Offline sjlauritsen
#1 Posted : 31 March 2014 21:19:53(UTC)
sjlauritsen
Hi Guys
Can I be absolutely sure that an older 60215 (from e.g. early 2012) contains the same hardware as a new one from 2014?
...and yes, I am thinking of getting one. Laugh
Søren from Denmark
thanks 1 user liked this useful post by sjlauritsen
#2 Posted : 31 March 2014 21:38:44(UTC)
Well Søren, Marklin has different hardware versions on the 60215 - early versions were 4.3 I think. A version revision might be just something small like a substitute component for something that can no longer be sourced, or a minor revision to a circuit board layout. Essentially the units will do all the same things, so I don't think you need to worry too much about hardware revision levels.
My 60214 has an early 3.1 hardware version and does not support 5 amp track output, but I can get around that by using 60174 boosters with a 100va power supply.
Offline sjlauritsen
#3 Posted : 31 March 2014 21:50:25(UTC)
sjlauritsen
Okay, so I am not to worry about getting a "slower" version or something like that?
Søren from Denmark
#4 Posted : 31 March 2014 22:02:22(UTC)
No. Keep in mind that there always will be revisions, so you will be constantly chasing your tail if you worry about it. My v3.1 60214 will do everything the latest 60215 will do, except for the 5 amp output.
Offline sjlauritsen
#5 Posted : 31 March 2014 22:05:18(UTC)
sjlauritsen
Of course minor revisions are inevitable, my worries were that I would loose functionality. Luckily, that is not the case. :-)
Søren from Denmark
Offline witzlerh
#6 Posted : 31 March 2014 22:29:14(UTC)
witzlerh
Views messages in topic : 417
Dad has the 60213 CS2 and I have the 60215 CS2. Other that previously posted that "older" CS2 do not handle 100Va, everything is the same.
Marklin has a very good philosophy about making their stuff backward compatible. Even the brand new all plastic C track for the new my world will click together with the usual C track. This makes for easy storage track!
I am using MS1 and CS1 for extra throttles and the CS1 will run switches etc.
You do have a right to be concerned after the mess up with ESU and Marklin over CS1.
However with CS2, I think that Marklin is doing a good job with this product. Far better that many software companies!
Harald
CS2 DB & Canadian Era 3-6
#7 Posted : 01 April 2014 01:22:50(UTC)
Another feature that the v4.3x hardware introduced was galvanic isolation, but again that can be worked around with older hardware versions by making sure you use 60174 boosters, and do not use more than one device in a setup that does not have galvanic isolation with a common earth.
Offline pa-pauls
#8 Posted : 01 April 2014 15:11:01(UTC)
pa-pauls
At last ! Flapper
Pål Paulsen
Offline sjlauritsen
#9 Posted : 01 April 2014 15:43:36(UTC)
sjlauritsen
Originally Posted by: pa-pauls Go to Quoted Post
At last ! Flapper
Yeah Pål, I know you have been waiting for this moment... BigGrin
Søren from Denmark
Offline FrankF
#10 Posted : 05 April 2014 20:13:36(UTC)
FrankF
Hi Søren
The Marklin CS (60215) is produced with 2 types of Internal Hardware :
Hardware V5.1 - Galvanic isolation / Improvements regarding Noise-suppresion / Minor Hardware-Layout Changes (Newest versions)
Hardware V4.33 - Galvanic isolation using 2 CS2 units as Master/Slave and improvement for S88 Modules.
(Some Marklin 60214 Units is delivered with Hardware-version 3.6 in the Start and later on with Hardware-version 4.33)
Older Hardware Versions is :
Hardware V3.6 - NOR Flash changed from 200nm to 100nm-Technology (Die-Shrink) ( Some Marklin 60214 Units is delivered with this Hardware-version also, the first delivery series)
Hardware V3.5 - Optimized PCB-Card changes
Hardware V3.4 - EMV Improvements / Updated and Optimized Areas : Powersupply / Screen / Touch-Steering. (Marklin 60213 CS2)
Hardware V3.1 - Original Hardware when CS2 (60213) was delivered from the Start of 2008. (Marklin 60213 CS2)
CS3+ 60216 ( SW:2.5.2 ) / CS2 60215 ( SW:4.3.0 ) / MS2 60653/57 ( SW:4.28 ) / MS1 60652 ( SW:1.8 AP ) / 60883 S88 LINK ( SW:1.1 )
MDT 3 (SW 3.6.0) - HW: ( 60970 / 60971 / 60801 ) & ESU LOKPROGRAMMER ( SW 5.2.12 ) / ESU HW: 53451 / 53900 / 53901
thanks 2 users liked this useful post by FrankF
#11 Posted : 05 April 2014 22:13:03(UTC)
I've got news for you! My 60214 (yes, it is definitely a 60214) has hardware version 3.1
It seems they took some early 60213's, put the 60214 DCC upgrade on them, and called them 60214's.
My CS2 came in a 29500 mega starter set (https://www.marklin-users.net/fo...aspx?g=posts&t=16858)
Offline FrankF
#12 Posted : 06 April 2014 10:57:02(UTC)
FrankF
Hi Bigdaddynz
Ive have been helping som of my railroad friends with updating the CS2 (60214).
I have about 7-8 CS2 units (60214) in my hands and only seen Hardware-version 3.6 and 4.33 for the 60214 version
I Have a 60215 my self with Hardware-version 4.33 which i use on my H0-Layout (45 m2) with cable dimensions above 0.75 mm under the Layout.
I Have seen about 2-3 Marklin 60215 Unit also, but they all had the Hardware-version 4.33 installed.
Another funny thing regarding the CS2 is also that Marklin writes on the Update-website for the CS2 that USB-Updates wont be Updated anymore.
if you look in the Marklin Product-databank and enter "60215" to search for and take a look at the Product-page for the CS2 60215 it states under
the "Highlights"-section (The last line) that a USB-Update to the CS2 will be offered for Download in April 2014.
Offline waorb
#13 Posted : 07 April 2014 19:14:29(UTC)
waorb
Brazil
Frank F - Homepage: www.marklinisterne.dk / CS2 Lok-Icon Databank
Hello Frank!
It's off this topic (actually it's about your footnotes), but in short I want to congratulate you about your extensive/huge collection of CS2 icons!
Love
Walter
#14 Posted : 11 April 2014 13:32:46(UTC)
Bigdaddynz attached the following image(s):
This page was generated in 0.488 seconds.
