Joined: 19/10/2009(UTC) Posts: 14 Location: Southport, North Carolina
I have a Märklin Krokodil (#39563) engine and it is having problems picking up power from the track to drive the motor. All functions are working (whistle, lights, etc). Last week it started going into reverse on its own. I checked the voltage on the track and ran all my other locomotives no the track and everything looks good. Any suggestions on where I should start looking???? Thanks !
 1 user liked this useful post by Jackson
Joined: 23/03/2012(UTC) Posts: 2,555 Location: Finland
I have a brown Crocodile 39565 with full sound and it has sometimes strange running. It looks like it's motor will not get power for a while and then it goes ok again. It does not stop completely, but speed decreases for a very short time and then goes back to normal speed. Wheels and tracks are clean etc. Maybe it has some decoder problem, but all lights and sounds works just fine.
This was not an answer to your question, but a bit of same kind of problem. I bought this as new and it is the only one from my Crocodiles with these problems. Mfx and with SoftDrive Sinus motor. If I remember right 39563 has also Mfx and SoftDrive Sinus?
Regards, Janne |
Märklin H0 digital layout. I have analog and digital H0 Collection. Rolling stock mostly from era I, II, III and IV. Märklin 1 gauge beginner. |
Janne A couple of brain cells just came into play … now that I remember; I did notice speed changing quite frequently prior to it jumping into reverse last week. Thanks for responding. If you hear of anything; let me know and I will do the same.
Hi Wayne,
I will do some test driving with my 39565 and see if it still does that. I will clean all the wheels before testing to be sure they are absolutely clean. I have used my layout so much in the past three weeks and also run a track cleaning car so that is ok also. All other locos run just fine, except a SBB Ae 6/6 from 29680 starter set which also has varying speed at lower speed range. It also has a Mfx decoder but "normal" motor.
Janne |
Hi again, I cleaned the wheels and the small leading and trailing wheels were a bit dirty. When I started to just run it all was fine. But after around 30 seconds the same problem started again. Locomotive runs very silently but it looks bad when it "jerks". I put sounds on and when it does that it don't affect sounds. It seems like there is a motor power supplying problem (decoder defected?). I have put a few drops of oil to all axles and I have done the same thing to my other Crocodiles also. Could that oil cause this kind of running behaviour?  It is not so nice to own a over 400 euro loco (as new) and have such a bad running experience  . It will soon become my display case "queen" only as I bought it from eBay Germany and don't have a receipt for warranty, if I remember right. I have to check this out... And it is the other Crocodile with full sounds. Black new generation one is the other. Janne |
Joined: 10/07/2002(UTC) Posts: 3,299 Location: Patagonia
Hello Janne, well, she does not necesarly become the display queen, as al the machanical is well, the electronics can be easily fixed.....it happens to me with my Henschel-Wegmann set.... In the meanwhile, does it come with a 21 MTC connector? if so, to check if the decoder is faulty is the most easy thing.... |
 German trains era I-II and selected III, era depends on the mood, mostly Maerklin but i can be heretic if needed XD, heresy is no longer an issue.. LOL |
 1 user liked this useful post by franciscohg
Originally Posted by: franciscohg  Hello Janne, well, she does not necesarly become the display queen, as al the machanical is well, the electronics can be easily fixed.....it happens to me with my Henschel-Wegmann set.... In the meanwhile, does it come with a 21 MTC connector? if so, to check if the decoder is faulty is the most easy thing.... I don't know and I don't have a spare decoder. Maybe someone else knows if it has this 21 MTC connector? |
Joined: 16/02/2004(UTC) Posts: 15,467 Location: DE-NW
AFAIK all mfx locos are just plugged in. You just have to find whether it's NEM compatible or Märklin compatible.
Jerky running with flashing lights may appear like a decoder problem, but is often caused by bad contact due to over-oiled axle bearings. |
 2 users liked this useful post by H0
Looking at the diagram confirm that it is a plugged decoder just like Tom said. After checking that your axles are not overoiled, you can try with another's loco decoder you may have, or just order an mSD and try.....i think they are cheap enough to be used for diagnostic procedures |
Joined: 28/11/2007(UTC) Posts: 8,245 Location: Montreal, QC
Originally Posted by: Jackson  I have a Märklin Krokodil (#39563) engine and it is having problems picking up power from the track to drive the motor. All functions are working (whistle, lights, etc). Last week it started going into reverse on its own. I checked the voltage on the track and ran all my other locomotives no the track and everything looks good. Any suggestions on where I should start looking???? Thanks ! Jackson, a few quick questions to get more information... 1) What controller are you using? (6021, MS, CS?) 2) Have you tested the lok using an analog transformer (6646)? 3) When you say going into reverse on it's own, do you mean reversing as in the action of reversing or do you mean that the train only goes in the backward direction (as opposed to the one indicated on the controller)?. What happens when you manually reverse the direction? 4) Have you tested the lok inverted using either just wires or a short section of track to power only the slider section? 5) I have had an issue with an older crocodile where the drive wheel on the non powered end was gummed up. This prevented the proper movement of the lok. I am preparing to send the lok for a cleaning. Do all the wheels and rods move freely? Test carefully to make sure you don't damage any components. The 39563 was one of the more recent versions with the SDS and new Maerklin sound and decoder. I don't know if you can simply pop in an ESU Lokpilot or Loksound to test. It should have a 21 pin connector. If there is a problem with the decoder/PC board, this is an issue that will have to be addressed by the company. You may wish to ask Jacques Vuyes for his opinion. If the model is less than two years old, you should be able to send it back under warranty. Check with your dealer or contact service(at)maerklin.de If you send it back to Germany, you will have to pay the cost of shipment. If out of warranty, they will also charge you the repair and return costs. Regards Mike C
But just plug an mLD will work for testing ( around 30 euro )......and if the decoder is faulty replacing it with an mSD cost around 60-70 euro, if it is not under warranty perhaps it is the best option since you would have to pay the decoder and shipping....and at least my experience with M service was not the best.....3 months to get my CS2 fixed.... |
Originally Posted by: franciscohg  or just order an mSD and try.... Check the mSD Spezial manual first to see whether you need an mSD Spezial (#60940) or an mSD Normal (#60945/6/7). No mLD Spezial available. I don't know whether "wrong" decoder can do damage to loco or decoder. #39563/4 are candidates for the Spezial and may not work correctly with an mLD. |
mmmm, gets a little more complicated the testing procedure.....decoder still at the 60-70 euro range. |
Joined: 22/01/2009(UTC) Posts: 14,879 Location: On 1965 Märklin Boulevard just around from Roco Square
I don't like to sound too critical but why on earth I read when it comes to maintenance of locos, oil is the predominated factor. Unless your loco starts squeaking or makes some sort of unusual noise, there is not need to oil them. I don't want you adapt my maintenance policy and that is: none, unless there are some obvious signs. All it does, accumulate dirt and grime, it will ruin your adhesive tyres and your tracks get oily as well. if you have been able to give up smoking, stopped drinking alcohol you should be able to stop over oiling your engines.
regards.,
John |
 1 user liked this useful post by river6109
ohhhhhh, never succeeded to stop smoking and drinking....but i am absolutely away for that unhealthy overoiling practice.... |
Joined: 14/03/2005(UTC) Posts: 15,871 Location: Gibraltar, Europe
My experience is that it doesn't take long before locos start squeeking and grinding when you run them infrequently. I find myself oiling about one loco a week on average.
The secret is to use just one drop on each motor bearing, and one drop on each axle. |
Mostly Marklin.Selection of different eras and European railways Small C track layout, control by MS2, 100+ trains but run 4-5 at a time.
Hi all, Don´t get me wrong... I have not put too much oil to the axles. I oil them only when there is coming some noise telling me that axles are too dry. And I put just a very small drop of oil per axle with Faller oil with VERY thin needle. I have bought some locos second hand which were swimming in oil and that is not the case. Traction tyres were also very loose in those locos, because over oiling getting on them makes them very loose....  Lights are not flickering, only loco runs bad. I have to check the decoder type later. I have also a 29680 starter set green Mfx Crocodile with SoftDrive Sinus motor (same as 39563?) road number 14307. Then there is two 31860 brown Mfx Crocodiles which may also have same type of decoder? All these three others have only whistle sound and not full sound. Black Crocodile is also Mfx and has the same full sounds, but it has two motors and may have a different decoder? If the decoder is a plug and play type with some easy connection I could test my 39565 Crocodile with another Crocodiles decoder, BUT I´m afraid to damage the decoder and/or motor or electronics  . Cheers, Janne |
Joined: 09/04/2012(UTC) Posts: 1,343 Location: Southwest Ohio
Sounds like a bad decoder. If it is like the sinus drive on my 31859 brown Kroc, you will need aux 4 on continuously to power the drive. I upgraded mine with a LokSound V4. You need a 470uF 25V capacitor so the decoder can handle the increased current load of the drive. Info for installation is in the LokSound manual.
It is a 21 pin connection decoder. If you have other sinus drive Krocs, you should be able to swap it into the 39565 and test it.
What is the deal with this loko? I sold one a few months back. Did an 8 in CV8 to reset the values to factory and tested it before I sent it on it's way. At the other end the new owner also had trouble with the running characteristics. It was still in warranty so he got it repaired. Was there a bad lot of decoders? Marklin's first attempt at MFX decoders made by themselves and not ESU? |
Matt Era 3 DB lokos, coaches and freight cars from across Europe But I do have the obligatory (six) SBB Krocs ECoS 50200, all FX and MFX decoders replaced with ESU V4s, operated in DCC-RailCom+ with ABC brake control. With the exception of the passenger wagens with Marklin current conducting couplers, all close couplers have been replaced with Roco 40397. |
 2 users liked this useful post by biedmatt
Thanks from help. I will see later with better time how the decoder looks in 39565 and see from 39563 if it looks the same and test it. I will let you all know the results when I get it done... maybe later today in the evening. I hope that I don´t burn any electrics though Cheers, Janne |
Hi all, I opened both 39565 (full sound Mfx) and 39563 (from starter set 29680 only whistle sound Mfx). Decoders in both locos are 21 pin version, but they look different and are even different size. So I was brave enough (and stupid...  ) to swap the decoder from 39563 to 39565. Then I tested how it runs straight with loco object 39563 in my CS2 and put lights on. Worked ok, but other functions did not work like red tail light and whistle sound. I had not deleted loco objects and let this loco register itself again, I only tested how it runs. First the running looked really good, but after a short time the same bad running became back. Then I just put both decoders back to their right locos, but none of them showed any signs of working... No running, no lights and no sounds... After this I decided to give them a new try by deleting both loco objects from my CS2 loco list. Then I put the 39565 on track and it came back to my loco list and all sounds and lights work, but it still has bad running... Then I put 39563 on track and also it came back to my loco list and everything else works except the tail light won't change anymore from yellow to red as it should with that function  and now this loco has even worse running charasteristics than 39565 has. Before this it was perfect. I noticed a interesting thing: When 39563 starts jerking it's lights change towards opposite direction than it is running for a very short time (as long as it takes when the speed suddenly decreases). So now I have two bad running expensive Crocodiles. I was stupid when I changed decoders as they were not the same decoders. I just decided to give it a try as the motors in both locos are SoftDrive Sinus. Any thoughts or advices what could be wrong or what should I do? PS. Axles over oiling or dirty track is not an issue as the same part of track caused the problem and bad running only in one direction and not in the other direction. I'm very confused and will not buy these SoftDrive Sinus motored Crocodiles in the future. Good old C-Sinus motored 39560 and 39561 are better. I have a 39561 but not 39560 anymore. That is the next Crocodile I will buy again. Regards, Janne |
Hmmmmm, have you checked the 39563 for any short? Also maybe the board that is deffective.... Also, dont know about those specific decoders but....did you ever reset them? It may worth to take a look on the CS2 if the are setted for a C-sine engine. When i first put a mLD on the 26610 the running was very jerky until i checked and set it for c-sine motor Cheers |
 2 users liked this useful post by franciscohg
A lot going on in your post. I am going to address each item in bold inside the quote of your post. Originally Posted by: Janne75  Hi all, I opened both 39565 (full sound Mfx) and 39563 (from starter set 29680 only whistle sound Mfx). Decoders in both locos are 21 pin version, but they look different and are even different size. Makes sense. The 39565 is a full sound decoder with all sound files in the memory of that decoder. The 39563 is just an MFX decoder. The sound is another 1.5 x 1.5cm circuit board connected directly to the speaker and to the circuit board (via four wires) the decoder plugs into. An output of the MFX decoder tickles this board and makes the whistle sound.So I was brave enough (and stupid...  ) to swap the decoder from 39563 to 39565. Then I tested how it runs straight with loco object 39563 in my CS2 and put lights on. Worked ok, but other functions did not work like red tail light and whistle sound. I had not deleted loco objects and let this loco register itself again, I only tested how it runs. First the running looked really good, but after a short time the same bad running became back. You were not stupid. You can swap decoders around without damaging them. You may not get the same aux output based on the input button you press on your controller, this is a function of how the decoder input/outputs are mapped, but you won't damage it. Pressing input one on the controller may get output 2 on one decoder and 3 on the other decoder, but it is still just a voltage switched to a powered load. This is why other functions like the red taillight probably didn't map out the same.Then I just put both decoders back to their right locos, but none of them showed any signs of working... No running, no lights and no sounds... Odd, but it sounds like this is okay in the next paragraph.After this I decided to give them a new try by deleting both loco objects from my CS2 loco list. Then I put the 39565 on track and it came back to my loco list and all sounds and lights work, but it still has bad running... So back to bad running with the original decoder, but it did run okay with the 39563 decoder in the 39565 loko. Sounds like the decoder then.Then I put 39563 on track and also it came back to my loco list and everything else works except the tail light won't change anymore from yellow to red as it should with that function  and now this loco has even worse running charasteristics than 39565 has. Before this it was perfect. I noticed a interesting thing: When 39563 starts jerking it's lights change towards opposite direction than it is running for a very short time (as long as it takes when the speed suddenly decreases). So now I have two bad running expensive Crocodiles. I was stupid when I changed decoders as they were not the same decoders. I just decided to give it a try as the motors in both locos are SoftDrive Sinus. Could you have disturbed wire(s) from the 21 pin motherboard and the devices (lights, motor) they switch and control? You can't really damage anything by swapping them. The connections for the four aux devices, lights and motor are the same between decoders. If not, I would not have been able to replace the MFX decoders on 20+ lokos with LokSound and LokPilot V4 decoders without having to swap wires around. Getting the mapping right so the right output goes on with the right input (ie, which aux is that red light? You need to know this to map the functions properly.), but again, this is just how the decoder is mapped and not different connections between the decoder outputs and the 21 pin motherboard.[ The same pins on decoder A for the motor are the same pins on decoder B. Likewise all other aux outputs and front and rear lights.Any thoughts or advices what could be wrong or what should I do? PS. Axles over oiling or dirty track is not an issue as the same part of track caused the problem and bad running only in one direction and not in the other direction. I'm very confused and will not buy these SoftDrive Sinus motored Crocodiles in the future. Good old C-Sinus motored 39560 and 39561 are better. I have a 39561 but not 39560 anymore. That is the next Crocodile I will buy again. Regards, Janne |
Hi again, I think that the reason why 39563 has no more red tail lights is that the same function in 39565 is for engine sound. Maybe when 39563 decoder was put in 39565 and controlled with 39563 loco object (because of it's decoder) the same function output gives more current? and broke something in the electronics. Just my thinking... I also made a reset to the decoder and took of the plastics from the bottom of the 39563 and there was not too much oil there when I got a better look. But at the motor side there was a big amount of grease and I took a bit of it off. Then I put it back together and tested it. Now it runs pretty well and there is mostly problems in only certain speed levels, not all. I also noticed that the problems occur much more often on straight track sections and not in turns. This was the reason why I opened it up. But as I said now it is for some reason much better and only bad running at certain speeds. Maybe it helped when I opened up the hoods and center part again if something did a short circuit or similar, who knows? Next I will do the same things to 39565 to see if I can improve it's running also. I did a test run also with C-Sinus motored brown 39561 to see that there is no problems generally and track is ok. It runs like a dream! I will report how it goes with 39565 if it's running improves or not. Janne |
 1 user liked this useful post by Janne75
Hi Matt, Thank you very much from very detailed and well explained answer  . Now I can understand much better how these decoders and sound modules work. Function F2 is for red tail light in 39563. So I can see from your previous answer that electronics were not damaged by pressing F2 function from 39563 loco object in a 39565 that has engine sound with it's own decoder in F2. I just made a test run with different speeds again without front and rear hoods and middle part and it seems to run better when speeds are 0-60 % and gets worse with higher speed settings. Now it has less weight and maybe worse ground contact. During this posting I put back the front and rear hoods and the middle part. Now when it has more weight (and better grounding?) it runs better to higher speeds (80 %) and runs also better above this, but after some time makes sudden speed changes. It can go with full speed setting 100 % quite a long distance without any problems though. So those sudden speed changes or total stops are happening much less than before or without the covers (body). Also the lights are not blinking in the opposite direction than driving direction when it makes those speed changes. It is quite ok now, but unfortunately that red tail light function F2 is not working and I can not see any damaged or loose wires. But I'm happy that I got it running near perfectly  . Now I will open my 39565 to see what can be done... Cheers, Janne |
Just to show I am not blowing smoke up your behind. http://idioms.thefreedictionary.com/blow+smokeThis picture shows some of my conversions. All in the picture are 21 pin MFX decoders. Each bag has one decoder and possibly a Marklin 8 ohm speaker that was replaced with an ESU 4 ohm speaker. It may also contain the 1.5 x 1.5cm "squawk box" sound board. I have not lost a single decoder in any of these conversions. In all cases pins 17 and 18 are the motor. Pin 14 is aux 1, pin 13 is aux 2, pin 12 is aux 3 and pin 4 is aux 4. front lights are 8 and rear are 7. aux common is pin 15. It is this uniformity that makes it impossible to damage a decoder by swapping it into another loko. The pin outs are all the same, I have not rewired any loko except perhaps to add a speaker. You may get mixed mapping, but you won't damage the decoder. Before I bought the ESU decoder tester I would have to use trial and error to find what aux was wired to which loko event (front light, rear light, interior lights, changeover slider, sinus drive?). Now I plug the MFX decoder into the tester and press the Marklin icons on my ECoS. Now I know that red light on the Swiss Krocs is under say aux 2 and I no longer need trial and error to figure it all out.  This is what I call a "squawk box" from a loko with rudimentary sound. The loko does not have a sound decoder. It has just a standard MFX decoder. Aux outputs are used to input or tickle the auxiliary sound circuit board (sound files are there) and then the board directly drives the speaker. These lokos have only a couple sound options, horn and bell, or horn and whistle. They are very basic. This is Marklin # 39121. When I upgrade to an ESU LokSound, I document Marklin's installation so I can go back to original if desired. Like if I should sell the loko, there is no other reason to go back.  As you have probably determined, I have no use for Marklin's MFX decoders. |
Originally Posted by: Janne75  Hi again, I think that the reason why 39563 has no more red tail lights is that the same function in 39565 is for engine sound. Maybe when 39563 decoder was put in 39565 and controlled with 39563 loco object (because of it's decoder) the same function output gives more current? and broke something in the electronics. Just my thinking... I would say unlikely since the decoder outputs do have over current protection. Also remember that the function on one decoder may not be mapped to the same function in another decoder. That button may give aux 3 in one decoder and a sound file (no aux output at all) in another decoder. There are really just four "wildcard" events (aux 1-4) that feed voltage from the decoder to a powered device (interior lights, slider changeover etc). Decoder pin outs for the headlamps, taillamps and motor really never change. These wildcard events can be configured to any function button Marklin desires. They would be determined by what Marklin has wired to those four aux outputs. That aux output may also not be mapped to any function button on your loko controller. The change over of front or rear slider of a triebwagen is done automatically by the decoder depending on the direction of travel. You do not control this, they map one aux (we'll say front slider) to forward travel of the loko and a second aux (rear slider) for reverse direction. These two aux outputs tickle one of two relay coils in a dual coil latching relay, this relay then passes the third rail power from the correct slider to the decoder, powering the decoder from the slider desired.
This last type of event is where I would get frustrated when I made my conversions. I knew I could not damage anything, it just took a lot of time trying different possibilities until I found the right combination. Putting that MFX decoder in the ESU decoder tester now shows me exactly what those four aux outputs are doing so I can create the same map in the ESU decoder I install.
My guess is the decoder was perhaps damaged by static electricity. This was a big concern in the old MM 6080 decoders.I also made a reset to the decoder and took of the plastics from the bottom of the 39563 and there was not too much oil there when I got a better look. But at the motor side there was a big amount of grease and I took a bit of it off. Then I put it back together and tested it. Now it runs pretty well and there is mostly problems in only certain speed levels, not all. I also noticed that the problems occur much more often on straight track sections and not in turns. This was the reason why I opened it up. But as I said now it is for some reason much better and only bad running at certain speeds. Maybe it helped when I opened up the hoods and center part again if something did a short circuit or similar, who knows? Next I will do the same things to 39565 to see if I can improve it's running also. I did a test run also with C-Sinus motored brown 39561 to see that there is no problems generally and track is ok. It runs like a dream! I will report how it goes with 39565 if it's running improves or not. Janne |
 1 user liked this useful post by biedmatt
Hi Matt, Thank you very much! Now I understand even more of these digital decoders. If you don't need your Märklin Mfx decoders and sound circuits + Märklin 8 ohm speakers you can send them to me here in Finland... I will pay the shipping costs  . Just a joke  . I opened up my 39565 and it seems like some axle oil had mixed a bit with the grease in the motor gears. I cleaned it up a bit and also took some oil off from non powered end. From the visible axle and it's bushings. It helped it's running very much. Before it ran ok only at higher speed levels without jerking. Just opposite than 39563 which ran before worse when speed level was higher. Now this 39565 runs ok at lower speed levels also, but unfortunately it still jerks at around 70 % speed level. Not much above that or much less than that. But again like 39563 only at straight sections of track and not in turns. This just makes me think if there is a small grounding problem or still too much oil in axles. I have also a 33081 Delta DRG BR 85 that has bad running in straight track sections and works ok in turns. Other locos are running just fine mainly. Hmmmm.....  There is some similarities in Swiss Crocodiles and BR 85 like frame that moves to enable them to turn better. Now it is time to sleep before I have to wake up and go to work. This was a very interesting evening/night and I learned a lot of new things. Thanks once more Matt from your help and explanations! Cheers, Janne |
Originally Posted by: biedmatt  The pin outs are all the same Putting a sound decoder that was made for 50 Ohm speakers into a loco with a 4 or 8 Ohm speaker could kill the sound decoder. AUX3 and AUX4 are amplified on some decoders and TTL level on other decoders. I'm not sure if this can do damage to decoder or loco. The pin out is the same, but ESU decoders will not work in all Märklin or Trix locos that came 2009 or later. The loco will run, but light functions may not work correctly. |
Originally Posted by: RayF  My experience is that it doesn't take long before locos start squeeking and grinding when you run them infrequently. I find myself oiling about one loco a week on average.
The secret is to use just one drop on each motor bearing, and one drop on each axle. Ray, I have had locos for 50 years now and never ever had to oil them once a week under any circumstances. you may have a salt problem living in Gibraltar.  mind you I'm happy as Larry since I've added ball bearings John |
Originally Posted by: H0  Originally Posted by: biedmatt  The pin outs are all the same Putting a sound decoder that was made for 50 Ohm speakers into a loco with a 4 or 8 Ohm speaker could kill the sound decoder. AUX3 and AUX4 are amplified on some decoders and TTL level on other decoders. I'm not sure if this can do damage to decoder or loco. The pin out is the same, but ESU decoders will not work in all Märklin or Trix locos that came 2009 or later. The loco will run, but light functions may not work correctly. Agree about speakers, but AKAIK, MFX are 8 ohm and will work with ESU. Putting that MFX decoder back when you have an ESU 4 ohm speaker may damage the MFX sound decoder. Squawk box speakers are driven from the aux sound board picked or activated by an aux output. No problem there. I have only had two conversions that would not work. The 31859 white and green krocs have some strange mapping for the motor, but nothing got damaged, they just ran too fast. The lights were fine. I need to make permanent magnets for them like I did for my 3015 and 36159 and then convert them and give them sound too. With the 37772 and 37774 triebwagens everything would operate and all the lights were good, but the sinus drive would put the decoder into overload and the loko coast down even with a 470uF 25V cap connected to the decoder as recommended by ESU. Those decoders went into other lokos. All four are now run in MM mode with my ECoS. The capacitor has worked in all my other sinus drive loko conversions. All said I've done about 60 conversions. I only lost one, a sound decoder that went into a Br 85, 3309. I must have gotten a short between two outputs and I smoked the decoder. A lot of stuff inside the boiler on an articulated frame loko that wasn't engineered for it all. The second try went well. |
Janne, Another thing to try might be to put a LoPi decoder into the two lokos. With the LoPi you would have a low cost decoder to test the motors and the four aux functions. You will not get sound, but that's no big deal since sound comes directly from the decoder to the speaker. I could create a simple map that I could e-mail you and it could be loaded into the decoder with LokProgrammer, or you could write the CVs with your own loko controller.
Edit: Out of curiosity I opened my LokProgrammer file for the ESU decoder I have in my 31859 brown Kroc. This I believe is identical to your 39563 Kroc. Simple sound functions and sinus drive. I also got the MFX decoder I removed from that loko and put it on my ESU decoder tester to confirm what I was seeing. Aux 2 and 4 are constantly on. They are not controlled by any function button, nor the direction of travel the decoder is set to at any given moment. Usually (not always) aux 4 is the aux needed for sinus drive power. With this loko it appears 2 and 4 are used. The red marker light is under aux 3. Aux 1 is probably the output to the squawk box whistle. I forgot to test that function button. This is all probably different than the aux function mapping for your 39565 loko. That may only need aux 4 to power the sinus drive. Now you are understanding the frustration I had working out these decoders when I did not have the ESU decoder tester.
I would get a LoPi decoder, configure the 4 aux outputs to four function buttons so you could individually pick combinations to try and test how well the loko runs with it. This could prove or disprove the bad running is a fault of the Marklin decoders. There are a few other settings needed with sinus drive lokos, but they are simple and I could list them too if that is how you would like to proceed. 64614 is the LoPi V4 decoder that is 21 pin and also MFX compatible. I am not sure what controller you are using, but if it's Marklin, an MFX compatible decoder would then be my choice.
Also check and make sure the ribbon cable from the motor is secure in it's plug on the motherboard. I had one that was loose and the loko ran poorly. There is a catch or release on some plugs that will cause the cable to not make good connection. I remember the event, but not the exact fix. Mine was loose on the one that ran so badly. |
Joined: 17/09/2006(UTC) Posts: 18,778 Location: New Zealand
Check the loco's pickup shoe - maybe swap it for a new one., even though it might look OK. I've seen this fix many a loco running problem.
Originally Posted by: biedmatt  Aux 2 and 4 are constantly on. With some locos that have El Cheapo sound modules, one AUX may always be on to provide minus to the sound module. I have this with one of my BR 151 Märklin models. An amplified AUX that is on will give 0 V (minus pole) while an unamplified AUX that is on will give 5 V. mfx locos with (Compact) C Sine need 5 V for the driver board, supplied by AUX3 or AUX4. |
Originally Posted by: biedmatt  Agree about speakers, but AKAIK, MFX are 8 ohm and will work with ESU. Well, mfx has no impedance. Early Märklin locos used ESU mfx decoders were made for 50/100 Ohms. Current ESU mfx decoders and Märklin mfx decoders are made for 4/8 Ohm speakers. mfx decoder with blue PCB factory-installed in a Märklin loco: ESU, AUX3/4 not amplified and requires high speaker impedance. mfx decoders in Roco or ESU locos still have blue PCBs, AUX3/4 are still not amplified, but will require low speaker impedance (but speaker with high impedance cannot do damage). |
Originally Posted by: biedmatt  Janne, Another thing to try might be to put a LoPi decoder into the two lokos. With the LoPi you would have a low cost decoder to test the motors and the four aux functions. You will not get sound, but that's no big deal since sound comes directly from the decoder to the speaker. I could create a simple map that I could e-mail you and it could be loaded into the decoder with LokProgrammer, or you could write the CVs with your own loko controller.
Also check and make sure the ribbon cable from the motor is secure in it's plug on the motherboard. I had one that was loose and the loko ran poorly. There is a catch or release on some plugs that will cause the cable to not make good connection. I remember the event, but not the exact fix. Mine was loose on the one that ran so badly. Matt, Thanks from even more info. Yes, I think that 31859 or 31860 Mfx brown Crocodiles with whistle sound are technically the same as 39563 green Crocodile. So the problem is then maybe with decoder aux 3 (pin 12)? or the wire etc. after that or circuit board. I really don´t want to swap any decoders anymore when both 39563 and 39565 are now running better, but not 100 % perfect. If I would have the knowledge that you have from decoders and ability to program them and test them I maybe would do some further tests. I can check again the ribbon cables from both locos later, but if I remember right I checked them yesterday. So maybe if I would buy a normal Märklin Mfx decoder my 39563 red marker light could work again. Or if the decoder is ok and something else is faulty it does not help then. I can live without red marker light, but it is a nice function when Crocodile runs without cars. I have a Märklin CS2 60214 as my main controller. I have also an Control Unit 6021 for my lower level (separate) tracks under main layout and for loco programming purposes. Cheers, Janne |
Originally Posted by: Bigdaddynz  Check the loco's pickup shoe - maybe swap it for a new one., even though it might look OK. I've seen this fix many a loco running problem. This is a very good idea also, when thinking of power feeding circuit to motor as if here is some small problem it will affect these newer electric things more than the older locos. Both 39563 and 39565 have the new type pickup shoe and also the other Ae 6/6 having some running issues from 29680 starter set. I will buy some new pickup shoes and test later. They all look ok, but who knows? Cheap testing. Cheers, Janne |
Hi, I just called my Finnish Märklin dealer. He has a basic Märklin Mfx 21-pin new decoder from 29710 starter set diesel that has been converted to sound Mfx decoder as new. I will get it for only 5 euros!  I will buy it and some new pick-up shoes etc. If it is not the correct type to this 39563 Crocodile it can be used to some other locos as a spare decoder. Cheers, Janne |
Originally Posted by: Janne75  Hi, I just called my Finnish Märklin dealer. He has a basic Märklin Mfx 21-pin new decoder from 29710 starter set diesel that has been converted to sound Mfx decoder as new. I will get it for only 5 euros!  I will buy it and some new pick-up shoes etc. If it is not the correct type to this 39563 Crocodile it can be used to some other locos as a spare decoder. Cheers, Janne Very good news. |
The decoder from 29710 is an fx decoder of the 60760 type, not mfx. If your SDS loco requires AUX4 to be always on then you won't have much fun with this decoder. SDS locos also require decoder load regulation to be disabled - another requirement that can't be done with that decoder. |
 1 user liked this useful post by H0
Originally Posted by: H0  The decoder from 29710 is an fx decoder of the 60760 type, not mfx. If your SDS loco requires AUX4 to be always on then you won't have much fun with this decoder. SDS locos also require decoder load regulation to be disabled - another requirement that can't be done with that decoder. Bugger. The LoPi then looks like the easiest way to try a different decoder. These locked/unconfigurable/disabled Marklin decoders are a pain in the @ss. Why must they send second class decoders to their first class customers? Why do they block DCC in their Marklin decoders? As before though, I'm sure what we want means nuts to them. I get the cheap decoder in a starter set loko, that is geared for newb customers, but why do we get crap in the first line lokos too? Their loss too as well as mine. I have a small fortune in ESU decoders that most definitely would have gone to them instead. See picture above with 27 MFX decoders replaced with $130 ESU decoders. There are four more on my bench now too waiting to be changed. Maybe after the next bankruptcy they will care about what we want so they can help insure their survival. How they can be so indifferent to a shrinking customer base just blows my mind. The cost to them to enable DCC in their Marklin lokos will be very high for them. I see it as just one of several issues that will cause them to loose customers and go bankrupt yet again. The past track record of "our way or the highway" led them to bankrupty before, can't they see they're headed the same way except with the money of someone new? |
Originally Posted by: H0  The decoder from 29710 is an fx decoder of the 60760 type, not mfx. If your SDS loco requires AUX4 to be always on then you won't have much fun with this decoder. SDS locos also require decoder load regulation to be disabled - another requirement that can't be done with that decoder. Hi Tom, Thanks for information. It can be then a spare decoder for my 29710 diesel. I remembered that it was Mfx, but it is not. Still cheap for 5 euro  . Now I have new pick-up shoes also. Edit: But unfortunately I bought wrong type of "new type" pick-up shoes. They may fit many locos, but not these Crocodiles. They cost just 6 euro for three so cheap spare items for other locos anyway. It was good that I got info about wrong type of decoder before I had started to change it. Now I will not do anything to them as parts don't fit or are the wrong ones. I just changed two turnout decoders 74460 and one turnout motor 74491 (to self fixed = micro switches shorted) and once again all my turnouts work like they should.  That was my Märklin experience of today and no trains will run today as we have other things to do also. Cheers, Janne |
Ok ….. wow … Not sure where to start.
I am using a CS 60214. All non power wheels are turning freely. When it starts and stops, light go out. When I stated reverse, I should have stated it jumps into the opposite direction it was originally. I tend to agree with the folks that state that it is somewhere between the pickup and the decoder. The wires look as if they are all attached properly.
I can tell from the some of the responses that you folks are way ahead of me on repairs, so I'm looking for a repairman now.
I did learn a lot from all the responses.
Thanks to all for responding.
Jackson, I don't know where Southport is. I am guessing that is must be south of Northport, but I digress. In any case, the closest dealer that I can recommend for servicing and restoration of your model is Helmut's Hobby in VA. You can get the information from their website as well as the form that you are required to submit with a return. http://www.helmutshobbies.comhttp://www.helmutshobbies.com/Service_Form.pdfBut, before you do that, have you done any of the tests that I mentioned earlier? Test with an analog transformer Test with a classic 6021 See Post #10 for more details If you do not have an analog transformer, they can be bought out of start sets for a decent price. AJCKids in TX usually has some, as do many other dealers and on ebay. You can also use the brown and yellow leads from that transformer to power lights and accessories on your layout, even when not using the regulated control. If I can be of additional assistance, please contact me by PM Regards Mike C
