Offline drbob01
#1 Posted : 21 November 2013 16:24:18(UTC)
drbob01
Perhaps someone knows about this issue and can help me? I recently purchased a "new" ESU command station which I have connected to my C track layout that has 6 turnouts and 2 signals.
I have the trains running, but cannot get the signals or turnout decoders to be recognised, despite re-re-re-reading the manual. I was using the mobile station 2 previously and was hoping to use TouchCab for remote operation.
However, I see that I had to add a cable to connect the mobile station 2 to the command station. The IP address doesn't seem to be working on my ipad mini so far and the manual says the signals I have need to be addressed prior to installation.
Let me know if you have any such experience and how to get this corrected.
Thanks!
drBob
#2 Posted : 21 November 2013 16:47:17(UTC)
For signals and turnouts using MM protocol it is vital to connect B to centre rail and 0 to outer rail. Check the wires or try them swapped.
#3 Posted : 21 November 2013 17:20:23(UTC)
You have been a member since:: 12/08/2006(UTC)
Thanks!
drBob
"New"...??
What says the latest upgrade in yours "new" purchased Ecos??
Offline drbob01
#4 Posted : 21 November 2013 19:37:35(UTC)
drbob01
The manual says firmware3.4.0, 2nd edition, March2011
Offline drbob01
#5 Posted : 21 November 2013 19:40:24(UTC)
drbob01
Thanks! I will check and make certain that it's that way!BigGrin
Offline drbob01
#6 Posted : 02 December 2013 17:13:56(UTC)
drbob01
Thanks for the suggestion of swapping wires...that worked for everything except the mast signals 76390. They don't work and I no longer have the cardboard and clip that was originally in the box. Now I need to re-program the signal decoder using the ECoS command station, although the instructions on the manual for ECoS says keep the box intact (not possible!)
Does anyone have any luck in re-pregramming the 76390 series mast signals once they are already installed? They worked with MSII but not with ECoS. I would rather not buy new ones...
Thanks for helping.
PS: Marklin mobile station II doesn't seem to do anything when connected to ECoSlink even after waiting 10 minutes to re-program!
#7 Posted : 02 December 2013 17:25:45(UTC)
Thanks for helping.
This clip and carboard for the signals must always to safe,if you shall program.
Never throw them away!!
But Marklins new color signals will be arrive with new decoder with mfx and DCC.
Why not to try a new one??
#8 Posted : 02 December 2013 18:20:39(UTC)
MS1 and MS2 both use CAN bus, but speak different languages.
Only CS2 can use and update MS2, and can use MS1.
ECoS can use MS1 - and maybe even update it.
You can connect the trackbox of the MS2 to the sniffer port of the ECoS (use only DCC or MM protocol on the MS2).
Offline drbob01
#9 Posted : 02 December 2013 20:47:23(UTC)
drbob01
Thanks for helping.
Thanks! I didn't mean to throw it away, but after renovation, I cannot find it. As for new one, I would rather not spend the money if possible to reprogram the current ones.
Offline drbob01
#10 Posted : 02 December 2013 20:56:37(UTC)
drbob01
Thanks for the prompt reply! I presume you mean the box that connects to the track from the MSII? The wires can be inserted into the sniffer port and then I can operate the mast signal via the MSII...correct?
Thanks!BigGrin
Offline Iamnotthecrazyone
#11 Posted : 03 December 2013 00:11:23(UTC)
Iamnotthecrazyone
In regard of the signals and the cardboard piece. Are you good at soldering and have the proper tools to solder small areas? If so solder two wires were the cardboard bits would make contact and just join them as needed for programing. if you are not good better don't touch them as you can damage the circuit very easily. One thing I found with the ecos during programming of M signals is that you MUST set track DCC signal off otherwise they won't program correctly.
Offline drbob01
#12 Posted : 03 December 2013 17:32:19(UTC)
drbob01
Thank you! Now, I just need to figure out where those contacts were, so that I can make a replacement for them. Before I do, I will try to connect that track box to my ECoS sniffer and see if I can control the signals that way. Lots of help on this forum! I really appreciate it.
PS: does anyone know if the new decoder, Marklin item # 60831 m83 Decoder, will replace the discontinued 60880 decoder?
Offline drbob01
#13 Posted : 04 December 2013 01:58:54(UTC)
drbob01
Well, I tried connecting the trackbox to my sniffer with the MSII attached...no luck with working the signals. I am going to try to re-program the mast signals separately...here's hoping I don't kill them!
#14 Posted : 04 December 2013 08:42:25(UTC)
I´m not really sure,but i wonder if yours sniffer does disturb Marklins signals...??
Did you tried first without ESU products by only use MS2 to program signals?
Offline drbob01
#15 Posted : 04 December 2013 14:10:19(UTC)
drbob01
Yes, with MSII, all the decoders worked, including the 76xxx decoders for the mast signal. Now, I hooked up the track box to ESU and the MSII to the track box using the sniffer contacts on ESU. I can get the MSII to change to various functions, but none work and the mast signals don't light up. I am going to disconnect them from the layout and try programming them using a separate track and see if I can get ESU to recognize them. If not, I guess I will look for a new way to do this.
I want to get this layout to work with ESU before I begin adding my new layout plans to my current one. So far, everything works EXCEPT the decoders for the mast signals. Thanks, much for helping, Goofy!
Offline drbob01
#16 Posted : 07 December 2013 14:02:35(UTC)
drbob01
After no response with ECoS command station and MSII connected, I connected my MSII to the track, independent of the command station. The 76390 Marklin Mast Signals light up and work. Why can't I get any response when using the ECoS command station? All the other decoders for my turnouts work fine. Any ideas?
Thanks!
#17 Posted : 07 December 2013 14:24:44(UTC)
Is the ECoS set to use MM protocol for turnouts?
Offline drbob01
#18 Posted : 07 December 2013 23:11:36(UTC)
drbob01
Yes, and all the turnouts work...it's just the 76391 mast signals (2) that do not light up or appear to be recognized. I can only get them to work when connected to MSII. I hope I don't need to remove them to re-program them...that's what I am afraid of!
Offline drbob01
#19 Posted : 11 December 2013 01:47:39(UTC)
drbob01
Well, here is the latest in the saga of the 76391 mast signal: I totally disconnected from my layout and connected it to an isolated track, along with theECoS, confirming the B and O tracks were connected properly to the mast signal yellow and brown wires and the Ecos to the B and O track posts. I shorted out the signal decoder box using a paper clip and followed the directions in the Ecos manual, page23 and page 34, 18.9. I turned off Ecos and then after creating an icon for the mast signal, turned the Ecos on, waiting for the signal to start flashing...Nothing! no light, no nothing. Yet, it worked fine when connected to the track using MobileStation II.
Does anyone have any ideas?? I hope so!
Thanks for your help!
#20 Posted : 11 December 2013 08:25:30(UTC)
It seems there is bugs in the Ecos...
If signal works fine with MS2,why not with the Ecos??
Maybe you should try to reset yours Ecos and start it again.
By the way...did you upgrade the latest version from ESU for the Ecos??
Did you find out if there is any bugs in the Ecos?
If not is working with signal and the Ecos,you should contact ESU.
www.esu.eu
#21 Posted : 11 December 2013 10:42:35(UTC)
Having bought an ECoS you should be able to join the ESU forum after registering your command station, when this is all done enquire about your problem on the English spoken site
regards.,
#22 Posted : 11 December 2013 11:18:42(UTC)
Who knows where the bug is.
My Märklin turnout decoders work fine with my ECoS 60212 (aka CS1 reloaded).
Could be a problem with the configuration, could be a problem of the sender (ECoS), could be a problem of the receiver (Märklin signal).
#23 Posted : 11 December 2013 11:28:29(UTC)
When the signals work with the MS2, then they should also work with the ECoS using the same address without re-programming the signals.
Same for the turnouts.
The basic errors are swapping red (B, centre rail) and brown (0, outer rail) in the track connection of both controller and decoders.
Another basic error would be using DCC for those accessories (in the ECoS this can be configured for each accessory). You say you checked all that.
The ECoS allows to enable and disable protocols.
For a test you can disable RailCom, DCC, SX, mfx and try it with MM only (trying both settings for the asymmetric track signal).
Offline drbob01
#24 Posted : 11 December 2013 20:38:47(UTC)
drbob01
Thanks! I am a member of ECoS forum and they have not been able to figure this out either. Perhaps there is some error. I need to speak to someone who knows this unit and can maybe walk me through it. Forum is good, but not enough to and fro on the ECoS ESU forum to really figure this out. I am going to try to get to the person who originally sold the unit, which I purchased as new through EBay (tried to saver money!) Oh, well...so much for saving money!
#25 Posted : 11 December 2013 20:47:48(UTC)
Oh dear...
I suggest you shall try first to reset yours Ecos,because it´s second hand bought(used).
Tom has right...try to accept MM protocol and test if this work with signal.
Just in case...when you program signal,don´t use anything standing on the tracks(locomotivs with lighting on).
Offline drbob01
#26 Posted : 12 December 2013 22:19:36(UTC)
drbob01
Thanks !
I did try removing the signal and isolating it on the track with nothing but the Ecos wires. (The unit was sold after 2 weeks of use, and was said to be new) anyway, I tried everything, including a dealer who tried as I was trying and he also was unable to get any power to the mast signal. I think there is something that may be incorrect in the manual...I am checking on that with ESU support. As I progress I shall report!
#27 Posted : 13 December 2013 06:19:03(UTC)
You said your Ecos is at software version 3.4.0. The latest is 3.7.0, and you might want to update to that, just in case there were some bug fixes.
Offline drbob01
#28 Posted : 16 December 2013 20:43:37(UTC)
drbob01
Sounds like a worthwhile thing to do, since I am having quite a bit of trouble with this command station.
#29 Posted : 20 December 2013 03:27:57(UTC)
Iamnotthecrazyone
I still fail to understand this problem, you say the signals don't light up at all. Just by connecting power to them they should light up in state even if they aren't recognized. Since obviously your Ecos is putting some power out then that should be the case.
I doubt this is the cause of your problem but the power pack has a voltage adjustment and it might be set too low. You can check the voltage output of your ecos through the screen with the sliders, what do you have it set at?
thanks 2 users liked this useful post by Iamnotthecrazyone
GoofyH0
#30 Posted : 20 December 2013 09:27:56(UTC)
To use Marklin trains,you need power about 18 volt to the track.
Offline drbob01
#31 Posted : 24 December 2013 00:06:29(UTC)
drbob01
I have successfully upgraded my firmware to 3.7.0 and I now have my 2 locos working well. However, my turnouts seem to be sluggish and I wonder if I need a voltage booster. My current reading is about 13 volts. If that's too low, how do I get a voltage booster for Ecos? Maybe that's why my signals aren't working??
Thanks! And...Merry Christmas to all!
#32 Posted : 24 December 2013 08:10:20(UTC)
Read the manual. Or read this thread.
The ECoS comes with an adjustable power supply. A half turn to the right on the power supply will give you a higher track voltage.
I adjusted mine so I got a reading of 19 V with idle track (no trains running).
Offline drbob01
#33 Posted : 26 December 2013 14:06:05(UTC)
drbob01
Hi Tom,
Thanks for the tip! That's what the problem was---my voltage was too low and once I adjusted it to 18 volts it worked! The mast signals now light up. Now I can re-install them and hopefully get on with my layout addition. Thanks so much for your help!
#34 Posted : 26 December 2013 14:09:30(UTC)
It was Iamnotthecrazyone who pointed out the problem.
Offline drbob01
#35 Posted : 03 January 2014 16:05:46(UTC)
drbob01
Well then, many many thanks to lamnotthecrazyone for his very astute observation and suggestion!
#36 Posted : 03 January 2014 20:33:29(UTC)
Iamnotthecrazyone
No problem, I am glad to be of help when I can. it's the least I can do since other people in this forum have helped me on countless occasions too.
Guest (10)
This page was generated in 1.127 seconds.
