635) into a silence pickup shoe. Inludes compatibility list of Märklin locos.
Ball Bearing for motor shield, gears and gear box
I had to repair a gear box of an Primex E141. This was the chance to test ball bearings for two gears of the gear box...
LED interior lightning for ICE 1 (33701)
Replace of the bulbs with LED stripes for lower power consumption.
LED interior lightning for Märklin Pendolino BR 610 (37761)
To lower the power consumption and to have a more regular illumination I converted the lightning first with single LED boards, then in a second step with LED stripes.
Märklin E60 (37562) with Telex coupler
The E60 is a classical shunting loco. Therefore, it was a must have to mount a Telex coupler to the E60.
Märklin E 60 (37562) with bell-armature can motor and buffer elco
For better slow motion and shunting usage, I mounted a buffer capacitor into the E60. The benefit will become better, when I change the bulbs with LEDs (not yet done).
Märklin Crocodile (3352) with Ball Bearing and HLA motor
After converting to HLA motor with ball bearings, the full metal croco 3352 is one of my best running models, very slow and smooth (incl. Video!)
Märklin Hobby 36xxx - mSD upgrade + buffer capacitor
Content:
- mSD Sound Decoder and buffer capacitor modification for Märklin Hobby models
- Description of soldering contacts on mtc21
- Experience with mSD decoder with buffer capacitor
Trix V80 (22075) with driver's cabin light
Conversion of a Trix V 80 005 (22075) by using the not documented but existing AUX port, mapped to F1, for a driver's cabin light.
Edited by user 08 January 2018 08:56:29(UTC)  | Reason: Made this very useful post into a Sticky
thanks 16 users liked this useful post by Moritz-BR365
#2 Posted : 24 August 2014 23:02:43(UTC)
Moritz-BR365
New in the list:
thanks 3 users liked this useful post by Moritz-BR365
#3 Posted : 25 August 2014 09:04:33(UTC)
Moritz-BR365
New in the list:
The MaK 1206 (Märklin 37635) can easily modified to enable switchable rear lights. With Video!
thanks 2 users liked this useful post by Moritz-BR365
#4 Posted : 10 September 2014 08:23:41(UTC)
Moritz-BR365
New in the list:
thanks 4 users liked this useful post by Moritz-BR365
#5 Posted : 01 October 2014 09:19:48(UTC)
Moritz-BR365
New in the list:
Märklin BR 120 (3653) - 60760 HLA conversion with Ball Bearings, Buffer Capacitor and F3 enabled
Märklin BR 120 (3653) - 60760 HLA conversion with Ball Bearings, Buffer Capacitor and F3 enabled inc. circuit plan and link to external documents
#6 Posted : 20 November 2014 08:04:28(UTC)
Moritz-BR365
New in the list:
Offline MalinAC
#7 Posted : 20 November 2014 11:40:28(UTC)
MalinAC
Ireland
Hi Moritz-br365, I must you seem to have been a very busy boy for the last few months. I wish I had the skill and patience to do that, but Im all thumbs. Take care Eddie. Huh Huh
thanks 1 user liked this useful post by MalinAC
#8 Posted : 20 November 2014 11:52:50(UTC)
Moritz-BR365
Thanks, Eddie,
I do it most times in the evening and night hours, when my wife and the kids are sleepingBigGrin
You need patience and calmness to do such things. It doesn't work when wife and three kids are calling You all three minutesLaugh
But, I hope during christman vacation to have some days, where the boys are working on house models and I can do some electronic stuff.
Moritz
#9 Posted : 16 October 2015 08:28:02(UTC)
Moritz-BR365
New in list:
#10 Posted : 20 July 2017 10:20:51(UTC)
Moritz-BR365
The latest updates:
LED headlights and rear lights, interior light and digital function decoder
This page was generated in 0.410 seconds.
